    NprTools
    extensions
    83 Posts 9 Posters 14.3k Views 9 Watching
    • Al HartA Offline
      Al Hart
      @tinanne said:
      Thanks Al. I LOVE the sketchy lines, I use them all the time, just not as thick as you were using. Looks like a great tool! I'm looking forward to the beta release. Need a Beta tester?
      Everyone who wants can have a free test copy for a couple of months. Just watch this thread for the release.
      Al Hart
      IRender nXt from Render Plus
      • tinanneT Offline
        tinanne
        Awesome! I'm looking forward to it.
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
        • Al HartA Offline
          Al Hart
          The last thing which was holding me up from putting out the Beta for NprTools was a way to make good sketchy textures. NprTools has a feature which draws patterns in SketchUp, then lets you apply Sketchy Edge Styles to the textures and then make them tileable for use as Sketchy Patterns in SketchUp.
          http://wiki.renderplus.com/images/b/b4/Sketchy_Material_Dialog-2.jpg
          GIMP and PhotoShop have routines to make patterns tileable, but I wanted something we could run directly from SketchUp.
          This new feature of NprTools using an algorithm described by Paul Bourke
          Here is an example of taking a non-repeatable swirl pattern, making it tileable and placing it in SketchUp.
          Original Pattern
          http://wiki.renderplus.com/images/3/3b/Original1.PNG
          Tileable Pattern from NprTools
          http://wiki.renderplus.com/images/7/70/Original1_r.PNG
          Repeating Texture used in SketchUp
          http://wiki.renderplus.com/images/thumb/3/38/Radial-swirls.jpg/400px-Radial-swirls.jpg
          This example was not very tileable in the first place, but makes it easier to see how this works. It works well with patterns, like grass or carpets, which are almost tileable. But it will make any pattern tileable.
          See: Tileable Patterns for a better explanation on how this works.
          Al Hart
          • tinanneT Offline
            tinanne
            Do you have any idea when the Beta release will be available?
            • Al HartA Offline
              Al Hart
              I have promised myself that I will get it out this week. šŸ˜•
              Al Hart
                šŸŽ‰
                • Al HartA Offline
                  Al Hart
                  NprTools is ready for testing.
                  http://wiki.renderplus.com/images/4/4f/House1-white-SS-bp.png
                  To download the trial version, go to Downloads
                  For more information, see: NprTools
                  Place any questions, comments, etc. here, or on this SketchUcation Support Forum Thread.
                  Look for these features:
                  http://wiki.renderplus.com/images/3/3b/NprTools-toolbar.jpg
                  1. Soft Shadows
                  2. Sketchy Shadows
                  3. Sketchy Textures
                  4. Soft Edges
                  5. Crayon Colors and Styles
                  6. Save Images from SketchUp
                  7. Make images Tileable
                  (We will have better icons in a day or two when the crowdSPRING design project is completed.)
                  Al Hart
                    richcat
                    Al
                    I've just download and installed OK but when attempting to use it says my trial period has expired.
                    (EDIT) It seems to be conflicting with Rptools, I'll try and see if it makes any difference by removing Rptools.
                    • Al HartA Offline
                      Al Hart
                      I just launched the Beta Test version.
                      See: This Thread
                      Al Hart
                      • Al HartA Offline
                        Al Hart
                        @richcat said:
                        Al
                        Hopefully you will be the only one with this problem. (I seem to remember that you tested it about a year ago)
                        Try this reset trial code:
                        Today's reset trial code is: 89307
                        This code is only valid for today: Tuesday, May 12, 2009.
                        If you need to process it tomorrow instead, tomorrow's code is: 90344
                        1. Load the License dialog in SketchUp/Plugins/NprTools/License
                        2. Enter the password into the 'Authcode or Security Code' field of the license dialog, and
                          click 'Check License and Validate'.
                        You should be 'rewarded' with the message 'Trial Mode Reset',
                        which will reset your trial period for 30 more days.
                        Al Hart
                          richcat
                          Tried both codes and says it reset days to 0, each time I restart sketchup it says it end of trial period and I have to insert codes again.
                          • tinanneT Offline
                            tinanne
                            Thanks Al, I'm trying it out now.
                            • Al HartA Offline
                              Al Hart
                              Arrgh! 😠
                              Is it working for anyone else?
                              If not, we may have to put out a new version tomorrow.
                              Richcat,
                              Start your RUby Console and type in: Time.now and send it to me.
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                You work fast! I went to the DL page and there is no check box for NPR Tools-- might confuse folks?
                                I put out the Alpha Test version of NprTools over a year ago - so it has been in production for a long, long time.
                                But I am glad to finally get it out (I hope)
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  @richcat said:
                                  Al
                                  Yes, We really need to put out a new version of RpTools as well to match it.
                                  [Edit] You can't really remove RpTools. It shares the same code space, and installation folder as NprTools.
                                  (They are the same internally, except for the toolbar)
                                  If you have a valid license for RpTools, or the Combo Pack, use that license and request an authcode for NprTools. People who own either of these products to not have to purchase NprTools. It will be included.
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    Note to self: Don't release a new Beta Test product just 30 minutes prior to when you will be gone for several hours.
                                    If anyone has problems, be patient and look again tomorrow.
                                    Al Hart
                                      richcat
                                      I was able to quickly try out soft shadows but even though I selected launch when complete, had to go searching for the image produced in "My Documents\NprTools\SoftShadows"
                                        richcat
                                        AL
                                        On the machine I'm testing this on it has an a copy of RpTools but the trial has expired, which basically leaves me with the tools in RpEdits.
                                        My laptop has the fully functional copy of RpTools, but I have not tried Nrptools on this yet.
                                        Just luv these soft shadows (10 iterations & time increment set 1) šŸŽ‰
                                          BTM
                                          Sorry I haven't been able to scan the sketchy lines %(#808080)[(still šŸ˜ž )]. i've had issues with a few things, including finding out which surface I drew the cleaner-looking diagonal lines on ( I've tried a few different places...).
                                          Oh, and on the NprTools wiki, it says 'diagonals not available' for the thin lines, but I did post them šŸ˜•
                                          http://www.sketchucation.com/forums/scf/download/file.php?id=26739
                                          http://www.sketchucation.com/forums/scf/download/file.php?id=26740
                                          lastly, I can't use it because i don't have a sketchup enabled windows computer lying around. Still, I can't find the demo download link on the downloads page 😐 If it's there, I guess I'm not looking hard enough šŸ˜†
                                          ...Also, anyone have any sketchy shadow examples? šŸ˜„ I just want to see how they work.
                                          • Al HartA Offline
                                            Al Hart
                                            We did start on the Mac version last week, but it will be a little while before it is ready.
                                            Al Hart
                                            With your input, this post could be even better šŸ’—
                                            • 1 / 5
