    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 24.5k Views 5 Watching
      @thomthom said:
      Does Mac also have the issue with the open Outliner? It's not specific to the way Windows redraws stuff?
      Don't know - are there any Mac users out there getting BugSplats with the Outliner being open during script runs that affect groups/instances ???
      Any Mac users doing 'send_action' - please try to open/close the Outliner and try Sketchup.send_action(21513) etc and report back...
      It would be good to have extended common 'send_actions' for both PC and Mac - I know that some 'numerical' ones don't work on Mac...
        I have an old Mac Mini at home I can test the send_actions on.
        Not sure if it's reliable to test the Outliner issue due to it's age and lack of power...
          Thanks - Scott's taking his time coming back... I suspect it's not going to be straight forward...
            Matt666
            I reported this Mac bug here... I hope outliner test will be positive...
            Frenglish at its best !
            My scripts
              v1.3 is here http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
              IT has an unneeded initial 'require ...' removed: otherwise it's unchanged...
                Matt666
                Hi TIG.
                I start to play with your cool function!
                Just one bug for the moment, line 139. group.definition, and no definition function for groups.
                I think you didn't copy the function in the script... πŸ˜‰
                class Sketchup;;Group
                	def definition
                		return self.entities[0].parent
                My scripts
                  Matt = thanks for pointing this out - I had 'group.definition' load from a separate ruby - that I hadn't posted...
                  I've now added it to this file for the avoidance of doubt...
                  v1.4 now here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                  Being able to get a group's definition is very useful in many other cases...
                  • H Offline
                    HPW
                    So now we have this great addition to the toolset, what is the best way of delivery?
                    The file gets copied into the Plugins-Directory.
                    What should our own installer should do?
                    Check the existence of the file and install it if not present?
                    Check date and install it if a newer version is available?
                    Can the ruby-code check if the method is installed?
                    If not use a copy installed in the own subfolder?
                      Your own installer should check the existence of the file and install it if not present, BUT also check any existing file's modification-date and install if you have a newer version.
                      Yes to all, this is the best way for all plugins...
                        AlexMozg
                        Method 'group.definition'....
                        More correct would be the code:
                           def definition
                              self.entities.parent
                        Because, when group is empty
                        there is an error at the use of code: self.entities[0.parent]
                        The group may be empty soon after its inception.
                        For example:
                        group = Sketchup.active_model.active_entities.add_group
                        definition = group.definition
                        Request to replace a code on more correct, because I use this method in the developments.
                          Following AlexM's point I have adjusted to code to avoid empty group errors...
                          v1.5 is now here... http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                            An oversight has been corrected...
                            v1.6 all definition.behavior(s) now fully copied across. 20090702 download it from... http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                            • H Offline
                              HPW
                              I run into a problem when I use add_entities from a startup-ruby.
                              The code line:
                              @kombi_group_sel_def.instances[0].add_entities(@kombi_group_list)
                              throws an error : undefined method `parent' for nil:NilClass
                              My ruby (zAutostart.rb) loads after the ComponentInstance-add_entities.rb
                              When I disable the call in my ruby and start the command from the console it runs without problems.
                                Are you sure you have an instance of that definition in your model?
                                • H Offline
                                  HPW
                                  Yes, because when I outcomment my call and type it in the console after start-complete it works.
                                  Therefor I build just a workaround:
                                   wsh = WIN32OLE.new('Wscript.Shell')
                                   if wsh.AppActivate(skpbasename+".skp - SketchUp")
                                    sleep(1)
                                    wsh.SendKeys('{F2}')
                                    sleep(1)
                                    wsh.SendKeys('convert_acad_import{ENTER}')
                                  Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
                                    Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
                                    • H Offline
                                      HPW
                                      Cannot be true, because the error come from inside the add_entities-code.
                                      Otherwise the error would tell about unknown method.
                                        Maybe things aren't ready immediately when SU loads the plugins...
                                        Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?
                                          require 'toggleWindows.rb' ?
                                          • H Offline
                                            HPW
                                            I tried a 'sleep' with some diferent values without any success.
                                            I had it yet for closing the outliner.
                                            With my workaround it is working fine now.
                                            (Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.)
                                            • 2 / 2
