    Quick tutorial for road design on a terrain
    36 Posts 9 Posters 18.6k Views 9 Watching
    • soloS
      That's the thing, like I mentioned in another thread relating to this, you need to divide the terrain to a point where it's smooth before even attempting anything road-wise.
      For anything really accurate and useable for construction or even client visualisation I would seriously urge you to look beyond SU, SU just does not have the 'balls' for this kind of work. I would recommend Geocontrol 2 and Vue for this. Here is a link to how it can be achieved with Geocontrol 2 (it's a road tutorial), after which you can either continue working with the terrain in Geo or move it into Vue for finishing.
      ERROR: The request could not be satisfied
      (www.cajomi.de)
      • charly2008C
        charly2008
        Hi Chris, hi Pete,
        thanks for your detailed advices. I will try it with the terrain reshaper and consuming some cups of
        coffee.
        Another question is how to get a less triangulated mesh out from Vue. Maybe that would be the way for future to start with less triangulated Terrains. I have spent some time for work with VUE. Geocontrol seems to be a nice tool.
        Karlheinz
        • soloS
          Karl
          Select the terrain in Vue then go to your file drop down menu and select 'export object', a new dialogue will appear which will give you a mesh quality slider, the lower the slider the less detailed/triangulation, the highest will probably kill SU.
          • charly2008C
            charly2008
            Hi Pete,
            i had a look at the Geocontrol tutorial and it seems not bad and relativly simple to use. I have downloaded the trial version to carry out some tests according to that video. From Geocontrol i exported a wave object file with a project size of 128, then imported the file into Vue and exported a 3ds file. The file size in Sketchup is now reasonable. It seems to be a promising solution. To have a similar tool inside Sketchup would be very nice. It should be possible somehow to develop something like that also for Sketchup in anyway.
            Karlheinz
            Test Road.zip
            • charly2008C
              charly2008
              Hi to All,
              in the second test, the road looks fine in Geocontrol. But the exported road doesn't look exactly the same in Sketchup. May be anyone has an Idea how to improve the road in Sketchup.
              Karlheinz
              Test Road.zip
              • charly2008C
                charly2008
                Summary:
                Up till now I have not found any satisfactory possibility for the construction of roads in Sketchup. Road design within Geocontrol is done simply and shows satisfactory results. The Terrain was exported as an .obj file and changed to an 3ds file which is Sketchup able to import. To have good view of the road in the triangulated terrain in Sketchup it is neccessary to import it as a high resolution terrain.
                The biggest size which Sketchup was able to load is the terrain shown below. The difficulty is that the road doesn't have a sharp borderline as shown in Geocontrol.
                I'm not shure if it is possible to create smooth borderlines because for the road also we have only triangles.
                I will devote again myself to other more pleasant work. May be in the future somebody has a brainwave.
                Karlheinz
                • soloS
                  Karl
                  That looks great, good work.
                  Is this for a particular project/client? is the road asphalt/concrete? and i assume you would need stone barriers too right?
                  I would suggest making the road using a profile in GC, extracting the vector road seperate and the profile seperate, taking them into Vue and exporting them seperately then overlaying them as components in SU that way you will have clear control over them. However it will probably cripple you unless you work with strict layering (but that may not be enough once you start texturing)
                  Or, work the entire project in Vue or GC.
                  • charly2008C
                    charly2008
                    Hi Pete,
                    it is not a particulare project it is only for fun. I try to find only a comfortable workflow for road design that can be used within Sketchup. With GC i did only some first steps. I don't know how to make a profile in GC and to export them separately. Up till now I have exported only an obj file from GC. In the use of Vue i'm also a beginner. It seems to me that you have some experience with GC. Your method sounds promising but I comprehend not yet completely the steps. Perhaps I can soothe my frustration again. Would you be so kind to give me a rough description of the steps within GC.
                    Karlheinz
                    • soloS
                      Actually Karl, Pilou may be onto something here, the 'tools on surface' ruby will be good to trace the shape of the road in SU and from there you can pull up the barriers as needed, will be a lot easier than my idea above.
                      • GaieusG
                        What I'd do here is to soften the whole terrain first and then drape the road lines in their place. It wouldn't add further geometry but simply unsoften the two sides of the oad.
                        Now from then on, you can use TOS to offset and Joint PushPull to erect side barriers, copy along path to distribute road side posts or what you call them or anything for a road.
                        • charly2008C
                          charly2008
                          Pete, Csaba, Pilou,
                          please can you show me an example how you would do this on the Test Road.skp above.
                          Karlheinz
                          • GaieusG
                            For that, I'd need the mesh as it is now AND the road that you integrated in that other app (which I don't know) separately imported into SU.
                            Can you rip the road only, somehow like Pete suggested above? It would be a long, thin strip this way.
                              In theory you can draw your road with "Tools on surface" by Fredo6 on top view
                              Just hide or separate some useless reliefs around the road for have a speedy calculate
                              • charly2008C
                                charly2008
                                Hi Csaba,
                                the road was generated with Geocontrol (GC). The workflow is as follows:
                                1. Generation of a terrain
                                2. Drawing the road direction by a Vector tool on a 2D height shaded view
                                3. Road will be generated by GC automatically
                                4. Export terrain as a Wavefront object (.obj).
                                5. Changing the obj file into a 3ds file using Vue or Cinema 4D
                                6. Import of the triangulated mesh (3DS file) into Sketchup.
                                At present i can't see any way to separate the terrain mesh from the Vector road. It is exported as one triangulated mesh.
                                Karlheinz
                                GC
                                GC
                                GC
                                Sketchup mesh
                                • GaieusG
                                  Hm. I see. Too bad actually. The other option would be to soften the whole surface, turn on hidden geometry and unsoften the bordering edges of the road manually (Shift+Ctrl+Eraser tool) but certainly that's a whole lot of tedious,manual work although can be done at the weekends while one's wife is knitting beside)
                                  • charly2008C
                                    charly2008
                                    Hi csaba,
                                    i agree with you, but i'm a Lazy dog.
                                    Karlheinz
                                      abuyaas
                                      thanks man ı am sorry for may poorıng english
                                        Macker
                                        Just dragging this topic up again.
                                        Being unfamilliar with the "follow me & keep" tool, could someone please explain how to use it? I get absolutely nonsense results when I use it.
                                        Check out my blog @ http://macviz.blogspot.co.uk
                                        • charly2008C
                                          charly2008
                                          Hi Macker,
                                          create a line and the end a Profile, in this case a rectangle. Select the lines including the rectangle and choose follow me and keep.
                                          Karlheinz
                                          Followme and keep.skp
                                          • majidM
                                            majid
                                            dear mate, I was not deeply contribute in this tut, but now I take a look and see that there is a gpa this between taht makes me not to understand it: After unfolding the road sextion, "how do y make it curvy again?" plz
                                            • 2 / 2
