    Scaled array
    33 Posts 7 Posters 57.6k Views 7 Watching
      There is a separate dialog at the end asking for 'order of operations'...
      The latest version of 'Grow' is now available for download here http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
        Indeed that is a big Duhduh ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
        I had a very old version! ๐Ÿ˜†
        So I must learn your new opus โ˜€
          Ok that works like a charm ๐Ÿ˜Ž
          except that we must find first the "Growth point"!!!
          the "bottom point base" of the troncated crossing edges top Pyramid! ๐Ÿ˜ฎ
          Maybe this can be automatic because in this case its' easy to find it but in case of complex form?
          Or biggest volume?
          Mr TIG it's your turn ๐Ÿ˜„
          grow.skp
          • utilerU
            utiler
            Gee, I'm glad i stumbled on this; I like Pilou had an old version....TIG, is this only relatively new? I just went to http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm and the old one still downloads.....
            TIG, Have you produced a instructions sheet with this latest version? I am having trouble executing what i want to do. I seem to be confused as the the 'X' and 'Y' planes....
            I assume 'X' is red direction; left and right,
            'Y' is green direction; up and down the screen,
            and
            'Z' is obvious.
            When I rotate a vertical ['Z' plane] object around what i think is the RED direction it actually rotates it around the GREEN...['Y']
            Also, TIG, can you give a little detailed explanation of the order of parameters...?
            I have been getting an awful lot of Bugspats!!!!
            Don't get me wrong, I think once I get the concept of it I will have found my new favourite plugin!!!
            Just Curious...
              @Utiler
              Z Is not obvious, with it your model goes in the 3D space up & down! ๐Ÿ˜‰
              there is a little help text inside the code plug! Open it ๐Ÿ˜‰
              It's around the BLUE AXIS ๐Ÿ˜‰
              Order gives you the natural order of transformations ๐Ÿ˜‰
              About the first problem seems you can't oblige to have 80% for have perfect fit if you don't know the other X,Y,Z measures!
              it's depending of the measure of the first start volume!
              See my example above! I have 50% for this one (of course with my start measures volume)
              My regulates and don't forget the Growth point position (see image above)
              nb copy 3
              X spacing = 0
              Y spacing = 0
              Z spacing = 100 cm
              Scaling = Yes
              Xspacing scaling = 1
              Yspacing scaling = 1
              Zspacing scaling = 0.5
              Xcopy scaling = 0.5
              Ycopy scaling = 0.5
              Zcopy scaling = 0.5
              (all exponential+ by default)
              Move Scale Rotate order (or Move Rotate Scale as the is no rotation in this one)
              • utilerU
                utiler
                Thanks Pilou,
                I believe Z is always vertical [blue axis in SU]. If the ground plane is the ground then it makes sence to me that Z [blue axis is vertical....
                See the simple Palm tree attached.
                Say I want to rotate copy and move the palm fron as noted on the attached image. Still getting weird outcomes when I try to do so...
                thanks in advance.
                GrowTest.skp
                Just Curious...
                  Something like this?
                  • utilerU
                    utiler
                    No, Pilou. As a Palm fron grows [pardon the pun], it faces the sky with it's flat side facing up. Sometimes, slightly rotated but for the purpose of the exersice, lets keep it simple....
                    This is what i mean.
                    Then copy and rotate various frons to thicken up the folage...GrowTest03.png
                    Then do a little 'Fredo' bending....
                    So thats what i want to do with grow, however I just did this example manually...
                    Skippy attached FYI...
                    Thanks for your help with this idea, Pilou, much appreciated!! ๐Ÿ‘
                    GrowTest01.skp
                    Just Curious...
                      Ok I see ๐Ÿ˜„
                      Maybe monday a result ๐Ÿ˜„
                      • utilerU
                        utiler
                        Thanks Pilou, look forward to your reply..
                        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                        Just Curious...
                        • utilerU
                          utiler
                          Pilou, My Grow dialouge Box looks a little different.... older or newer?
                          Just Curious...
                          • utilerU
                            utiler
                            Still not working.... ๐Ÿ˜ก
                            Not getting the same result as you even though I am imputting the same data...
                            Ready to un-install.
                            GrowTest.skp
                            Just Curious...
                              You have an older version! ๐Ÿ˜‰
                              The last version were in this same thread always by TIG ๐Ÿ˜‰
                                Maybe this ๐Ÿ˜„
                                But in fact all gives cool results just try different little variations
                                Palm's pull up is given by negative value ๐Ÿ˜‰
                                Here with these regulates (click image)
                                • utilerU
                                  utiler
                                  Damn!
                                  I hate it when i feel amateurish... ๐Ÿ˜ณ
                                  Thanks Pilou, I think I am on the right track now. I will post some updates later.
                                  Thank you kindly for your persistence.
                                  ๐Ÿ˜
                                  Just Curious...
                                  • utilerU
                                    utiler
                                    Ok, I have loaded the new 2.1 version...
                                    Did a little axis directions text [see attached.] It eems that the X axis directions are back to front. I would have thought that the postive directions would have been forward and the negative direction would be backwards....
                                    Also, rotations around the Z axis are anti-clockwise. I thought it makes sense to have postive rotations clockwise and negative rotations anticlockwise.... [see also attached]
                                    TIG, is there any reason for this?
                                    Eitherway, I think i have it worked out. ๐Ÿ‘
                                    Just Curious...
                                    • H
                                      hsjzyangbin
                                      HI,TIG,i wish the picture just like show
                                        You need to experiment with the 'Growth Point' origin in different places ? ๐Ÿ˜•
                                          hm... I wonder if there is a copy+rotate plugin out here already...
                                            @tig said:
                                            My Grow.rb already does this - there is an example of how to make a helical staircase in its thread...
                                            I'm not finding it easy to find it - is it this? http://forums.sketchucation.com/viewtopic.php?f=180&t=20195&p=168380&hilit=+grow#p168380
                                            It'd be best if it was in a thread by itself and not buried inside another thread.
