    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      Matt666
      Just construction points? You can try native Su tool! GO to Edit menu / Delete guides.
      You can also copy this code below in the ruby console... It will delete all construction points in the selection.
      Sketchup.active_model.selection.each{|e|e.erase! if e.class==Sketchup;;ConstructionPoint}
      πŸ˜‰
      Frenglish at its best !
      My scripts
        Matt666
        Hi Fredo!
        I suppose you will move your menus in "Fredo collection" in your next TOS update, like freescale plugin ? ❓
        That would be cool, and also your push pull plugin!
        Sans titre 1.jpgExcellent plugin, as always, sir! πŸ˜„ Thank you...
        My scripts
        • simon le bonS Offline
          simon le bon
          πŸ™‚ Matt,
          --/ Hope i'm not going too far from this thread /--
          good tip: it is something I had forgotten.. > but the construction lines and points, they are all deleted from the overall model. Something we want not to be each time.
          @matt666 said:
          You can also copy this code below () in the ruby console... It will delete all construction points in the selection.
          This is just the good code: construction lines remain and every construction point inside selection are removed. Would you please make it as a .rb dear Matt? (I'm complet ignorant upon this ). It would be so greatfull!
          :-)simon
          • N Offline
            Nathryc
            Thank you, Thank you, Thank you, Fredo!!!! (insert Happy Dance Here!)
            At last I can do what I've been trying to do since I first found SketchUp (modeling planets for exterior sci-fi scenes)
            This plug-in is MADE of 100% AWESOME!
            Nathryc
              Roger
              You are the Gustave Eiffel and Pierre Bezier of SketchUp. Merci Beaucoup from the USA!
              What will you do to top this achievement?
              http://www.azcreative.com
                Kus
                Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up
                no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb
                I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
                what should I do??[/quote]
                • fredo6F Offline
                  @kus said:
                  Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up.
                  what should I do??
                  Kus,
                  Seems you had a problem with the unzip operation.
                  For Tools on Surface you must have only 2 elements in the Sketchup Plugins folder:
                  • a small file: ZLoader_OnSurface.rb
                  • a folder: TOS_Dir_13, with other rb files in it (and some subfolders).
                  I suggest you check your files and redo the Unzip, with a Select All and then Extract, to make sure your preserve the folder hierarchy when unzipping.
                    Steelyjoe_n
                    Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
                      Steelyjoe_n
                      Nevermind
                      I forgot to check it in preferences, thank you for the program anyway πŸ˜„)
                      • N Offline
                        niarfe
                        Fredo!!! I'm becoming your biggest fan!!!
                        thanks a lot!
                          monkeybss
                          I seem to have a problem too. I can see the toolbar but the offset doesn't work (Su7,7.0.102470), the line-on surface does, but nothing else seems to work.
                          I'm not familiar with ruby, but it feels like some setting might be wrong (like a variable in Autocad).
                          Later..
                          Just being stupid, I forgot to load in "preferences". Works like a charm!
                            Arthaxx
                            • H Offline
                              hitman47127
                              thanksssssssssss a lot, 😍 😍 😍
                              • E Offline
                                Efrado
                                Hi FREDO ,Thanks a lot for this Magnificent gift. Following the PDF I was traying to reproduce the "section pie" but I could not .How did you do? Thanks "
                                • fredo6F Offline
                                  Use the 'Ring' capability of the TOS shapes. In the VCB, you type an length, posititive or negative' followed by 'x', and you get the shape contour with the specificed offset. This is explained in the doc, in the Shapes section (page 9).
                                  Hope this answers your question.
                                  • E Offline
                                    Efrado
                                    As always your Kindness is OUT OF DOUBT ----PRICELESS-----Thank You
                                      mrljfr1
                                      Thanks,what a great work!
                                        lorca
                                        Am I doing something wrong? I place CadFather icons in the TOS v13 folder but I still get Fredo icons. I don't mind really but I wonder what is happening.
                                        • fredo6F Offline
                                          The folder is named TOS_Dir_13. I guess this is what you mean.
                                          I also assume that:
                                          • you unzipped correctly the CadFather icons into the folder (can you check the right files are there)
                                          • you restarted Sketchup
                                          • if you use both SU6 and SU7, you did not mix up the file copy.
                                          Otherwise, this looks strange. You can always delete all the png files in the folder and replace them by CadFather's files.
                                            lorca
                                            I also assume that:
                                            I extracted the Cadfather icons into the TOS_Dir_13. I deleted your icons to be sure I restarted sketchup but I still get your icons.
                                            • 11
                                            • 12
                                            • 13
                                            • 31
                                            • 32
                                            • 11 / 32
