    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 26.7k Views 5 Watching
      Version 1.1
      It can sometimes BugSplat if the Outliner window is open when it runs...
      so it can now be forced to rollup first - using Jim's code ideas - you'll need
      'toggleWindows.rb' and 'Win32API.so' - sorry it's for Windows only - Mac users ???
      If you are on a PC and don't install toggleWindows.rb/Win32API.so then it'll still work
      BUT please close the Outliner to avoid BugSplats !
      Version 1.1 20090401
      AT-ComponentDefinition-delete.rb version used.
      Recursive version now keeps layer/material.
      Possible Outliner window rollup added.
      You should download the following files:
      ComponentInstance-add_entities.rb
      AT-ComponentDefinition-delete.rb [ http://www.sketchucation.com/forums/scf/viewtopic.php?p=145255#p145255 ]
      for PC users the zip file contains 'toggleWindows.rb' and 'Win32API.so'...
      They are added to the first page in this thread...[ http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009 ]
        Version 1.2 is here [ http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009 ]
        It now has the 'definition.delete' code built-in as that is now greatly simplified thanks to AlexM's insights...
        I'm awaiting Scott's feedback on cross-platform Sketchup.send_action(21513) etc - I don't think they are Mac friendly... However if they are we can make the v1.1 Outliner crash work-around for PC and Mac...
          Does Mac also have the issue with the open Outliner? It's not specific to the way Windows redraws stuff?
            Don't know - are there any Mac users out there getting BugSplats with the Outliner being open during script runs that affect groups/instances ???
            Any Mac users doing 'send_action' - please try to open/close the Outliner and try Sketchup.send_action(21513) etc and report back...
            It would be good to have extended common 'send_actions' for both PC and Mac - I know that some 'numerical' ones don't work on Mac...
              I have an old Mac Mini at home I can test the send_actions on.
              Not sure if it's reliable to test the Outliner issue due to it's age and lack of power...
                Thanks - Scott's taking his time coming back... I suspect it's not going to be straight forward...
                  Matt666
                  I reported this Mac bug here... I hope outliner test will be positive...
                  Frenglish at its best !
                  My scripts
                    v1.3 is here http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                    IT has an unneeded initial 'require ...' removed: otherwise it's unchanged...
                      Matt666
                      Hi TIG.
                      I start to play with your cool function!
                      Just one bug for the moment, line 139. group.definition, and no definition function for groups.
                      I think you didn't copy the function in the script... πŸ˜‰
                      class Sketchup;;Group
                      	def definition
                      		return self.entities[0].parent
                      My scripts
                        Matt = thanks for pointing this out - I had 'group.definition' load from a separate ruby - that I hadn't posted...
                        I've now added it to this file for the avoidance of doubt...
                        v1.4 now here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                        Being able to get a group's definition is very useful in many other cases...
                        • H
                          HPW
                          So now we have this great addition to the toolset, what is the best way of delivery?
                          The file gets copied into the Plugins-Directory.
                          What should our own installer should do?
                          Check the existence of the file and install it if not present?
                          Check date and install it if a newer version is available?
                          Can the ruby-code check if the method is installed?
                          If not use a copy installed in the own subfolder?
                            Your own installer should check the existence of the file and install it if not present, BUT also check any existing file's modification-date and install if you have a newer version.
                            Yes to all, this is the best way for all plugins...
                              AlexMozg
                              Method 'group.definition'....
                              More correct would be the code:
                                 def definition
                                    self.entities.parent
                              Because, when group is empty
                              there is an error at the use of code: self.entities[0.parent]
                              The group may be empty soon after its inception.
                              For example:
                              group = Sketchup.active_model.active_entities.add_group
                              definition = group.definition
                              Request to replace a code on more correct, because I use this method in the developments.
                                Following AlexM's point I have adjusted to code to avoid empty group errors...
                                v1.5 is now here... http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
                                  An oversight has been corrected...
                                  v1.6 all definition.behavior(s) now fully copied across. 20090702 download it from... http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                                  • H
                                    HPW
                                    I run into a problem when I use add_entities from a startup-ruby.
                                    The code line:
                                    @kombi_group_sel_def.instances[0].add_entities(@kombi_group_list)
                                    throws an error : undefined method `parent' for nil:NilClass
                                    My ruby (zAutostart.rb) loads after the ComponentInstance-add_entities.rb
                                    When I disable the call in my ruby and start the command from the console it runs without problems.
                                      Are you sure you have an instance of that definition in your model?
                                      • H
                                        HPW
                                        Yes, because when I outcomment my call and type it in the console after start-complete it works.
                                        Therefor I build just a workaround:
                                         wsh = WIN32OLE.new('Wscript.Shell')
                                         if wsh.AppActivate(skpbasename+".skp - SketchUp")
                                          sleep(1)
                                          wsh.SendKeys('{F2}')
                                          sleep(1)
                                          wsh.SendKeys('convert_acad_import{ENTER}')
                                        Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
                                          Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
                                          • H
                                            HPW
                                            Cannot be true, because the error come from inside the add_entities-code.
                                            Otherwise the error would tell about unknown method.
