    NprTools
    extensions
    83 Posts 9 Posters 21.3k Views 9 Watching
    • Al HartA
      Al Hart
      @tinanne said:
      To answer my own question.. I'm guessing that is an SU option.....
      Yes, these line weights are a SketchUp Sketchy Style. For non-photorealistic rendering, some people like these line weights because they give the drawing a Sketchy look. However the Soft Shadows did not change the line weights. It uses what you have already.
      Here is a similar model, with normal lines:
      Al Hart
      IRender nXt from Render Plus
      • tinanneT
        tinanne
        Thanks Al. I LOVE the sketchy lines, I use them all the time, just not as thick as you were using. Looks like a great tool! I'm looking forward to the beta release. Need a Beta tester?
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
        • Al HartA
          Al Hart
          Everyone who wants can have a free test copy for a couple of months. Just watch this thread for the release.
          Al Hart
          • tinanneT
            tinanne
            Awesome! I'm looking forward to it.
            • Al HartA
              Al Hart
              The last thing which was holding me up from putting out the Beta for NprTools was a way to make good sketchy textures. NprTools has a feature which draws patterns in SketchUp, then lets you apply Sketchy Edge Styles to the textures and then make them tileable for use as Sketchy Patterns in SketchUp.
              http://wiki.renderplus.com/images/b/b4/Sketchy_Material_Dialog-2.jpg
              GIMP and PhotoShop have routines to make patterns tileable, but I wanted something we could run directly from SketchUp.
              This new feature of NprTools using an algorithm described by Paul Bourke
              Here is an example of taking a non-repeatable swirl pattern, making it tileable and placing it in SketchUp.
              Original Pattern
              http://wiki.renderplus.com/images/3/3b/Original1.PNG
              Tileable Pattern from NprTools
              http://wiki.renderplus.com/images/7/70/Original1_r.PNG
              Repeating Texture used in SketchUp
              http://wiki.renderplus.com/images/thumb/3/38/Radial-swirls.jpg/400px-Radial-swirls.jpg
              This example was not very tileable in the first place, but makes it easier to see how this works. It works well with patterns, like grass or carpets, which are almost tileable. But it will make any pattern tileable.
              See: Tileable Patterns for a better explanation on how this works.
              Al Hart
              • tinanneT
                tinanne
                Do you have any idea when the Beta release will be available?
                • Al HartA
                  Al Hart
                  I have promised myself that I will get it out this week. šŸ˜•
                  Al Hart
                    šŸŽ‰
                    • Al HartA
                      Al Hart
                      NprTools is ready for testing.
                      http://wiki.renderplus.com/images/4/4f/House1-white-SS-bp.png
                      To download the trial version, go to Downloads
                      For more information, see: NprTools
                      Place any questions, comments, etc. here, or on this SketchUcation Support Forum Thread.
                      Look for these features:
                      http://wiki.renderplus.com/images/3/3b/NprTools-toolbar.jpg
                      1. Soft Shadows
                      2. Sketchy Shadows
                      3. Sketchy Textures
                      4. Soft Edges
                      5. Crayon Colors and Styles
                      6. Save Images from SketchUp
                      7. Make images Tileable
                      (We will have better icons in a day or two when the crowdSPRING design project is completed.)
                      Al Hart
                        richcat
                        Al
                        I've just download and installed OK but when attempting to use it says my trial period has expired.
                        (EDIT) It seems to be conflicting with Rptools, I'll try and see if it makes any difference by removing Rptools.
                        • Al HartA
                          Al Hart
                          I just launched the Beta Test version.
                          See: This Thread
                          Al Hart
                          • Al HartA
                            Al Hart
                            @richcat said:
                            Al
                            Hopefully you will be the only one with this problem. (I seem to remember that you tested it about a year ago)
                            Try this reset trial code:
                            Today's reset trial code is: 89307
                            This code is only valid for today: Tuesday, May 12, 2009.
                            If you need to process it tomorrow instead, tomorrow's code is: 90344
                            1. Load the License dialog in SketchUp/Plugins/NprTools/License
                            2. Enter the password into the 'Authcode or Security Code' field of the license dialog, and
                              click 'Check License and Validate'.
                            You should be 'rewarded' with the message 'Trial Mode Reset',
                            which will reset your trial period for 30 more days.
                            Al Hart
                              richcat
                              Tried both codes and says it reset days to 0, each time I restart sketchup it says it end of trial period and I have to insert codes again.
                              • tinanneT
                                tinanne
                                Thanks Al, I'm trying it out now.
                                • Al HartA
                                  Al Hart
                                  Arrgh! 😠
                                  Is it working for anyone else?
                                  If not, we may have to put out a new version tomorrow.
                                  Richcat,
                                  Start your RUby Console and type in: Time.now and send it to me.
                                  Al Hart
                                  • Al HartA
                                    Al Hart
                                    You work fast! I went to the DL page and there is no check box for NPR Tools-- might confuse folks?
                                    I put out the Alpha Test version of NprTools over a year ago - so it has been in production for a long, long time.
                                    But I am glad to finally get it out (I hope)
                                    Al Hart
                                    • Al HartA
                                      Al Hart
                                      @richcat said:
                                      Al
                                      Yes, We really need to put out a new version of RpTools as well to match it.
                                      [Edit] You can't really remove RpTools. It shares the same code space, and installation folder as NprTools.
                                      (They are the same internally, except for the toolbar)
                                      If you have a valid license for RpTools, or the Combo Pack, use that license and request an authcode for NprTools. People who own either of these products to not have to purchase NprTools. It will be included.
                                      Al Hart
                                      • Al HartA
                                        Al Hart
                                        Note to self: Don't release a new Beta Test product just 30 minutes prior to when you will be gone for several hours.
                                        If anyone has problems, be patient and look again tomorrow.
                                        Al Hart
                                          richcat
                                          I was able to quickly try out soft shadows but even though I selected launch when complete, had to go searching for the image produced in "My Documents\NprTools\SoftShadows"
                                            richcat
                                            AL
                                            On the machine I'm testing this on it has an a copy of RpTools but the trial has expired, which basically leaves me with the tools in RpEdits.
                                            My laptop has the fully functional copy of RpTools, but I have not tried Nrptools on this yet.
                                            Just luv these soft shadows (10 iterations & time increment set 1) šŸŽ‰
                                            With your input, this post could be even better šŸ’—
                                            • 1 / 5
