    Scaled array
    33 Posts 7 Posters 57.9k Views 7 Watching
      @Utiler
      Z Is not obvious, with it your model goes in the 3D space up & down! πŸ˜‰
      there is a little help text inside the code plug! Open it πŸ˜‰
      When I rotate a vertical ['Z' plane] object around what i think is the RED direction it actually rotates it around the GREEN...['Y']
      It's around the BLUE AXIS πŸ˜‰
      Order gives you the natural order of transformations πŸ˜‰
      About the first problem seems you can't oblige to have 80% for have perfect fit if you don't know the other X,Y,Z measures!
      it's depending of the measure of the first start volume!
      See my example above! I have 50% for this one (of course with my start measures volume)
      My regulates and don't forget the Growth point position (see image above)
      nb copy 3
      X spacing = 0
      Y spacing = 0
      Z spacing = 100 cm
      Scaling = Yes
      Xspacing scaling = 1
      Yspacing scaling = 1
      Zspacing scaling = 0.5
      Xcopy scaling = 0.5
      Ycopy scaling = 0.5
      Zcopy scaling = 0.5
      (all exponential+ by default)
      Move Scale Rotate order (or Move Rotate Scale as the is no rotation in this one)
      • utilerU
        utiler
        Thanks Pilou,
        I believe Z is always vertical [blue axis in SU]. If the ground plane is the ground then it makes sence to me that Z [blue axis is vertical....
        See the simple Palm tree attached.
        Say I want to rotate copy and move the palm fron as noted on the attached image. Still getting weird outcomes when I try to do so...
        thanks in advance.
        GrowTest.skp
        Just Curious...
          Something like this?
          • utilerU
            utiler
            No, Pilou. As a Palm fron grows [pardon the pun], it faces the sky with it's flat side facing up. Sometimes, slightly rotated but for the purpose of the exersice, lets keep it simple....
            This is what i mean.
            Then copy and rotate various frons to thicken up the folage...GrowTest03.png
            Then do a little 'Fredo' bending....
            So thats what i want to do with grow, however I just did this example manually...
            Skippy attached FYI...
            Thanks for your help with this idea, Pilou, much appreciated!! πŸ‘
            GrowTest01.skp
            Just Curious...
              Ok I see πŸ˜„
              Maybe monday a result πŸ˜„
              • utilerU
                utiler
                Thanks Pilou, look forward to your reply..
                πŸ‘ πŸ‘ πŸ‘
                Just Curious...
                • utilerU
                  utiler
                  Pilou, My Grow dialouge Box looks a little different.... older or newer?
                  Just Curious...
                  • utilerU
                    utiler
                    Still not working.... 😑
                    Not getting the same result as you even though I am imputting the same data...
                    Ready to un-install.
                    GrowTest.skp
                    Just Curious...
                      You have an older version! πŸ˜‰
                      The last version were in this same thread always by TIG πŸ˜‰
                        Maybe this πŸ˜„
                        But in fact all gives cool results just try different little variations
                        Palm's pull up is given by negative value πŸ˜‰
                        Here with these regulates (click image)
                        • utilerU
                          utiler
                          Damn!
                          I hate it when i feel amateurish... 😳
                          Thanks Pilou, I think I am on the right track now. I will post some updates later.
                          Thank you kindly for your persistence.
                          Just Curious...
                          • utilerU
                            utiler
                            Ok, I have loaded the new 2.1 version...
                            Did a little axis directions text [see attached.] It eems that the X axis directions are back to front. I would have thought that the postive directions would have been forward and the negative direction would be backwards....
                            Also, rotations around the Z axis are anti-clockwise. I thought it makes sense to have postive rotations clockwise and negative rotations anticlockwise.... [see also attached]
                            TIG, is there any reason for this?
                            Eitherway, I think i have it worked out. πŸ‘
                            Just Curious...
                            • H
                              hsjzyangbin
                              HI,TIG,i wish the picture just like show
                                You need to experiment with the 'Growth Point' origin in different places ? πŸ˜•
                                  hm... I wonder if there is a copy+rotate plugin out here already...
                                    @tig said:
                                    My Grow.rb already does this - there is an example of how to make a helical staircase in its thread...
                                    I'm not finding it easy to find it - is it this? http://forums.sketchucation.com/viewtopic.php?f=180&t=20195&p=168380&hilit=+grow#p168380
                                    It'd be best if it was in a thread by itself and not buried inside another thread.
                                      My Grow.rb already does this - there is an example of how to make a helical staircase in its threads...
                                        @tig said:
                                        Perhaps we could start a new thread to resurrect it - next week ?
                                        That would be good.
                                        Didier and Fredo had/has some old versions laying around as well. I noticed the last week several users seemed to have been downloading them instead of the new versions - despite noticed about newer versions. So I wanted to do a sweep of the plugin section and remove old versions and lock old obsolete threads. With the permission of the authors - in case they deliberately left them out there for legacy reasons.
                                          Grow.rb is a pretty old thing - probably predates the Forum !
                                          It's available from Didier's Depot and if you search by author [TIG] and 'Grow' there are several threads about it where I uploaded a version for convenience, there are also examples in some threads...
                                          • H
                                            hsjzyangbin
                                            Yes,I can do it with 'clf_component_stringer.rb'just like picture
                                            • 2 / 2
