    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      Matt666
      Hi Fredo!
      I suppose you will move your menus in "Fredo collection" in your next TOS update, like freescale plugin ? ❓
      That would be cool, and also your push pull plugin!
      Sans titre 1.jpgExcellent plugin, as always, sir! πŸ˜„ Thank you...
      Frenglish at its best !
      My scripts
      • simon le bonS
        simon le bon
        πŸ™‚ Matt,
        --/ Hope i'm not going too far from this thread /--
        @matt666 said:
        Just construction points? You can try native Su tool! GO to Edit menu / Delete guides.
        good tip: it is something I had forgotten.. > but the construction lines and points, they are all deleted from the overall model. Something we want not to be each time.
        @matt666 said:
        You can also copy this code below () in the ruby console... It will delete all construction points in the selection.
        This is just the good code: construction lines remain and every construction point inside selection are removed. Would you please make it as a .rb dear Matt? (I'm complet ignorant upon this ). It would be so greatfull!
        :-)simon
        • N
          Nathryc
          Thank you, Thank you, Thank you, Fredo!!!! (insert Happy Dance Here!)
          At last I can do what I've been trying to do since I first found SketchUp (modeling planets for exterior sci-fi scenes)
          This plug-in is MADE of 100% AWESOME!
          Nathryc
            Roger
            You are the Gustave Eiffel and Pierre Bezier of SketchUp. Merci Beaucoup from the USA!
            What will you do to top this achievement?
            http://www.azcreative.com
            • K
              Kus
              Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up
              no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb
              I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
              what should I do??[/quote]
              • fredo6F
                @kus said:
                Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up.
                what should I do??
                Kus,
                Seems you had a problem with the unzip operation.
                For Tools on Surface you must have only 2 elements in the Sketchup Plugins folder:
                • a small file: ZLoader_OnSurface.rb
                • a folder: TOS_Dir_13, with other rb files in it (and some subfolders).
                I suggest you check your files and redo the Unzip, with a Select All and then Extract, to make sure your preserve the folder hierarchy when unzipping.
                  Steelyjoe_n
                  Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
                    Steelyjoe_n
                    Nevermind
                    I forgot to check it in preferences, thank you for the program anyway πŸ˜„)
                    • N
                      niarfe
                      Fredo!!! I'm becoming your biggest fan!!!
                      thanks a lot!
                        monkeybss
                        I seem to have a problem too. I can see the toolbar but the offset doesn't work (Su7,7.0.102470), the line-on surface does, but nothing else seems to work.
                        I'm not familiar with ruby, but it feels like some setting might be wrong (like a variable in Autocad).
                        Later..
                        Just being stupid, I forgot to load in "preferences". Works like a charm!
                          Arthaxx
                          • H
                            hitman47127
                            thanksssssssssss a lot, 😍 😍 😍
                            • E
                              Efrado
                              Hi FREDO ,Thanks a lot for this Magnificent gift. Following the PDF I was traying to reproduce the "section pie" but I could not .How did you do? Thanks "
                              • fredo6F
                                Use the 'Ring' capability of the TOS shapes. In the VCB, you type an length, posititive or negative' followed by 'x', and you get the shape contour with the specificed offset. This is explained in the doc, in the Shapes section (page 9).
                                Hope this answers your question.
                                • E
                                  Efrado
                                  As always your Kindness is OUT OF DOUBT ----PRICELESS-----Thank You
                                    mrljfr1
                                    Thanks,what a great work!
                                    • L
                                      lorca
                                      Am I doing something wrong? I place CadFather icons in the TOS v13 folder but I still get Fredo icons. I don't mind really but I wonder what is happening.
                                      • fredo6F
                                        The folder is named TOS_Dir_13. I guess this is what you mean.
                                        I also assume that:
                                        • you unzipped correctly the CadFather icons into the folder (can you check the right files are there)
                                        • you restarted Sketchup
                                        • if you use both SU6 and SU7, you did not mix up the file copy.
                                        Otherwise, this looks strange. You can always delete all the png files in the folder and replace them by CadFather's files.
                                        • L
                                          lorca
                                          I also assume that:
                                          I extracted the Cadfather icons into the TOS_Dir_13. I deleted your icons to be sure I restarted sketchup but I still get your icons.
                                          • fredo6F
                                            Maybe you still run TOS 1.2.
                                            Can you check the file ZLoader__onSurface.rbto verify that it contains the correct reference to TOS_Dir_13 (alternately, reinstall the plugin, making sure you overwrite all files, including ZLoader__onSurface.rb).
