    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    NprTools
    extensions
    83 Posts 9 Posters 13.9k Views 9 Watching
      richcat
      Al
      I've just download and installed OK but when attempting to use it says my trial period has expired.
      (EDIT) It seems to be conflicting with Rptools, I'll try and see if it makes any difference by removing Rptools.
      • Al HartA Offline
        Al Hart
        I just launched the Beta Test version.
        See: This Thread
        Al Hart
        IRender nXt from Render Plus
        • Al HartA Offline
          Al Hart
          @richcat said:
          Al
          Hopefully you will be the only one with this problem. (I seem to remember that you tested it about a year ago)
          Try this reset trial code:
          Today's reset trial code is: 89307
          This code is only valid for today: Tuesday, May 12, 2009.
          If you need to process it tomorrow instead, tomorrow's code is: 90344
          1. Load the License dialog in SketchUp/Plugins/NprTools/License
          2. Enter the password into the 'Authcode or Security Code' field of the license dialog, and
            click 'Check License and Validate'.
          You should be 'rewarded' with the message 'Trial Mode Reset',
          which will reset your trial period for 30 more days.
          Al Hart
            richcat
            Tried both codes and says it reset days to 0, each time I restart sketchup it says it end of trial period and I have to insert codes again.
            • tinanneT Offline
              tinanne
              Thanks Al, I'm trying it out now.
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
              • Al HartA Offline
                Al Hart
                Arrgh! 😠
                Is it working for anyone else?
                If not, we may have to put out a new version tomorrow.
                Richcat,
                Start your RUby Console and type in: Time.now and send it to me.
                Al Hart
                • Al HartA Offline
                  Al Hart
                  You work fast! I went to the DL page and there is no check box for NPR Tools-- might confuse folks?
                  I put out the Alpha Test version of NprTools over a year ago - so it has been in production for a long, long time.
                  But I am glad to finally get it out (I hope)
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    @richcat said:
                    Al
                    Yes, We really need to put out a new version of RpTools as well to match it.
                    [Edit] You can't really remove RpTools. It shares the same code space, and installation folder as NprTools.
                    (They are the same internally, except for the toolbar)
                    If you have a valid license for RpTools, or the Combo Pack, use that license and request an authcode for NprTools. People who own either of these products to not have to purchase NprTools. It will be included.
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      Note to self: Don't release a new Beta Test product just 30 minutes prior to when you will be gone for several hours.
                      If anyone has problems, be patient and look again tomorrow.
                      Al Hart
                        richcat
                        I was able to quickly try out soft shadows but even though I selected launch when complete, had to go searching for the image produced in "My Documents\NprTools\SoftShadows"
                          richcat
                          AL
                          On the machine I'm testing this on it has an a copy of RpTools but the trial has expired, which basically leaves me with the tools in RpEdits.
                          My laptop has the fully functional copy of RpTools, but I have not tried Nrptools on this yet.
                          Just luv these soft shadows (10 iterations & time increment set 1) šŸŽ‰
                            BTM
                            Sorry I haven't been able to scan the sketchy lines %(#808080)[(still šŸ˜ž )]. i've had issues with a few things, including finding out which surface I drew the cleaner-looking diagonal lines on ( I've tried a few different places...).
                            Oh, and on the NprTools wiki, it says 'diagonals not available' for the thin lines, but I did post them šŸ˜•
                            http://www.sketchucation.com/forums/scf/download/file.php?id=26739
                            http://www.sketchucation.com/forums/scf/download/file.php?id=26740
                            lastly, I can't use it because i don't have a sketchup enabled windows computer lying around. Still, I can't find the demo download link on the downloads page 😐 If it's there, I guess I'm not looking hard enough šŸ˜†
                            ...Also, anyone have any sketchy shadow examples? šŸ˜„ I just want to see how they work.
                            • Al HartA Offline
                              Al Hart
                              We did start on the Mac version last week, but it will be a little while before it is ready.
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                @richcat said:
                                Al
                                NprTools is checking the trial days for RpTools instead of the new trial days for NprTools.
                                There is no easy fix.
                                I'll post a new version tomorrow for people who already have RpTools installed.
                                Sorry,
                                Al
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  I just added the NprTools checkbox to the download form.
                                  (You can download all products even if you don't check them off)
                                  And it is on the page you get after filling out the form.
                                  In either case, click Refresh if you can't see it.
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    @richcat said:
                                    Al
                                    People with RpTools installed may be having a problem with NprTools.
                                    (Uninstalling RpTools doesn't help)
                                    We will post a new version on Wednesday.
                                    Al Hart
                                    • Al HartA Offline
                                      Al Hart
                                      I had a similar problem launching images on my Vista machine, but I thought I had it fixed.
                                      See This Thread
                                      Try a couple of things for me.
                                      1. In the Ruby console, store the full path of a png image in a variable s1, using
                                      s1 = 'c:/path.../image.png', or
                                      s1 = 'c:\path...\image.png' (with single quote marks, you do not have to escape the back slashes)
                                      Then type in: UI.openURL(s1)
                                      This should launch the image.
                                      s1 = 'C;\docs\NprTools\SoftShadows\Shadows-k.png'
                                      UI.openURL(s1)
                                      true
                                      (every other response here is the outut from Ruby.)
                                      Also see what is returned by UI.openURL (true means that it thinks it worked)
                                      1. If it doesn't launch the image, then navigate to the .PNG file in Windows Explorer, and right click on it. See what verbs are displayed and what the default verb is.
                                      If Open is in this list, and if the default verb (in my case Edit), launches the image then it should work.
                                      1. If UI.openURL does launch the image, then type in:
                                      $nprtools.launch_file(s1)
                                      and see what happens.
                                      Al Hart
                                        richcat
                                        Al I'm on XP Pro
                                        Tried the ruby code above and it opened with both versions followed by UI.openURL(s1)and $nprtools.launch_file(s1)also worked.
                                        If I double left click image it opens in image viewer, If I right click I get the menu as below.
                                        • Al HartA Offline
                                          Al Hart
                                          @richcat said:
                                          Al I'm on XP Pro
                                          Thanks for the help richcat.
                                          Hopefully NprTools will launch the images properly for you when you get the new version.
                                          Al Hart
                                          • Al HartA Offline
                                            Al Hart
                                            SOn the NprTools wiki, it says 'diagonals not available' for the thin lines, but I did post them šŸ˜•
                                            Thanks,
                                            I added the diagonal patterns to todays release.
                                            (It will go our as soon as Rich gets back from feeding himself)
                                            Here is a Sketchy Shadow example with the diagonal thin lines.
                                            (I rotated the house a little so we wouldn't have to see the same old boring model again. šŸ˜ž )
                                            Al Hart
                                            • 4 / 5
