    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 227.0k Views 61 Watching
    • urgenU Offline
      urgen
      ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function πŸ˜• ....I do not want come back to old script "ClineAtFaceIntersection.rb" πŸ˜’
      --pupil forever...------
      • Didier BurD Offline
        Didier Bur
        OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
        DB
        • urgenU Offline
          urgen
          ....thanks,Didier! πŸ˜›
          ...For drawing of difficult roofs this function is very necessary πŸ˜‰
            Didier Bur
            if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
            Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here πŸ˜‰
            DB
              rv1974
              Hi Didier!
              I can't make your new commands work.
              Some quotations from console:
              Error: #<NameError: uninitialized constant ProjectCpointTool>
              C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
              C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in call' Error: #<NameError: uninitialized constant XLinesThrougLinesTool> C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23 C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in call'
              Any ideas what's wrong in my case?
              And thank you again and again for your contributions.
                Didier Bur
                hi rv1974,
                your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case πŸ˜‰
                DB
                  DIEGO-RODRIGUEZ
                  Didier, thank you for this fantastic tool.
                  But I have the same problem massimo, with guide lines
                    rv1974
                    @didier bur said:
                    hi rv1974,
                    For a 1st sight everything is OK. In fact I have your toolbar and the point tool working (one single click though)
                      Didier Bur
                      Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
                      Regards,
                      DB
                      • massimoM Offline
                        massimo Moderator
                        Thanks Didier, now it works very well. πŸ‘
                        • O Offline
                          otb designworks
                          I am using a MAC pro, and this version 2 has no functionality on my computer.
                          Choosing any function has no effect whatsoever.
                          I am attaching the errors indicated in the Ruby console.
                          I have deleted all previous versions from my plug in folder.
                          Thanks and help! I use these all the time, especially extrude lines, which is a god send sometimes.
                          Cheers, Chuck
                          Cheers, Chuck
                          OTB Designworks is on Youtube
                            rv1974
                            Regards,
                            Indeed it goes OK πŸ˜›
                            Another thing: Could you add multiple not connected edges extrusion? It'd really add a lot
                              DIEGO-RODRIGUEZ
                              Thank you very much for update Didier.
                              Three suggestion.
                              a - be possible to customize the toolbar?for example Plugins 1001bit 1.1.6
                              Leaving active in the toolbar only the tools I'm interested
                              b - Erase guides, Could have an option to delete all guides of the drawing?
                              c - Insert Insert guides and guides at intervals at divisions, after using them, are active at the same starting point.
                              the tool could be active. But choose a new edge?
                              http://img20.imageshack.us/img20/7672/sinttulo2qdv.jpg
                              and a question.
                              Achieve as the result of this picture?
                              http://forums.sketchucation.com/download/file.php?id=29592&t=1
                              • kenK Offline
                                ken
                                Didier
                                Would it be possible to have a choice for Tools #6 and #7 to place either points or guide lines?
                                Thanks for me a very useful plugin
                                Ken
                                  Didier Bur
                                  Hi Chuck,
                                  It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. πŸŽ‰
                                  DB
                                    Didier Bur
                                    You can do that already. Select unconnected edges as you would do with connected edges !
                                    You can do that already too. After a first guides insertion, hit Enter to select a new edge (watch your status bar). Please read the doc folks ! πŸ˜„
                                    DB
                                    • urgenU Offline
                                      urgen
                                      ...Thanks for update Didier,very useful. πŸ‘
                                        Ben Ritter
                                        Didier,
                                        Fantastic tools! Thank you very much.
                                        • O Offline
                                          otb designworks
                                          @didier bur said:
                                          Hi Chuck,
                                          Hi Didier, thanks for the quick response.
                                          Yes, the projection.rbs is in the projection folder.
                                          I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
                                          thanks for the help
                                          Cheers, Chuck
                                          Cheers, Chuck
                                          • takesh hT Offline
                                            takesh h
                                            Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
                                            My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
                                            I've been using Projection tools for the longest time and am very familiar with how they work.
                                            They have been doing beautifully until I updated to ver.2.
                                            I clean-installed them as well.
                                            I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
                                            instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
                                            Hope this will be fixed... Thanks in advance!
                                            • 2 / 8
