    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 25.3k Views 5 Watching
      @thomthom said:
      I have an old Mac Mini at home I can test the send_actions on.
      Not sure if it's reliable to test the Outliner issue due to it's age and lack of power...
      Thanks - Scott's taking his time coming back... I suspect it's not going to be straight forward...
        Matt666
        I reported this Mac bug here... I hope outliner test will be positive...
        Frenglish at its best !
        My scripts
          v1.3 is here http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
          IT has an unneeded initial 'require ...' removed: otherwise it's unchanged...
            Matt666
            Hi TIG.
            I start to play with your cool function!
            Just one bug for the moment, line 139. group.definition, and no definition function for groups.
            I think you didn't copy the function in the script... πŸ˜‰
            class Sketchup;;Group
            	def definition
            		return self.entities[0].parent
            My scripts
              Matt = thanks for pointing this out - I had 'group.definition' load from a separate ruby - that I hadn't posted...
              I've now added it to this file for the avoidance of doubt...
              v1.4 now here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
              Being able to get a group's definition is very useful in many other cases...
              • H Offline
                HPW
                So now we have this great addition to the toolset, what is the best way of delivery?
                The file gets copied into the Plugins-Directory.
                What should our own installer should do?
                Check the existence of the file and install it if not present?
                Check date and install it if a newer version is available?
                Can the ruby-code check if the method is installed?
                If not use a copy installed in the own subfolder?
                  Your own installer should check the existence of the file and install it if not present, BUT also check any existing file's modification-date and install if you have a newer version.
                  Yes to all, this is the best way for all plugins...
                    AlexMozg
                    Method 'group.definition'....
                    More correct would be the code:
                       def definition
                          self.entities.parent
                    Because, when group is empty
                    there is an error at the use of code: self.entities[0.parent]
                    The group may be empty soon after its inception.
                    For example:
                    group = Sketchup.active_model.active_entities.add_group
                    definition = group.definition
                    Request to replace a code on more correct, because I use this method in the developments.
                      Following AlexM's point I have adjusted to code to avoid empty group errors...
                      v1.5 is now here... http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                        An oversight has been corrected...
                        v1.6 all definition.behavior(s) now fully copied across. 20090702 download it from... http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                        • H Offline
                          HPW
                          I run into a problem when I use add_entities from a startup-ruby.
                          The code line:
                          @kombi_group_sel_def.instances[0].add_entities(@kombi_group_list)
                          throws an error : undefined method `parent' for nil:NilClass
                          My ruby (zAutostart.rb) loads after the ComponentInstance-add_entities.rb
                          When I disable the call in my ruby and start the command from the console it runs without problems.
                            Are you sure you have an instance of that definition in your model?
                            • H Offline
                              HPW
                              Yes, because when I outcomment my call and type it in the console after start-complete it works.
                              Therefor I build just a workaround:
                               wsh = WIN32OLE.new('Wscript.Shell')
                               if wsh.AppActivate(skpbasename+".skp - SketchUp")
                                sleep(1)
                                wsh.SendKeys('{F2}')
                                sleep(1)
                                wsh.SendKeys('convert_acad_import{ENTER}')
                              Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
                                Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
                                • H Offline
                                  HPW
                                  Cannot be true, because the error come from inside the add_entities-code.
                                  Otherwise the error would tell about unknown method.
                                    Maybe things aren't ready immediately when SU loads the plugins...
                                    Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?
                                      require 'toggleWindows.rb' ?
                                      • H Offline
                                        HPW
                                        I tried a 'sleep' with some diferent values without any success.
                                        I had it yet for closing the outliner.
                                        With my workaround it is working fine now.
                                        (Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.)
                                          sleep prevents everything else to process. If you use a timer you allow the rest to continue processing.
                                            v1.7 is now available - now any Attribute Dictionaries the Definition might have are kept when the Definition is reworked with the new entities...
