    Quick tutorial for road design on a terrain
    36 Posts 9 Posters 17.5k Views 9 Watching
      For that, I'd need the mesh as it is now AND the road that you integrated in that other app (which I don't know) separately imported into SU.
      Can you rip the road only, somehow like Pete suggested above? It would be a long, thin strip this way.
        In theory you can draw your road with "Tools on surface" by Fredo6 on top view
        Just hide or separate some useless reliefs around the road for have a speedy calculate
        • charly2008C Offline
          charly2008
          Hi Csaba,
          the road was generated with Geocontrol (GC). The workflow is as follows:
          1. Generation of a terrain
          2. Drawing the road direction by a Vector tool on a 2D height shaded view
          3. Road will be generated by GC automatically
          4. Export terrain as a Wavefront object (.obj).
          5. Changing the obj file into a 3ds file using Vue or Cinema 4D
          6. Import of the triangulated mesh (3DS file) into Sketchup.
          At present i can't see any way to separate the terrain mesh from the Vector road. It is exported as one triangulated mesh.
          Karlheinz
          GC
          GC
          GC
          Sketchup mesh
            Hm. I see. Too bad actually. The other option would be to soften the whole surface, turn on hidden geometry and unsoften the bordering edges of the road manually (Shift+Ctrl+Eraser tool) but certainly that's a whole lot of tedious,manual work although can be done at the weekends while one's wife is knitting beside)
              charly2008
              Hi csaba,
              i agree with you, but i'm a Lazy dog.
              Karlheinz
                abuyaas
                thanks man ı am sorry for may poorıng english
                  Macker
                  Just dragging this topic up again.
                  Being unfamilliar with the "follow me & keep" tool, could someone please explain how to use it? I get absolutely nonsense results when I use it.
                  Check out my blog @ http://macviz.blogspot.co.uk
                    charly2008
                    Hi Macker,
                    create a line and the end a Profile, in this case a rectangle. Select the lines including the rectangle and choose follow me and keep.
                    Karlheinz
                    Followme and keep.skp
                    • majidM Offline
                      majid
                      dear mate, I was not deeply contribute in this tut, but now I take a look and see that there is a gpa this between taht makes me not to understand it: After unfolding the road sextion, "how do y make it curvy again?" plz
                        charly2008
                        Hi Majid,
                        for shape bender, you need the road direction line from the first step. This i forget to mention.
                        Sorry that i answered a little late.
                        Karlheinz
                        • 2 / 2
