    I need help...
    20 Posts 12 Posters 1.5k Views 12 Watching
      You want to try working with SketchUp, AutoCAD AND Revit all in the same day !!!
      When you are used to using keyboard shortcuts it's a continuing problem...
      M=Move, M+space_OR_enter= Move, MM=Move...... Why won't AutoCAD or Revit go to 'Move' when I press the M key ??? Some seconds later = Duh!
      etc etc
      I often use ctrl+M to copy !!! without success...
      Not to mention when I also regularly write Ruby, AutoLisp/VB and VB/Revit_API it gets even worse - it's like speaking several different languages [reasonably well] but forgetting which country you are in... far too often !!! πŸ˜„ πŸ˜• πŸ˜’
        That's the packages we use at work. I'm a modelmaker and illustrator, so my main tool is SU. AutoCAD and Revit always makes me scream "why isn't this working?!?".
        Apart from 3D modelling and SU ruby scripting I do websites on the side; PHP, JS, HTML, CSS (ok, not all are 'scripting' languages, but still)
        Web programming is what I did first; now I don't do it as much. But after using Ruby quite a lot lately I something find myself stuck when I write in JS or PHP.
        I'm a Norwegian, lived in UK for four years; lots of friends there. Use the internet allot in English and at the office the language runs in Norwegian, English & German due to a number of Germans employed. Juggling the correct language to the correct people when things get hectic isn't always an easy task...
          And you are not even in the EU. Imagine what would be going on then! πŸ˜„
          • jeff hammondJ Offline
            @thomthom said:
            ...I just tried to orbit inside Notepad++ while writing a ruby... ...even tried it twice... Not sure what I expected, but I'm sure if it did actually work; it'd be awesome!
            ...what? πŸ˜•
            sometimes we just want to read like this πŸ˜„
            [flash=425,344:j9bvj0fj]http://www.youtube.com/v/ukpPh-dcbqI&hl=en&fs=1[/flash:j9bvj0fj]
              Physicsguy1
              I think i have tried to orbit in a text field. My addiction to SU has drastically distorted my actions and the like. I sometimes, unbelievably, LOOK for the geometry on common objects. I somehow think that everything i see consists of faces. I even find myself telling my friends to "Turn on hidden geometry!" to help them find their "hidden" object(it's a pun, but it shows how much SU is affecting myself). Hopefully I will break this habit soon...
                linea
                I have the same affliction, I can look at a real world building and realise that almost subconsciously I'm seeing the wireframe or thinking about how it breaks down into faces. I also have a tendency to stand on construction sites and push pull them into completion in my mind. Kill me now.
                  BTM
                  I'm not that bad yet. Once though, I thought that an objet I was seeing was moving slow because it was too high poly for... well... existence I guess... πŸ˜•
                    Physicsguy1
                    I remember seeing something(i think it was a car?), and i thought it would lag when it accelerated. I also start to look around my environment to see if i can find some glitch, like a single face object. I can't believe that I assume that something has a one sided face. I'm going crazy...
                      remus
                      occasionally i see a strange lighting effect and almost immediately think 'rendering error' before promptly slapping myself back in to reality.
                        Physicsguy1
                        This is really affecting me. I just visited a web page and noticed a single link. I reached out and poked it in an attempt to navigate to the web page. I just poked my desktop screen! I can't believe I did that.
                        • EscapeArtistE Offline
                          EscapeArtist
                          Ah, the curse of the 3d modeler when thrown back into the real world! LOL.
                          After using SU for a full day I try to use my MMB to tilt my screen so I can see further down the web page without scrolling.
