    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 26.7k Views 5 Watching
      Matt666
      Hi TIG.
      I start to play with your cool function!
      Just one bug for the moment, line 139. group.definition, and no definition function for groups.
      I think you didn't copy the function in the script... πŸ˜‰
      class Sketchup;;Group
      	def definition
      		return self.entities[0].parent
      Frenglish at its best !
      My scripts
        Matt = thanks for pointing this out - I had 'group.definition' load from a separate ruby - that I hadn't posted...
        I've now added it to this file for the avoidance of doubt...
        v1.4 now here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
        Being able to get a group's definition is very useful in many other cases...
        • H
          HPW
          So now we have this great addition to the toolset, what is the best way of delivery?
          The file gets copied into the Plugins-Directory.
          What should our own installer should do?
          Check the existence of the file and install it if not present?
          Check date and install it if a newer version is available?
          Can the ruby-code check if the method is installed?
          If not use a copy installed in the own subfolder?
            Your own installer should check the existence of the file and install it if not present, BUT also check any existing file's modification-date and install if you have a newer version.
            Yes to all, this is the best way for all plugins...
              AlexMozg
              Method 'group.definition'....
              More correct would be the code:
                 def definition
                    self.entities.parent
              Because, when group is empty
              there is an error at the use of code: self.entities[0.parent]
              The group may be empty soon after its inception.
              For example:
              group = Sketchup.active_model.active_entities.add_group
              definition = group.definition
              Request to replace a code on more correct, because I use this method in the developments.
                Following AlexM's point I have adjusted to code to avoid empty group errors...
                v1.5 is now here... http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                  An oversight has been corrected...
                  v1.6 all definition.behavior(s) now fully copied across. 20090702 download it from... http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                  • H
                    HPW
                    I run into a problem when I use add_entities from a startup-ruby.
                    The code line:
                    @kombi_group_sel_def.instances[0].add_entities(@kombi_group_list)
                    throws an error : undefined method `parent' for nil:NilClass
                    My ruby (zAutostart.rb) loads after the ComponentInstance-add_entities.rb
                    When I disable the call in my ruby and start the command from the console it runs without problems.
                      Are you sure you have an instance of that definition in your model?
                      • H
                        HPW
                        Yes, because when I outcomment my call and type it in the console after start-complete it works.
                        Therefor I build just a workaround:
                         wsh = WIN32OLE.new('Wscript.Shell')
                         if wsh.AppActivate(skpbasename+".skp - SketchUp")
                          sleep(1)
                          wsh.SendKeys('{F2}')
                          sleep(1)
                          wsh.SendKeys('convert_acad_import{ENTER}')
                        Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
                          Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
                          • H
                            HPW
                            Cannot be true, because the error come from inside the add_entities-code.
                            Otherwise the error would tell about unknown method.
                              Maybe things aren't ready immediately when SU loads the plugins...
                              Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?
                                require 'toggleWindows.rb' ?
                                • H
                                  HPW
                                  I tried a 'sleep' with some diferent values without any success.
                                  I had it yet for closing the outliner.
                                  With my workaround it is working fine now.
                                  (Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.)
                                    sleep prevents everything else to process. If you use a timer you allow the rest to continue processing.
                                      v1.7 is now available - now any Attribute Dictionaries the Definition might have are kept when the Definition is reworked with the new entities...
                                      • H
                                        HPW
                                        Using 1.7 instead of 1.6 gives me this error:
                                        convert_acad_import
                                        Error: #<NoMethodError: C:/Programme/Google/Google SketchUp 7/Plugins/ComponentInstance-add_entities17.rb:188:in add_entities': undefined method each' for nil:NilClass>
                                          I've check it out...
                                          School boy error ! Now fixed with v1.8...
                                          • H
                                            HPW
                                            Thanks for the quick fix.
                                            Working correctly again!
                                            • 2 / 2
