    [Plugin] follow me rotate
    211 Posts 79 Posters 258.0k Views 79 Watching
      Now I see. It's all hidden normally.
      Thanks.
        sorgesu
        I thought this plug-in would be useful in finally solving the missing "sweep" tool, so I tried it. More specifically, I showed this one before, trying to make a squared handrail on a spiral staircase. Using follow me doesn't work because it curves the form so that the top isn't parallel with the ground. For this spiral stair case the steps are rotated 30 degrees so I tried the ruby with a 30 degree input. Totally didn't work. I tried various different inputs and I finally found one that visually, was "good enough". The input was -3 degrees.
        Can you take a look and let me know if there is a better number and if I there should be some relationship that can always be used to figure out what angle to use?
        Even if not, this saves just a ton of time as is and it is quite adequate for this job too! Thank so much.
        SpiralStairRail.skp
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
        • W Offline
          wikii
          Another script still in development can do followme and keep the profile from rolling.
          Left part of the first image is followme ,right part is follow_me_and_keep .
          In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
            sorgesu
            Fantastic! Can't wait.
            Susan Sorger
              Sounds fantastic! That would be something needed so long!
              • E Offline
                Ecuadorian
                Follow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
                Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here:
                404 Not Found
                (www.crai.archi.fr)
                The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis.
                -Miguel Lescano
                • N Offline
                  notareal
                  A must have tool!
                  • boofredlayB Offline
                    boofredlay
                    I am looking forward to it.
                    • E Offline
                      Ecuadorian
                      Until follow_me_and_keep is ready (which will save all these following steps), here's a workaround:
                      • Go to Camera > Standard Views > Left
                      • Draw your profile within the plane formed by the positive blue and green axis, touching the origin.
                      • Erase the face leaving the lines, and make it a component.
                      • Select your profile (it must be a curve or a polygon, if it isn't, first join the edges with the join tool by Rick Wilson in the SCF Power Toolbar).
                      • Use the "copy along distance" button on the SCF Power Toolbar (also a script by Rick Wilson) and play with the distance until you're satisfied.
                      • Select all instances of the component and explode them. You can use Rick Wilson's script "select all instances": http://www.smustard.com/script/Instances
                      • Click on the "configuration" button of the "Skin" script by Darrel to "By order". Leave the other options blank.
                      • Execute the "skin" command and keep pressing "Enter" like crazy until the full object is done.
                      • Add soften/smooth edges to your taste.
                      You can download the "skin" script from this post:
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin&start=105#p101209
                      And you can browse the rest of that thread for the latest version of skin.rb, too, if you want...
                      Yeah, it's a lot of extra work, that's why all await for follow_me_and_keep.
                      -Miguel Lescano
                      • david_hD Offline
                        david_h
                        This is pretty fun to play with.
                          ada123
                          it's really nice
                          • SwissmountainS Offline
                            Swissmountain
                            Thanks for this awesome script! 👍
                            Cogito ergo dum-di-dum
                              tamfore
                              is there a link for a text file or description and instructions on what this plugin does and how to use it?
                              thanks
                              Tamfore
                                thanks
                                Tamfore
                                Select welded edges as path and a face before using this script.
                                  kostas_designer
                                  Cool!...
                                  Jeff: i think you are talking about the SCF POWERBAR:
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar#p112024
                                    ayieartwork
                                    guys.how to rotate the shape from bigger to smaller?
                                    Intel Core i7-3930k with 16gb G.Skill Ripjaws
                                    • brookefoxB Offline
                                      brookefox
                                      I unzip to plugins; get FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb, which I must rename as I have a larger file of that name already (I put far.skp elsewhere). No plugins result in my pull down. I rename them *.rb and still nothing. Any tips?
                                      ~ Brooke
                                        you must keep names *.rbs!
                                          brookefox
                                          OK, thanks, though they did not work that way ---> It dawned on me belatedly that I needed to provide for the re-naming or not of inbox.rb: if I rename it then I guess I need to go through the code and replace the old name with the new name wherever it occurs.
                                          ~ Brooke
                                          • Chris FullmerC Offline
                                            What? You already have a inputbox.rb? This plugin appears to have a file called that, as well as another plugin then? Do you know what other plugin supplied the other inputbox.rb? If you PM them both to me, I'll look at them and see if I can help un-entangle this issue. It will probably take more than just changing file names inside the script.
                                            • 11
                                            • 5 / 11
