    Scaled array
    33 Posts 7 Posters 57.6k Views 7 Watching
      Grow by TIG makes maybe not that you want but another thing ๐Ÿ˜‰
      Seems you can make something also with Protrude by Jim Foltz
        museummaker
        Thank you for the tips.
        I have been experiementing and quite get the perfect results.
        It is helpful and faster than doing it by hand but still end up tweaking things.
        I will continue to explore what these great rubys can do. Always things to learn. ๐Ÿค“
          Grow makes the trick but you must add another plug for align drop objects! Align by Didier Bur
          After the Scale
          x = 0.8
          y = 0.8
          z = 0.8
          because the Z Spacing don't accept a coefficient but just a value in cm ๐Ÿ˜ฎ
          Maybe Tig can make something ๐Ÿ˜‰
          Another plug must be created "Drop" on an existing object
          Seems Didier Bur has a drop inside Spray tool but... ๐Ÿ˜’
            Try changing the order of operations - scale then move then rotate, move then scale then rotate etc... This will produce differing results
              How change order as all is in the same dialog box???
              Sorry but seems impossible or I miss something for the Duh thread ๐Ÿ˜ณ
              Seems that the Zspacing accepting a % will be very cool?
              I have the 1.0 20070207
                There is a separate dialog at the end asking for 'order of operations'...
                The latest version of 'Grow' is now available for download here http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
                  Indeed that is a big Duhduh ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                  I had a very old version! ๐Ÿ˜†
                  So I must learn your new opus โ˜€
                    Ok that works like a charm ๐Ÿ˜Ž
                    except that we must find first the "Growth point"!!!
                    the "bottom point base" of the troncated crossing edges top Pyramid! ๐Ÿ˜ฎ
                    Maybe this can be automatic because in this case its' easy to find it but in case of complex form?
                    Or biggest volume?
                    Mr TIG it's your turn ๐Ÿ˜„
                    grow.skp
                    • utilerU
                      utiler
                      Gee, I'm glad i stumbled on this; I like Pilou had an old version....TIG, is this only relatively new? I just went to http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm and the old one still downloads.....
                      TIG, Have you produced a instructions sheet with this latest version? I am having trouble executing what i want to do. I seem to be confused as the the 'X' and 'Y' planes....
                      I assume 'X' is red direction; left and right,
                      'Y' is green direction; up and down the screen,
                      and
                      'Z' is obvious.
                      When I rotate a vertical ['Z' plane] object around what i think is the RED direction it actually rotates it around the GREEN...['Y']
                      Also, TIG, can you give a little detailed explanation of the order of parameters...?
                      I have been getting an awful lot of Bugspats!!!!
                      Don't get me wrong, I think once I get the concept of it I will have found my new favourite plugin!!!
                      Just Curious...
                        @Utiler
                        Z Is not obvious, with it your model goes in the 3D space up & down! ๐Ÿ˜‰
                        there is a little help text inside the code plug! Open it ๐Ÿ˜‰
                        It's around the BLUE AXIS ๐Ÿ˜‰
                        Order gives you the natural order of transformations ๐Ÿ˜‰
                        About the first problem seems you can't oblige to have 80% for have perfect fit if you don't know the other X,Y,Z measures!
                        it's depending of the measure of the first start volume!
                        See my example above! I have 50% for this one (of course with my start measures volume)
                        My regulates and don't forget the Growth point position (see image above)
                        nb copy 3
                        X spacing = 0
                        Y spacing = 0
                        Z spacing = 100 cm
                        Scaling = Yes
                        Xspacing scaling = 1
                        Yspacing scaling = 1
                        Zspacing scaling = 0.5
                        Xcopy scaling = 0.5
                        Ycopy scaling = 0.5
                        Zcopy scaling = 0.5
                        (all exponential+ by default)
                        Move Scale Rotate order (or Move Rotate Scale as the is no rotation in this one)
                        • utilerU
                          utiler
                          Thanks Pilou,
                          I believe Z is always vertical [blue axis in SU]. If the ground plane is the ground then it makes sence to me that Z [blue axis is vertical....
                          See the simple Palm tree attached.
                          Say I want to rotate copy and move the palm fron as noted on the attached image. Still getting weird outcomes when I try to do so...
                          thanks in advance.
                          GrowTest.skp
                          Just Curious...
                            Something like this?
                            • utilerU
                              utiler
                              No, Pilou. As a Palm fron grows [pardon the pun], it faces the sky with it's flat side facing up. Sometimes, slightly rotated but for the purpose of the exersice, lets keep it simple....
                              This is what i mean.
                              Then copy and rotate various frons to thicken up the folage...GrowTest03.png
                              Then do a little 'Fredo' bending....
                              So thats what i want to do with grow, however I just did this example manually...
                              Skippy attached FYI...
                              Thanks for your help with this idea, Pilou, much appreciated!! ๐Ÿ‘
                              GrowTest01.skp
                              Just Curious...
                                Ok I see ๐Ÿ˜„
                                Maybe monday a result ๐Ÿ˜„
                                • utilerU
                                  utiler
                                  Thanks Pilou, look forward to your reply..
                                  ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                  Just Curious...
                                  • utilerU
                                    utiler
                                    Pilou, My Grow dialouge Box looks a little different.... older or newer?
                                    Just Curious...
                                    • utilerU
                                      utiler
                                      Still not working.... ๐Ÿ˜ก
                                      Not getting the same result as you even though I am imputting the same data...
                                      Ready to un-install.
                                      GrowTest.skp
                                      Just Curious...
                                        You have an older version! ๐Ÿ˜‰
                                        The last version were in this same thread always by TIG ๐Ÿ˜‰
                                          Maybe this ๐Ÿ˜„
                                          But in fact all gives cool results just try different little variations
                                          Palm's pull up is given by negative value ๐Ÿ˜‰
                                          Here with these regulates (click image)
                                          • utilerU
                                            utiler
                                            Damn!
                                            I hate it when i feel amateurish... ๐Ÿ˜ณ
                                            Thanks Pilou, I think I am on the right track now. I will post some updates later.
                                            Thank you kindly for your persistence.
                                            ๐Ÿ˜
                                            Just Curious...
