    Render this: Stained glass
    66 Posts 27 Posters 27.5k Views 27 Watching
      MrWip
      Trillium, if you take a closer look to the post, it was not done with Atl, but with indigo, an unbiased render.
      Artlantis does not take the glass thickness in consideration, but you can play with the index of refraction of the shader itself, and change is nature (airs, glass, plastic...). That should affect the resulting shadows...
      http://www.wip-archi.com
        bubbalove
        Here is my half-ass attempt. I could've continued to get better results but I got lazy and quit trying. It was done in Kerky...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • E Offline
          Eulgrand
          Rendered in Kerkythea
          Preset 20 - MLT (BPT), 30 passes.
          Noise removed with NeatImage
          Lit by the sun and an HDR global.
          Just added some procedural Perlin noise as bump map, on an image grabbed on the net. The glass has 5mm thickness, IoR 1.52
            MrWip
            Well done Eulgrand, the scene is missing some materials to me, but the glass is just what it should be. The bump effect create a perfect bad quality glass effect, and the caustics works well.
            I've also give it a try on my scene with Kerky, but with a biased solution and the result was not convincing, so good that you gave your settings, It helps !
            • honoluludesktopH Offline
              honoluludesktop
              MrWip, (I like that) Any chance of posting your skp so that we can play with it? The design reminds me of a deconstructed(?) FLW design:-)
                MrWip
                Guys, good idea to share it, I will post it... but I just realize that I forgot the file on my office computer so we have to wait till monday 😳 ....
                I will prepare it with different layers, presenting different variation (thickness, type of image, etc...), so we can all refer to the related scenes when we post a render and explain a technic.
                • daleD Offline
                  dale
                  A first Attempt building on an earlier stained glass piece. Modeled the door windows after Charles Rennie Macintosh's original windows for the Glasgow School of Art. Tried to give it a moonlit ambience for a change. Rendered in Kerkythea, preset 12. Hope I have time to play with it some more.
                    Looks promising, Dale. The coloured light spots and even caustics look cool though I have to say that I find the glass (window) itself a bit "dull".
                    Also, some (very faint) volumetric light would really enhance this image - I know Kerky can do it.
                    All in all, I like it a lot (and all the other contributions - it's very useful, too IMO).
                    • daleD Offline
                      dale
                      Thanks Gaieus I tend to agree. At first I liked the moodiness, but I think the glass need more attention. I hope to get some time to fool around with it some more. I'm still really new to this, and each challenge teaches me a lot, both with what others do,and the settings they discuss.
                        d12dozr
                        My first attempt...I'm a rendering noob, and I tried IDX Renditioner Express and Podium, but couldn't get the light cast from the window to be colored. This is with IRender nXt. I really like the edge highlighting setting. It needs a lot more tuning...any tweaking suggestions?
                        Sketchup + IRender nXt, no post-processing
                        http://goo.gl/f7ooYh
                          @dale said:
                          Thanks Gaieus I tend to agree. At first I liked the moodiness, but I think the glass need more attention...
                          I might suspect that in fact there's nothing outside that would "liven up" that glass. Did you solely use the sun for lighting and no other geometry to reflect outside? If so,maybe an intensive hdri background could do the job.
                          Well, to me it still looks much better than anything I could do. 👍
                          • arail1A Offline
                            arail1
                            I especially like the 'watery' quality of the light coming through Eulgrand's window. It makes me think there are trees outside, moving in the wind and the reflections on the wall are in motion. Very convincing to my eye.
                            • david57D Offline
                              david57
                              BubbaLove has the best one. Its Excellent.
                              • EscapeArtistE Offline
                                EscapeArtist
                                Wow, there are some excellent renders here. I better get to work!
                                  MrWip
                                  Your render is charming d12dozr, IRender give good result on this kind of effect (by the way, maybe you should just add some more segment on the round opening...)
                                  Here is my sketchup files, if people want to give it a try!
                                  Stained_Glass_Challenge.zip
                                  • daleD Offline
                                    dale
                                    Well I figured Macintosh would probably have made the woodwork white, so I changed this and used an HDRI sky, and a little exposure and Gamma tweak. Still Kerlythea
                                    • E Offline
                                      Eulgrand
                                      Thanks Arail1. That's right, there's a global with trees outside. Thte "watery" effect is due to the procedural Perlin noise in the bump channel.
                                      I attach my KT material. Hope this helps.
                                      Vitrail.mat.zip
                                      • soloS Offline
                                        http://img36.imageshack.us/img36/4527/stainglasschallenge100.jpg
                                          dylan
                                          There is some great looking stained glass here.
                                          Is it possible to get this coloured light coming through using Podium?
                                          http://dmdarchitecture.co.uk/
                                            trillium
                                            hi MrWip, thank you for sharing your fabolous model! how did you generate all the individual pieces of glass from the original image? did you trace each piece in Sketchup? or is there an easier way to do that? thanks again!!!
                                            • 2 / 4
