    [Plugin] cgScenesMAC v 2 April 2010
    40 Posts 11 Posters 102.3k Views 11 Watching
    • chrisglasierC Offline
      chrisglasier
      @edson said:
      @chrisglasier said:
      i am sorry, but it remains obscure to me. perhaps the video would clear it up. have you tried to host your video somewhere else like vimeo or blip.tv?
      I have tried many - all fail - Vimeo after waiting 6 hours!
      I have to go to dinner now, but simply if you select a scene in the left column, it opens that scene; if you select Layers in the middle column, it shows you the scene's layers and their visibility status in the third; if you select Components in the middle, it shows the scene's components in the third; the same for styles ...
      The menus at the top enable you to toggle things on and off, add, erase and so on as in the SU windows. In other words it does nothing new, it just does it without you having to open and/or move from window to window. The information comes to you. More of your model is left exposed.
      Really thanks, you know when so deep into something it is sometimes difficult to put things across. I hope this is a bit better!
      My regards
      • EdsonE Offline
        Edson
        chris,
        this is much better. i'll have a go at it soon. thanks.
        http://www.mahfuz.arq.br
          Downloaded to have a look at this. I see now that it's some kind of organizer window that takes on the roles of the many individual SU windows and merge functionality into one. Am I correct?
          I got an error message when I tried it though. When I activated the tool in a model with no scenes I got this:
            chrisglasier
            [attachment=0:kxsxxkug]<!-- ia0 -->error.png<!-- ia0 -->[/attachment:kxsxxkug]
            Sorry it should open an alert. For the moment please just add a new scene before opening the plugin. Better still download the 5.7 mb test model from here so you can see how it handles (inshala) several scenes, layers, components and styles. Blank applications can be dead boring!
            Sorry for teething problems ...
              tomasz
              To run the script successfully one needs to add
              require 'sketchup.rb'
              at the start of the code.
              I am testing it Chris right now. It looks interesting.
              Toggling items could be done by double click also. It would improve layer\component sets editing speed.
              Tomasz
                tomasz
                Now if we could have groups of scenes. What I mean - a higher level in hierarchy, above scenes alone.
                If a user could move\copy a scene from one group to another it would be great.
                In the given SU example the Groups could be called Perspectives, Elevations, Plans, Sections.
                EDIT: There is a tricky thing I realized. Some plugins may attach attributes to scenes, so you would need to copy\move them too.
                Tomasz
                  chrisglasier
                  I have added it for the next release. If I remember correctly it is more precaution than necessity so the current code should work without it. But I am a reluctant coder particularly where Ruby is concerned, when I do little more than lip-sync. Any straightening out recommendations are well received.
                  Indeed. But please remember I am trying to make this a device module that can be added to the core nameset. I use some core minimalist panel and event handling conventions for overall control. I have avoided double click so far because I have been sceptical how it performs on handheld devices - a single stab or poke seems safer.
                  But I become more aware of things like editing speed as I am finishing the little house model. Yesterday I changed the top menu to be right aligned, directly above the main (3rd) clicking list, which is more natural. You will be able to move the white stripe closer (but this means more clicks for upward scrolling).
                  [BTW did you see the window is resizable (to help determine the compromise between screen obstruction and long names)?]
                  Yes, higher level groups are the real challenge not just for scenes but also components. Not to be confused with SU groups, I categorise these as collections and groupings, collections that define the physical aspects of the project (buildings, floors, spaces, products) and groupings that are less influenced by final positioning that may relate to scheduling (sanitaryware), buying (purchase orders), distribution, containerisation, sustainability (to jump on the band wagon), colour boards, regulations (fire), operating (diagrams) and so on.
                  Two important points are that one component can belong to many groups and all collecting and grouping is computed outside modeling; and one important question is: can components be used in lieu of SU groups to the point of extinction - what do you think?
                  Thanks for your interest and help
                    chrisglasier
                    Just to keep things updated :
                    cgScenes R1.01 (basic config).zip
                    Release 1.01 includes the following amendments:
                    Added sketchup.rb (thanks to Tomasz SCF)
                    Added scene setup for new files
                    Right aligned menu for easier toggling
                    Rename layer function
                    Excluded Layer0
                    cg
                    • Chris FullmerC Offline
                      Hi Chris, you can organize it however you want, but most authors update the file in the original post so that people don't have to read through an entire thread to make sure they are downloading the most recent vesion.
                      Also, I think you started another thread where you posted this new version already. It might be adviseble to delete it from this thread, and just put a link to that thread from here, and also in the top post. And also, again, remove the old file from the top post. That way you only have one file - always the most current - posted somewhere. Otherwise it can be confusing for users to try and fin the most recent version.
                      But, you can do it however you like. Just in the end, try to make it so users can't accidentally find old versions of your scripts.
                      Keep up the great work! I can begin to finally understand namesets in the context of layers, scenes, styles, etc and how all these things are connected and all affect the same objects. Little by little it is coming together.
                      BTW, have you looked at Google Wave yet? It is interesting!
                        Jim
                        @chrisglasier said:
                        " I asked Jim to be put cgScenes on the register so I can just refer to it there for the releases and continue my mumblings here in the usual fashion. Do you think that would be OK?
                        Sorry about this, Chris. I hope, in not very much longer that you will be able to enter and edit your entries yourself. I'm talking a couple of days, if you can wait...
                          chrisglasier
                          @chris fullmer said:
                          Hi Chris, you can organize it however you want ...
                          No, I don't want to take that line, but I just thought as this thread has [code] in the title it should also get the latest version. The other post is a background piece, but of course it needed to have the updated version to make sense. To save the "on and on," I asked Jim if cgScenes could be put on the register so I can just refer to it there for the releases and continue my mumblings here in the usual fashion. Do you think that would be OK?
                          .. how all these things are connected and all affect the same objects.
                          Yes and this underpins "linking data" that Kevin Kelly and others keep raving on about.
                          I can only imagine right now - youtube has been blocked here, but I am planning to look elsewhere soon
                            jmmad
                            Hi Chris
                            looks a really useful plugin.
                            I downloaded version 1.3
                            But I don't know how to install it please give me a hint
                            Thxs
                            Get Upa !
                              chrisglasier
                              If you have a PC extract zip file to your plugs-in folder. Suggest you use model Test file (downloadable from web site). Open Sketchup. Look in plugins menu for cgScenes.
                              We are still working on Mac version.
                                chrisglasier
                                I put release 1.04 in the first post. You can also download it from the Namesets web site (Output section).
                                  Thanks for the update, Chris.
                                  Could I ask a favor? Would you please edit the thread title to reflect the current version and revision date? That would make it easier for folks to know there's been a change to the plugin.
                                  Thanks again.
                                  Dave
                                    chrisglasier
                                    Would you be so kind as to put cgScenes on manually now I have released 1.04(PC)? Do you need any info from me? Thanks.
                                      Jim
                                      My apologies, cgScenes is now in the Index.
                                        chrisglasier
                                        No apologises necessary. We should all be just grateful for your generosity. Many thanks.
                                          chrisglasier
                                          cgScenes R1.05 added to first post
                                          cg
                                            chrisglasier
                                            Release R 1.051 added to first post. (Amendment to layerAdd tool - not shown in Tutorial)
