    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 216.4k Views 88 Watching
    • Chris FullmerC
      I know I have not explained the inner workings of the script very well yet, but its partly because the next version changes some things, or exposes a a little more of how it works. So its not quite worth going into detail yet when its about to change (a little).
      But....the loft might exactly the right tool for something like what he wants. Especially the next version. It has the ability to control the strength of the curvy-ness that is being given to each bezier connection. So instead of really trying to be curvy, you can minimize that a little and make it mostly flat, but rounding just the areas closest to the splines.
      This is why the script is designed to actually run through every given spline, and not use the splines as "handles". It gives more accuracy this way because you CAN control where it runs - directly through each spline. And with the next addition of being able to control the strength of the beziers, its pretty handy.
      All that being said, I don't prefer to use lofting tools that much. I'd probably just use my bend script or one of the follow me and keeps. They are all good alternatives, especially while this script is still so difficult to use.
      (I've been debugging my next version of the script most of today with limited success 😞 )
        driven
        cheers Chris and thanks for the comments August,
        it works, exploded the curves and it's a one click job, fantastic
        @august said:
        I wish I could point you to the non-twisting Follow-Me plugins
        I've been searching, but the advantages of this is I have a lot of control over the bezier profile and path (thanks to Fredo) and a simple rig made with xformclone.rb, so skinning between only distorts the additional sections I add at both ends, which trim square with an intersect with a plane, then it's just 'movecopy' X times...
        A good tool is a good tool regardless of it's original perceived use...
        thanks again chris
        ADDED: it did this in one go, not just for drapes.... took 10 mins but no crash, this time.
        Added More: Spoke to soon, this is in the components window, it seems to have locked while writing the thumbs, having completed the drawing, I'm in and out at moment so will give it time and see if it recovers, out of curiosity..
        quick test
        from this lot
        do bugs look like this?
        • gillesG
          gilles
          @driven, there is a very good plugin to screw profile or shape named "screw1_5.rb or screw_21.rb I prefer the first one".
          However @ Chris I can say I enjoy your plugins as much I enjoy Fredo's, but this doesn't want to run on my mac. ❓
          undefined method select_tool' for nil:NilClassError Loading File clf_simple_loft_loader.rb undefined method select_tool' for nil:NilClass
          • david_hD
            david_h
            fun little tool. Thanks again Chris.
              MrPlanet
              Just to let you know, this plugin creates an empty group in every model, it may seem small, but SketchyPhysics (By Chris Phillips) Simply refuses to work with it.
              I reject your reality and substitute my own.
              • Chris FullmerC
                Oh really? Oops. I'll try to make sure to get that fixed on the next round. I must be forgetting to delete a group somewhere in the mix. Thanks for pointing it out!
                  saimen
                  wow that's exactly what I need πŸ˜‰
                    Chris, I've been playing with your Loft plugin and Driven's screw thread file. When I first opened his file I was able to create his threads by selecting two curves at a time and using 1 for the number of segments. I tried it by selecting all six curves and got a Bug Splat. I reopened the file and cut the curves down to a quarter turn thinking I'd give it fewer faces to create. Here's the results. In the background you can see a test loft with two 12-segment arcs and five loft segments.
                    All six curves selected. One segment chosen in dialog box
                    Bottom four curves, one segment.
                    Top two curves, one segment
                    The guidepoints are interesting but not quite what I expected.
                    • Chris FullmerC
                      That means it is crashing for some reason. Normally to do with the selection including a non-edge item, or also if the segment counts don't match. I'm not sure which. You can upload the model immediately before that point and show me which lines to click on and I'll figure out what it is.
                      Hopefully the next version wll clean some of that up.
                        Here you go Chris. I hope it helps.
                        thread_bez_loft[1].skp
                        • N
                          nomeradona
                          wow thanks a million...
                          • EscapeArtistE
                            EscapeArtist
                            Hey Chris, I just started having some trouble with this plugin. Maybe you can decipher what I'm doing wrong; I know the plugin works so it must be something that I'm doing. Here's the console output:
                            Error; #<NoMethodError; undefined method `all_connected' for nil;NilClass>
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;61;in `onLButtonUp'
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186
                            Error; #<ArgumentError; Cannot convert argument to Sketchup;;Point3d>
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;189;in `add_cpoint'
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;189;in `end_handles'
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186;in `each_index'
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;186;in `end_handles'
                            L;/Modeling/Sketchup Google/Plugins/clf_simple_loft/clf_simple_loft.rb;94;in `onReturn'
                            I'm applying the plugin to 3 bezier curves, the plugin generates construction points and then stops.
                              EscapeArtist
                              ...onLButtonUp...
                              line=60  best = ph.best_picked
                              line=61  all_best = best.all_connected
                              line=62  @shapes_edges << best.all_connected
                              It's failing to find anything you have selected when you release the mouse-button... Are you picking anything ? It falls over since 'best' = 'nil' and nil can't have connected edges...
                              Chris: before 'all_best = ' you could test for 'best' and re-run the main functions if it's nil, e.g.
                              if not best
                                ### run me again ###
                                return nil
                              end#if
                              • EscapeArtistE
                                EscapeArtist
                                Yep, absolutely picking something. I know the plugin works because I drew two other curves and tested it, the loft worked just fine; so it must be a problem with the curve set I was initially using. Maybe it doesn't work on curves that were part of a face. I had to draw faces to get the curves to lay flat on specific axes and then deleted the faces, leaving the curves behind. I'm probably missing knowledge about a change that happens to edges that were part of a face and how it affects the plugin.
                                edit:
                                Solved:
                                That was the problem, edges/curves that were part of a face will not loft. I worked around the problem by grouping the planes, exiting the group, and then drawing the curves on the faces. The lines went where I wanted and the integrity of the curve was preserved in order for loft to work.
                                • P
                                  publied
                                  Chris,
                                  a smart substitute of the old curve stitcher! they spare my time. thank you!
                                  hire me@ http://www.publied.it !
                                  • Chris FullmerC
                                    No possibility to automate the clicks of curves? πŸ˜‰
                                    the 10 curves are made with the Grow plug by Tig
                                    So I've been thinking about this, and what if I made it so that holding down the mouse button (click and drag) would add lines in the order you cross over them. You can let go and then re-click and drag to add more splines to the selection set. I think that would do the trick. Then just hit enter once you've selected all the splines you want to use.
                                    Would that be a good solution?
                                      Marvelous πŸ‘
                                      The only problem for you is the order of the curves πŸ˜‰
                                      image of the original post
                                      http://forums.sketchucation.com/download/file.php?id=27140
                                      • Chris FullmerC
                                        No, the order of the curves becomes the users problem to figure out. It will all depend on how you click and drag over the splines. πŸ˜‰
                                        • GaieusG
                                          So Chris you got to the point to quote yourself. I've only seen this from elderly politicians so far. 😲
                                          • Chris FullmerC
                                            I wasn't quoting myself, I was re-explaining myself πŸ˜„
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
