    [Plugin] follow me rotate
    211 Posts 79 Posters 252.0k Views 79 Watching
    • E Offline
      Ecuadorian
      Sure, I posted the links in the Youtube video description. click on "(more info)" to show it. I'll copy the description here:
      Today I read this tutorial for doing a "twisted leg": http://finewoodworking.taunton.com/item/6095/doin-the-twist
      But I remembered that in the SketchUp Community Forums there are free tools that can do the same thing in a snap. So I decided to record a video tutorial.
      You'll need the SCF Power Toolbar, which includes the "Join edges" tool by Rick Wilson:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar
      And the "Follow me rotate" script, by wikii:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&st=0&sk=t&sd=a
      In this video I did a counter-clockwise twist. To do it clockwise, simple input a negative value in the "Rotate" field of the Follow And Rotate script.
      Remember to check that the line was properly divided before using the "Join Edges" tool; if you don't, the Follow And Rotate tool might not work properly.
      Tutorial created with Camstudio, a free and open-source excellent little piece of software, and subtitles added in Windows Movie Maker.
      -Miguel Lescano
        Now I see. It's all hidden normally.
        Thanks.
          sorgesu
          I thought this plug-in would be useful in finally solving the missing "sweep" tool, so I tried it. More specifically, I showed this one before, trying to make a squared handrail on a spiral staircase. Using follow me doesn't work because it curves the form so that the top isn't parallel with the ground. For this spiral stair case the steps are rotated 30 degrees so I tried the ruby with a 30 degree input. Totally didn't work. I tried various different inputs and I finally found one that visually, was "good enough". The input was -3 degrees.
          Can you take a look and let me know if there is a better number and if I there should be some relationship that can always be used to figure out what angle to use?
          Even if not, this saves just a ton of time as is and it is quite adequate for this job too! Thank so much.
          SpiralStairRail.skp
          Susan Sorger
          Former Seller Hand Rendered Entourage
          Former Canadian Authorized Training Centre, SketchUp
          • W Offline
            wikii
            Another script still in development can do followme and keep the profile from rolling.
            Left part of the first image is followme ,right part is follow_me_and_keep .
            In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
              sorgesu
              Fantastic! Can't wait.
              Susan Sorger
                šŸ‘
                Sounds fantastic! That would be something needed so long!
                • E Offline
                  Ecuadorian
                  Follow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
                  Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here:
                  404 Not Found
                  (www.crai.archi.fr)
                  The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis.
                  -Miguel Lescano
                  • N Offline
                    notareal
                    A must have tool!
                    • boofredlayB Offline
                      boofredlay
                      I am looking forward to it.
                      • E Offline
                        Ecuadorian
                        Until follow_me_and_keep is ready (which will save all these following steps), here's a workaround:
                        • Go to Camera > Standard Views > Left
                        • Draw your profile within the plane formed by the positive blue and green axis, touching the origin.
                        • Erase the face leaving the lines, and make it a component.
                        • Select your profile (it must be a curve or a polygon, if it isn't, first join the edges with the join tool by Rick Wilson in the SCF Power Toolbar).
                        • Use the "copy along distance" button on the SCF Power Toolbar (also a script by Rick Wilson) and play with the distance until you're satisfied.
                        • Select all instances of the component and explode them. You can use Rick Wilson's script "select all instances": http://www.smustard.com/script/Instances
                        • Click on the "configuration" button of the "Skin" script by Darrel to "By order". Leave the other options blank.
                        • Execute the "skin" command and keep pressing "Enter" like crazy until the full object is done.
                        • Add soften/smooth edges to your taste.
                        You can download the "skin" script from this post:
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin&start=105#p101209
                        And you can browse the rest of that thread for the latest version of skin.rb, too, if you want...
                        Yeah, it's a lot of extra work, that's why all await for follow_me_and_keep.
                        -Miguel Lescano
                        • david_hD Offline
                          david_h
                          This is pretty fun to play with.
                            ada123
                            it's really nice
                            • SwissmountainS Offline
                              Swissmountain
                              Thanks for this awesome script! šŸ‘
                              Cogito ergo dum-di-dum
                                tamfore
                                is there a link for a text file or description and instructions on what this plugin does and how to use it?
                                thanks
                                Tamfore
                                  thanks
                                  Tamfore
                                  Select welded edges as path and a face before using this script.
                                    kostas_designer
                                    Cool!...
                                    Jeff: i think you are talking about the SCF POWERBAR:
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar#p112024
                                      ayieartwork
                                      guys.how to rotate the shape from bigger to smaller?
                                      Intel Core i7-3930k with 16gb G.Skill Ripjaws
                                      • brookefoxB Offline
                                        brookefox
                                        I unzip to plugins; get FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb, which I must rename as I have a larger file of that name already (I put far.skp elsewhere). No plugins result in my pull down. I rename them *.rb and still nothing. Any tips?
                                        ~ Brooke
                                          you must keep names *.rbs!
                                            brookefox
                                            OK, thanks, though they did not work that way ---> It dawned on me belatedly that I needed to provide for the re-naming or not of inbox.rb: if I rename it then I guess I need to go through the code and replace the old name with the new name wherever it occurs.
                                            ~ Brooke
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 5 / 11
