    [Plugin] Extended Views v1.2 UPDATE May 23, 2013
    80 Posts 40 Posters 136.3k Views 40 Watching
      remus
      BTM, have a read through this: http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=10103&st=0&sk=t&sd=a&hilit=video
        Ah, Standard View as they should be. πŸ˜„
        • Chris FullmerC Offline
          Yeah, really! If only this fixed SU's inabilty to easily print to scale from a non standard view.
          • free agentF Offline
            free agent
            chris for PRES! i always wanted SU to align to my new axis, wow thanks
            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            • X Offline
              xymox
              thank alot chris..
              a little question, would it be possible
              to add "custom" points of views ?
              something like self configure able points of view (Camera positions)?
              hope it gets clear, what i mean.. πŸ˜’
              respect!
                @xymox said:
                thank alot chris..
                respect!
                Wouldn't you just set up Scenes for that?
                  jlsz
                  thanks for the plugin Chris
                  its Views as they should be
                  just one question is it possible to make a button to toggle between perspective view and parallel projection? So you dont need to go throgh the menu all the time.
                  that would be so nice.
                  Thanks in advance!
                    Thanks in advance!
                    You could assign a keyboard shortcut for that if you use it that often.
                      I do 'shift+P'...
                      • kenK Offline
                        ken
                        Will I downloaded Jing to record what was happening. However, the problem seems to have been an aberration. Right now I cannot get it to repeat.
                        It was a major slow down.It would take the ISO view over ten seconds to respond. I wasn’t modeling, just using a small model for testing. Maybe something else was going on. Will keep Jing in the standby mode.
                        Thanks for your quick reply.
                        Ken
                          Jim
                          Very cool, Chris... hey while you're at it, how about adding the 3 other ISO views - SW, NW, & NE?
                            BTM
                            ... Even better, do what it does in sketchup; find the ISO view closest to the orientation of the camera. πŸ˜‰
                              AlexMozg
                              I develop the large complex of plugins ArchTools.
                              But while not all is ready for a publication.
                              And I wrote a similar plugin also.
                              But while did not find how to avoid improper work of plugin in more early versions of Sketchup.
                              I publish my variant of script, because I think the best version of my script.
                              (Includes Iso Auto, Iso SW, Iso SE, Iso NE, Iso NW)
                              It is the cut out part from my complex of plugins.
                              Unfortunately without icons.
                              Extended Standard Views(ArchTools version)
                                Thats much cleaner code for determining the axes and setting the cameras Alex. I don't if you'll get as many people seeing it burried here deep inside this thread. You should make its own [Plugin] thread for it so people can find it easier! Or maybe wait until you add icons I guess if you'd like? Either way, it might just get lost here.
                                Great plugin though πŸ˜„
                                • utilerU Offline
                                  utiler
                                  Chris, another great plug-in....!
                                  I have often wondered for sometime if another view somewhere between Wireframe and Shaded could be developed..... Quite often i have wanted to export a view to Layout in black and white with only edges showing. the problem is I'd like it to appear as a line drawing only, no faces that covers other linework on the page.... something like wireframe but without the internal linework!!!
                                  What do you think?
                                  Just Curious...
                                  • utilerU Offline
                                    utiler
                                    Great Plug in Chris!!!
                                    which made me think of an idea i had a while back about another standard view somewhere between wireframe and shaded view.
                                    From time to time i want to export a view to Layout in Black and white with only edges showing... the problem is with shaded view the faces interfere with linework. I also know that we can re-arrange line work visually by hierarchy but still the problem applies...
                                    What I'd like to see is a wireframe mode without the internal linework. Say a wireframe, profiles only mode... it would work especially well with plans as ground surfaces would not display which helps with dimensioning, notation, etc in SU ...
                                    What do you think?
                                    Just Curious...
                                      AlexMozg
                                      Chris, I will make icons and will correct my version of plugin in the near time.
                                      • CadFatherC Offline
                                        CadFather
                                        Chris, had a play with this - fantastic -Thank You
                                          Matt666
                                          hi Chris!
                                          Great addition, thank you!
                                          Just one thing, it would be cool to add an icon which toggle perspective?
                                          Frenglish at its best !
                                          My scripts
                                            CadFather
                                            in fact i already have them integrated into my new standard toolbar (in place of)
                                            Chris, if it's ok with you i'll post it for all to enjoy
                                            • 2 / 4
