[Plugin] Point v1.2
Hi, cool plugin, you done a great job! If there a posible to put arow keys on blue, red , green axes like pen tool does?
Cher Matt!
Bravo pour cet outil!
I agree completely with Gaieus: a seemingly "little" tool that we forget that we need all the time.
How could we do without this tool ??
[flash=550,412:2xppaall]http://www.youtube.com/v/aEBrzJscSP0&hl=fr&fs=1[/flash:2xppaall]
But at the end we need to erase all those construction points!!!
No problem! Just use the so powerful Matt666's Selection Manager
And dear Matt I'm sure you will not be angry about me if i complete the panoply with those daily other useful tools:
Jim Foltz's Construction Line Tool
Jim Foltz's Arc Centerpoint
Todd Burch's CenterPoint
Didier Bur's fr_lines_converterSimon
Have a problem loading: see attachment.
ditto
looks very useful too... anyone know how to make this mac compatible?
@ Bones : Hi ! I will give a try... Not sure I can do that...
@ Jeff Hammond & Bob James : Ok, thank you for that! I have asked to Fredo6 (because his compatibility between Win & Mac is great), so be patient please!
@ simon le bon ... Bah didon belle présentation !! Merci à toi Thank you for this great presentation!! -
Obviously useful
MALAISE
Thank you Pierre!
A new version 1.2 is available... Try to fix Mac problems. -
Merci!
it's working nicely now on my mac.
btw, i think the provided icon is too small.. it's 16x16 but SU can use 24x24 as well..@simon le bon said:
No problem! Just use the so powerful Matt666's Selection Manageranother option is edit->delete guides.. not as powerful as selection manager but it will get rid of the points as well.
I found this plugin great.
But it could be excelent if after you inferrenced the distance with another object you could tape /# of spaces and add constructions points. Sort of dividing a line in 2,3,4.... spaces.
Is it possible to add this request ?Thanks
agrazdi
Matthieu, thank you
great addition for making of general plans -
Thank you!
agrazdi, I will see what I can do! -
Hi NewOne,
Your icons are NumberOne
But when i try to use them (32x32), their quality isn't at the "rendez-vous" . Why? I can't say.simon
@simon le bon said:
Hi NewOne,
simonWell... This is what I do now: try to figure out why on image viewer and on forum page the icon looks nice, but in Sketchup is a little messed up.
QUESTION: how many colors does sketchup accept for icons? true color, 256, or less? -
Sketchup Toolbar icons are 24x24, or 16x16 for the small icons. Tool cursors are 32x32.
THANK YOU !!
I tested with 24x24 and it looks wonderfull. -
--EDITED POST-- changed the files, and added code suggestion.
Alternate icons for PointTool
Matt666, if you like this icons, please edit your script to use 24x24px and 16x16px icons.The changes I made to your script to accept those icons and cursor icon are:
cmd.large_icon = File.join(p, "PointTool", "PointTool24x24.png") cmd.small_icon = File.join(p, "PointTool", "PointTool16x16.png")
and
def initialize #...your previous code p=Sketchup.find_support_file("Plugins") pointTool_cursor_path = File.join(p, "PointTool", "PointTool cursor.png") @@pointTool_cursor = UI;;create_cursor(pointTool_cursor_path, 3, 30) end def onSetCursor UI;;set_cursor(@@pointTool_cursor) end
I am not sure if this is entirely correct, but it works for me.
If you decide to change the icons, pay attention on hotspot coordinates of the cursor
Suggestion: add getExtents method to avoid disappearance of the OpenGL line.def getExtents bbox = Geom;;BoundingBox.new bbox.add @ip1.position if (@state == 0) bbox.add @ip.position if (@ip.valid? && @ip.display?) elsif bbox.add @ip2.position end bbox end
P.S. I like your script very much, it ease my work a lot! It's a simple, but strong idea!
contains 16x16, 24x24 and 32x32 PNG
The Blue Icon, because Simon Le Bon loved it...
for making the script to show cursor, see this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=13077&st=0&sk=t&sd=a&start=15#p184325
Hi NewOne,
Thank for it (the blue pen) . Now adopted
simon -
Dear Matt,
I have downloaded your version 1.2, but cannot work out how to draw a single point other than hitting the Esc key. What should I do?
Kind regards,
Bob
