    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 193.0k Views 88 Watching
    • gillesG Offline
      gilles
      @driven, there is a very good plugin to screw profile or shape named "screw1_5.rb or screw_21.rb I prefer the first one".
      However @ Chris I can say I enjoy your plugins as much I enjoy Fredo's, but this doesn't want to run on my mac. โ“
      undefined method select_tool' for nil:NilClassError Loading File clf_simple_loft_loader.rb undefined method select_tool' for nil:NilClass
      • david_hD Offline
        david_h
        fun little tool. Thanks again Chris.
          MrPlanet
          Just to let you know, this plugin creates an empty group in every model, it may seem small, but SketchyPhysics (By Chris Phillips) Simply refuses to work with it.
          I reject your reality and substitute my own.
          • Chris FullmerC Offline
            Oh really? Oops. I'll try to make sure to get that fixed on the next round. I must be forgetting to delete a group somewhere in the mix. Thanks for pointing it out!
              saimen
              wow that's exactly what I need ๐Ÿ˜‰
                Chris, I've been playing with your Loft plugin and Driven's screw thread file. When I first opened his file I was able to create his threads by selecting two curves at a time and using 1 for the number of segments. I tried it by selecting all six curves and got a Bug Splat. I reopened the file and cut the curves down to a quarter turn thinking I'd give it fewer faces to create. Here's the results. In the background you can see a test loft with two 12-segment arcs and five loft segments.
                All six curves selected. One segment chosen in dialog box
                Bottom four curves, one segment.
                Top two curves, one segment
                The guidepoints are interesting but not quite what I expected.
                  That means it is crashing for some reason. Normally to do with the selection including a non-edge item, or also if the segment counts don't match. I'm not sure which. You can upload the model immediately before that point and show me which lines to click on and I'll figure out what it is.
                  Hopefully the next version wll clean some of that up.
                    Here you go Chris. I hope it helps.
                    thread_bez_loft[1].skp
                    • N Offline
                      nomeradona
                      wow thanks a million...
                      • EscapeArtistE Offline
                        EscapeArtist
                        Hey Chris, I just started having some trouble with this plugin. Maybe you can decipher what I'm doing wrong; I know the plugin works so it must be something that I'm doing. Here's the console output:
                        Error; #<NoMethodError; undefined method `all_connected' for nil;NilClass>
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;61;in `onLButtonUp'
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186
                        Error; #<ArgumentError; Cannot convert argument to Sketchup;;Point3d>
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;189;in `add_cpoint'
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;189;in `end_handles'
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186;in `each_index'
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186;in `end_handles'
                        L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;94;in `onReturn'
                        I'm applying the plugin to 3 bezier curves, the plugin generates construction points and then stops.
                          EscapeArtist
                          ...onLButtonUp...
                          line=60  best = ph.best_picked
                          line=61  all_best = best.all_connected
                          line=62  @shapes_edges << best.all_connected
                          It's failing to find anything you have selected when you release the mouse-button... Are you picking anything ? It falls over since 'best' = 'nil' and nil can't have connected edges...
                          Chris: before 'all_best = ' you could test for 'best' and re-run the main functions if it's nil, e.g.
                          if not best
                            ### run me again ###
                            return nil
                          end#if
                            EscapeArtist
                            Yep, absolutely picking something. I know the plugin works because I drew two other curves and tested it, the loft worked just fine; so it must be a problem with the curve set I was initially using. Maybe it doesn't work on curves that were part of a face. I had to draw faces to get the curves to lay flat on specific axes and then deleted the faces, leaving the curves behind. I'm probably missing knowledge about a change that happens to edges that were part of a face and how it affects the plugin.
                            edit:
                            Solved:
                            That was the problem, edges/curves that were part of a face will not loft. I worked around the problem by grouping the planes, exiting the group, and then drawing the curves on the faces. The lines went where I wanted and the integrity of the curve was preserved in order for loft to work.
                              publied
                              Chris,
                              a smart substitute of the old curve stitcher! they spare my time. thank you!
                              hire me@ http://www.publied.it !
                                No possibility to automate the clicks of curves? ๐Ÿ˜‰
                                the 10 curves are made with the Grow plug by Tig
                                So I've been thinking about this, and what if I made it so that holding down the mouse button (click and drag) would add lines in the order you cross over them. You can let go and then re-click and drag to add more splines to the selection set. I think that would do the trick. Then just hit enter once you've selected all the splines you want to use.
                                Would that be a good solution?
                                  Marvelous ๐Ÿ‘
                                  The only problem for you is the order of the curves ๐Ÿ˜‰
                                  image of the original post
                                  http://forums.sketchucation.com/download/file.php?id=27140
                                    No, the order of the curves becomes the users problem to figure out. It will all depend on how you click and drag over the splines. ๐Ÿ˜‰
                                      So Chris you got to the point to quote yourself. I've only seen this from elderly politicians so far. ๐Ÿ˜ฒ
                                        I wasn't quoting myself, I was re-explaining myself ๐Ÿ˜„
                                          Daniel S
                                          Each spline must have the same amount of segments and with Fredoยดs Bezier plugin itยดs easy to create this (has an option for Precision: total number of segments of the generated curve).
                                          I just try this option with Loft alpha and:
                                          Itยดs great combination of plugins.
                                          Daniel S
                                            Wow, that's pretty impressive! I do have a working version I'm testing that works with splines with different segment counts, but it won't be released for a while I'm sure. So thanks for posting that great work-around!
                                            That's a pretty cool model too!
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
