    [Plugin] Extended Views v1.2 UPDATE May 23, 2013
    80 Posts 40 Posters 138.3k Views 40 Watching
      Matt666
      hi Chris!
      Great addition, thank you!
      Just one thing, it would be cool to add an icon which toggle perspective?
      Frenglish at its best !
      My scripts
      • CadFatherC
        CadFather
        in fact i already have them integrated into my new standard toolbar (in place of)
        Chris, if it's ok with you i'll post it for all to enjoy
          Sorry Pilou and any other SU6/5 devotees!
          No problem, I have free 6 & 7 โ˜€
          But I don't see the video? Where is it? ๐Ÿ˜ฎ
          • Chris FullmerC
            Sorry, no video yet. And probably not anything much new from me for the next few days. I'm graduating tomorrow and my parents are in town - hooray!. So I am sort of out of commission.
            CadFatther, that would be fine to include it in your toolbar. I am planning on updating it though in a week or two. So you might have to update your version after that.
            • utilerU
              utiler
              Congratulations Chris!!! ๐ŸŽ‰ Nice time to be surrounded by the people that matter...
              Just Curious...
              • CadFatherC
                CadFather
                well done Chris - thanks.. and congratulations!
                • utilerU
                  utiler
                  Chris, have you got any ideas on the post I made a few weeks ago...?
                  Extract:
                  *Chris, another great plug-in....!
                  I have often wondered for sometime if another view somewhere between Wireframe and Shaded could be developed..... Quite often i have wanted to export a view to Layout in black and white with only edges showing. the problem is I'd like it to appear as a line drawing only, no faces that covers other linework on the page.... something like wireframe but without the internal linework!!!
                  What do you think?*
                  Cheers, look forward to hearing your ideas... ๐Ÿ‘ Love your work!!!
                  Just Curious...
                  • Chris FullmerC
                    Try this on one of your models and tell me how close it is to what you are thinking of.
                    Load the style I attached here. Then go to your shadow settings and turn the light and dark sliders both to 100% and turn on "Use Sun for Shading". You might also put the sun at noon-ish just to make sure it is bright.
                    Does that begin to get at what your thinking of?
                    black_oultine.style
                    • utilerU
                      utiler
                      Thanks Chris, not realy what i was thinking about....
                      This is what your style gives me.
                      What I was thinking was a style that only showed visible edges but with no faces. Like I said, a wireframe type of style where there were not faces visible but also only visible edges...
                      The real benefit of such a style is in Layout where imported images overlapping would appeap more blended or seemless...
                      Just Curious...
                      • Chris FullmerC
                        That is odd, there are quite a few things about that picture that aren't quite representative of how the style was working on my machine - but I was using very simple models. Any chance I could test it out on that model and see if I can get it to do what I had in mind?
                        • utilerU
                          utiler
                          Sure, Chris. PM me your email address and I'll send it to you....
                          Just Curious...
                          • free agentF
                            free agent
                            Hi Chris
                            im having a problem with this script, if i try to undo a set of actions where i had used ur extended views in it, i get a very annoying little box with construction points being "unbuilt" as i go through the undos, its like your script uses it to align the axis and u havnt got the script group (or whatevr you ruby guys call it) where it can undo with a single undo, then i tried to just open a blank page, draw a quick block then hit T (for top view), then try to undo the block, then u see the construction points ๐Ÿ˜ž and way to make ur script undoable with one undo, or have it not feature in the undo list at all
                            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                              AlexMozg
                              Hi Chris
                              im having a problem with this script...
                              use my version ๐Ÿ˜„
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=19323
                              ...it does not have this failing.
                              And my version is more complete.
                              • Chris FullmerC
                                Heh, yeah sorry. I apparently forgot to make it not have an undo show up. I'll fix that.
                                But you might be best off just to use Alex's script. It is more complete. I wrote mine before he had published his. didn't know he also had a similar script in progress.
                                • JClementsJ
                                  JClements
                                  Hi Chris:
                                  Not sure if the following is as designed or something related to changes in 7.1.
                                  If, for example, I click on the Top View icon, the the camera is oriented properly; however, it zooms to the model extents rather than the current display as is the case with SU's native View Toolbar.
                                  My work around is to preselect geometry in the display, use Extended Standard Views, then zoom to the selection extents.
                                  I like that you found a way to use the User Defined Axis. Do you think other scripts could utilize your code, such as Todd's Nudge script?
                                  • Chris FullmerC
                                    Hi John, I'll have to look into the zoom extents vs. zoom current context. THat indeed was an issue while testing 7.1, so perhaps their fix messed up ruby script methods. I'll try to look at it today.
                                    And yes, and script could implement the ability to use the user defined axis, but it only works in SU 7.0 and higher. 6.0 does not support it. And it is a bit of a hack. It would be nicer if they built a true method into ruby to access the user defined axis. But yes, it could be incorporated into plugins for sure, like nudge.
                                    • JClementsJ
                                      JClements
                                      Thanks, Chris.
                                      • simon le bonS
                                        simon le bon
                                        Hi Chris, Hi everybody,
                                        EDIT: Confirmed, it doesn't work with version 4,5,6 or earlier. Just version 7. Sorry Pilou and any other SU6/5 devotees!
                                        (Am I SU6 devotee ? Not sure. I just still use it mainly. Why? May be because I'm not found of the actual way of SketchUp development.)
                                        Thank you ++ for this new plugin!! I don't need it for I'm still with Su6, but I Keep it in mind for future.
                                        ... Also, how to you embed Jing videos in the forum????? I've been trying to forever!
                                        Cool to mention my How can i attach a Flash (Swf) video to my posts
                                        but You can better follow this simpler way by Ecuadorian.
                                        Easy way to embed Youtube video in SketchUcation that I mentioned at the end of the thread.. ๐Ÿ‘ ๐Ÿ‘
                                        ๐Ÿ˜‰ simon
                                        • E
                                          ermethic
                                          Any way of making the standard views also force a Parallel Projection switch to the camera ? I've been looking everywhere for a plugin that would do that, but i haven't found anywhere.
                                          Thank you very much in advance...
                                            It's easiest enough to add a shortcut key combo to toggle between parallel and perspective camera settings. That way the tools suit everyone and pressing a key to change from one format or the other is no great hardship ๐Ÿ˜•
                                            • 3 / 4
