    Scaled array
    33 Posts 7 Posters 57.0k Views 7 Watching
      You have an older version! πŸ˜‰
      The last version were in this same thread always by TIG πŸ˜‰
        Maybe this πŸ˜„
        But in fact all gives cool results just try different little variations
        Palm's pull up is given by negative value πŸ˜‰
        Here with these regulates (click image)
        • utilerU Offline
          utiler
          Damn!
          I hate it when i feel amateurish... 😳
          Thanks Pilou, I think I am on the right track now. I will post some updates later.
          Thank you kindly for your persistence.
          Just Curious...
          • utilerU Offline
            utiler
            Ok, I have loaded the new 2.1 version...
            Did a little axis directions text [see attached.] It eems that the X axis directions are back to front. I would have thought that the postive directions would have been forward and the negative direction would be backwards....
            Also, rotations around the Z axis are anti-clockwise. I thought it makes sense to have postive rotations clockwise and negative rotations anticlockwise.... [see also attached]
            TIG, is there any reason for this?
            Eitherway, I think i have it worked out. πŸ‘
            Just Curious...
            • H Offline
              hsjzyangbin
              HI,TIG,i wish the picture just like show
                You need to experiment with the 'Growth Point' origin in different places ? πŸ˜•
                  hm... I wonder if there is a copy+rotate plugin out here already...
                    @tig said:
                    My Grow.rb already does this - there is an example of how to make a helical staircase in its thread...
                    I'm not finding it easy to find it - is it this? http://forums.sketchucation.com/viewtopic.php?f=180&t=20195&p=168380&hilit=+grow#p168380
                    It'd be best if it was in a thread by itself and not buried inside another thread.
                      My Grow.rb already does this - there is an example of how to make a helical staircase in its threads...
                        @tig said:
                        Perhaps we could start a new thread to resurrect it - next week ?
                        That would be good.
                        Didier and Fredo had/has some old versions laying around as well. I noticed the last week several users seemed to have been downloading them instead of the new versions - despite noticed about newer versions. So I wanted to do a sweep of the plugin section and remove old versions and lock old obsolete threads. With the permission of the authors - in case they deliberately left them out there for legacy reasons.
                          Grow.rb is a pretty old thing - probably predates the Forum !
                          It's available from Didier's Depot and if you search by author [TIG] and 'Grow' there are several threads about it where I uploaded a version for convenience, there are also examples in some threads...
                          • H Offline
                            hsjzyangbin
                            Yes,I can do it with 'clf_component_stringer.rb'just like picture
                            • H Offline
                              hsjzyangbin
                              Hi,TIG,I wish Chris 'Component Stringer'and yous "GROW.RB" combine together
                                Seems only Grow is necessary! πŸ˜‰
                                Just make in 2 parts!
                                Select the previous group "growed" and grow again πŸ˜‰
                                Not a big deal πŸ˜„
                                • 2 / 2
