    [Plugin] follow me rotate
    211 Posts 79 Posters 243.4k Views 79 Watching
    • W Offline
      wikii
      Another script still in development can do followme and keep the profile from rolling.
      Left part of the first image is followme ,right part is follow_me_and_keep .
      In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
        sorgesu
        Fantastic! Can't wait.
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
          Sounds fantastic! That would be something needed so long!
          • E Offline
            Ecuadorian
            Follow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
            Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here:
            404 Not Found
            (www.crai.archi.fr)
            The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis.
            -Miguel Lescano
            • N Offline
              notareal
              A must have tool!
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              • boofredlayB Offline
                boofredlay
                I am looking forward to it.
                • E Offline
                  Ecuadorian
                  Until follow_me_and_keep is ready (which will save all these following steps), here's a workaround:
                  • Go to Camera > Standard Views > Left
                  • Draw your profile within the plane formed by the positive blue and green axis, touching the origin.
                  • Erase the face leaving the lines, and make it a component.
                  • Select your profile (it must be a curve or a polygon, if it isn't, first join the edges with the join tool by Rick Wilson in the SCF Power Toolbar).
                  • Use the "copy along distance" button on the SCF Power Toolbar (also a script by Rick Wilson) and play with the distance until you're satisfied.
                  • Select all instances of the component and explode them. You can use Rick Wilson's script "select all instances": http://www.smustard.com/script/Instances
                  • Click on the "configuration" button of the "Skin" script by Darrel to "By order". Leave the other options blank.
                  • Execute the "skin" command and keep pressing "Enter" like crazy until the full object is done.
                  • Add soften/smooth edges to your taste.
                  You can download the "skin" script from this post:
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin&start=105#p101209
                  And you can browse the rest of that thread for the latest version of skin.rb, too, if you want...
                  Yeah, it's a lot of extra work, that's why all await for follow_me_and_keep.
                  -Miguel Lescano
                  • david_hD Offline
                    david_h
                    This is pretty fun to play with.
                      ada123
                      it's really nice
                      • SwissmountainS Offline
                        Swissmountain
                        Thanks for this awesome script! 👍
                        Cogito ergo dum-di-dum
                          tamfore
                          is there a link for a text file or description and instructions on what this plugin does and how to use it?
                          thanks
                          Tamfore
                            thanks
                            Tamfore
                            Select welded edges as path and a face before using this script.
                              kostas_designer
                              Cool!...
                              Jeff: i think you are talking about the SCF POWERBAR:
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar#p112024
                                ayieartwork
                                guys.how to rotate the shape from bigger to smaller?
                                Intel Core i7-3930k with 16gb G.Skill Ripjaws
                                • brookefoxB Offline
                                  brookefox
                                  I unzip to plugins; get FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb, which I must rename as I have a larger file of that name already (I put far.skp elsewhere). No plugins result in my pull down. I rename them *.rb and still nothing. Any tips?
                                  ~ Brooke
                                    you must keep names *.rbs!
                                      brookefox
                                      OK, thanks, though they did not work that way ---> It dawned on me belatedly that I needed to provide for the re-naming or not of inbox.rb: if I rename it then I guess I need to go through the code and replace the old name with the new name wherever it occurs.
                                      ~ Brooke
                                      • Chris FullmerC Offline
                                        What? You already have a inputbox.rb? This plugin appears to have a file called that, as well as another plugin then? Do you know what other plugin supplied the other inputbox.rb? If you PM them both to me, I'll look at them and see if I can help un-entangle this issue. It will probably take more than just changing file names inside the script.
                                          brookefox
                                          Thanks, Chris.
                                          Yes; yes. The three being: FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb.
                                          Both inputbox.rb open as below, but are different implementations:
                                          Inputbox.rb Copyright 2008 jim.foltz@gmail.com
                                          The Inputbox class makes it easy to create user input
                                          dialogs by providing a consistent interface to UI.inputbox for
                                          text fields and drop-down selection fields.
                                          Checking the date stamps and my downloads leads to 2 DLs on 4.4.: inputbox and model_location.rb, which may or may not require input box (it has been snipped from some search result locations).
                                          Certainly I can try renaming the existing to something else in order to see if that will enable FAR.
                                          ~ Brooke
                                            brookefox
                                            The renaming (and re-starting SU, as opposed to just re-loading the scripts) worked, but behavior is erratic. (I didn't want to trouble you further, Chris, if I could make the re-naming work.)
                                            First 4 images show a failure with a welded straight path (called a curve by SU) and a rectangular face.
                                            Second 4 show success with a truly (apparently) curved path and a round face.
                                            The final image shows the SU upload dialog which leads one to believe you can upload more than one attachment at a time but which then ignores the request.
                                            ~ Brooke
                                            • 11
                                            • 6 / 11
