    What to call a high quality image
    20 Posts 15 Posters 1.4k Views 15 Watching
      museummaker
      You might want to play around with google suggest feature, I believe they are in order of how frequently people search.
      • Al HartA Offline
        Al Hart
        Thats part of what I am after. If I type in a phrase Google give me more suggestions. But I want to start with something not including Rendering.
        For Instance, SketchUp Rendering gives these ideas:
        (In order of search count)
        maxwell render sketchup
        vray sketchup render
        sketchup render plugin
        free sketchup render
        google sketchup render
        rendering for sketchup
        google sketchup rendering
        render in sketchup
        I tried for a list based on "SketchUp realism", but it didn't come up with any actual searches which looked promising. Two of the top ones with the word SketchUp in them were "SketchUp crack" and "SketchUp model", neither of which seemed relevant.
        free sketchup rendering
        Al Hart
        IRender nXt from Render Plus
        • Chris FullmerC Offline
          Here's what merriam-Webster says about "render"
          "to reproduce or represent by artistic or verbal means"
          We use it to talk about hand drawn images all the time too. In my mind it has always just meant to create an image with an emphasis on taking it into the beautiful/artistic realm (but never including the "High Arts").
          When I think about computer rendering, I often jump automatically to phototreal rendering though. So I often don't think of SU as making renders by default. Not until something beyond the basic output of SU happens.
          I don't think that helped at all....
          • DanielD Offline
            Daniel
            To me, a rendering is any image that has shades, shadows, and textures applied, regardless of whether it is hand drawn, SU output, or one of the photorealistic rendering engines. It can be 3D or 2D (as in a rendered elevation). To me, a high quality rendering has nothing to do with photorealism, but whether or not the image is clean and crisp.
            What else to call them? I've heard people use the terms image and picture. Or they will just refer to the format (jpeg or pdf). Another term that comes to my mind would be scene. Or, what about illustration?
            My avatar is an anachronism.
              Or what about Tom's (tomsdesk's) "water colour" pieces (just to avoid the terms "image" or "picture"). You cannot even call them "crisp" or "clean" (in the everyday meaning of these words) but calling them "not high quality" or "not renders" is also a mistake.
              Just another way of expressing things.
              • jeff hammondJ Offline
                i think the question isn't really about the definition of rendering or wether or not that name should be change. for one, i highly doubt the name will be change and i don't think it needs to change.
                the problem is, people will see a rendering but not know what it's called or what to search for when they want to find out which software or techniques are used to create 3D renderings. (and the same problem is likely to occur no matter what the name would be)
                so imagine you're new to the game, just saw a nice rendering and would like to learn how to make something like it yourself.. what are you going to type into the browser's search field?
                in my case, i would use variations of 'real' which along with google suggestions leads me very quickly to podium, kerkythea, artlantis, and vray.. from there, i'd come across the word rendering and investigate further..
                • honoluludesktopH Offline
                  honoluludesktop
                  Traditionally, a Architectural render was a presentation quality image that portrayed your project. Before computers, the Architect would put down his drafting tools, pick up watercolors, colored pencils, or use not for production techniques to "render" a design. In this context, a modeled, ray-traced, bumped mapped, textured, and "photoshopped" image is a rendering.
                  To my knowledge, the terms are still used that way in schools of Architecture.
                  • Al HartA Offline
                    Al Hart
                    You hit the nail on the head. I have been calling the process "rendering" for so long that I have no idea what some who does not use that term might call the process. I will add the word "Realistic" to my search optimization. It turns out that Google sees Photorealistic and a very different term then Photo-Realistic when it comes to searching for just Realistic. (Realistic does not find Photorealistic, but does find Photo-realistic)
                    Al Hart
                      Phil Rader AIA
                      Illustration
                      Visualization
                      3d Drawing
                      http://www.philrader.com
                      • Al HartA Offline
                        Al Hart
                        Illustration
                        Visualization
                        These two were good. Google used them to suggest:
                        SketchUp illustrator
                        as well.
                        Al Hart
                          tomsdesk
                          image export enhancer
                          2.5D Trees & Shrubs!
                            To a layman 'rendering' can be something you do to song OR plaster/cement on a wall OR what you do to fat/dead-animals OR something you do to terrorist prisoners OR an image...
                            If it's a 'high quality image' why not call it just that ? There's no ambiguity...
                            • pbacotP Offline
                              Because that doesn't say what it is. Depends on what you want. An outline term for a proposal of architectural services would be "architectural renderings" regardless of other uses of the word. No one would know what you are offering with "high quality images". If you want to be specific you can also say "photo-realistic perspective views" although MOST such offerings do not qualify as "high quality images". I totally disagree. If I offered high quality images to a developer that'd sound like hype and i could give them anything and say "looks like high quality to me!"
                                But 'photo-realistic images' might mean something more to them than to you ? Why not try 'computer generated images' - then show examples of varying levels of complexity... and the can choose from 'simple' through to 'deluxe' - the cost varies with the effort and quality...
                                • Alan FraserA Offline
                                  Alan Fraser
                                  Photorealistic render. The fact that it's qualified as photorealistic precludes it meaning boiling a whale down for oil...or any of the other possibilities.
                                  I wouldn't use illustration. Being an illustrator by profession, it usually has the connotation of being hand drawn, but it gets a little weird...a book can be 'illustrated' with illustrations or photos.
                                  3D Figures
                                  • Mike LuceyM Offline
                                    Mike Lucey
                                    REAL IMAGE!
                                    REAL VIEW!
                                    REAL PHOTO!
                                    PHOTO IMAGE!
                                    PHOTO VIEW!
                                    REALISTIC VIEW!
                                    REALISTIC VIEWS?
                                    COMPUTER GENERATED REALISTIC VIEWS?
