    NprTools
    extensions
    83 Posts 9 Posters 18.7k Views 9 Watching
    • PixeroP Offline
      Pixero
      I would like to see an option for having the shadow lines all in the same direction.
      Like I would draw them.
      As it is now it looks too artificial for my taste.
      Also a slider for soft shadows ranging from Sharp to Very smooth maybe in some increments.
      You can still have the choise for time and day offset but for ease of use I think a slider is better.
      • Al HartA Offline
        Al Hart
        Good idea - currently I place the shadow lines on the faces in the SketchUp model, which rotates them.
        I will offer a second options which will place a watermark texture on all the shadows, much like SketchUp does in styles.
        It will look more like this:
        (Based on the image you provide for the watermark)
        Al Hart
        IRender nXt from Render Plus
        • tinanneT Offline
          tinanne
          Will there be an option for lighter line weights? In the example you keep using the line weights are just so heavy. I don't think I would ever use (have ever) such a heavy look.
          To answer my own question.. I'm guessing that is an SU option.....
          Executive Director : American Society of Architectural Illustrators
          AIP 30 Competition opens soon. ASAI.org
          Architectural Rendering
          • Al HartA Offline
            Al Hart
            Yes, these line weights are a SketchUp Sketchy Style. For non-photorealistic rendering, some people like these line weights because they give the drawing a Sketchy look. However the Soft Shadows did not change the line weights. It uses what you have already.
            Here is a similar model, with normal lines:
            Al Hart
            • tinanneT Offline
              tinanne
              Thanks Al. I LOVE the sketchy lines, I use them all the time, just not as thick as you were using. Looks like a great tool! I'm looking forward to the beta release. Need a Beta tester?
              • Al HartA Offline
                Al Hart
                Everyone who wants can have a free test copy for a couple of months. Just watch this thread for the release.
                Al Hart
                • tinanneT Offline
                  tinanne
                  Awesome! I'm looking forward to it.
                  • Al HartA Offline
                    Al Hart
                    The last thing which was holding me up from putting out the Beta for NprTools was a way to make good sketchy textures. NprTools has a feature which draws patterns in SketchUp, then lets you apply Sketchy Edge Styles to the textures and then make them tileable for use as Sketchy Patterns in SketchUp.
                    http://wiki.renderplus.com/images/b/b4/Sketchy_Material_Dialog-2.jpg
                    GIMP and PhotoShop have routines to make patterns tileable, but I wanted something we could run directly from SketchUp.
                    This new feature of NprTools using an algorithm described by Paul Bourke
                    Here is an example of taking a non-repeatable swirl pattern, making it tileable and placing it in SketchUp.
                    Original Pattern
                    http://wiki.renderplus.com/images/3/3b/Original1.PNG
                    Tileable Pattern from NprTools
                    http://wiki.renderplus.com/images/7/70/Original1_r.PNG
                    Repeating Texture used in SketchUp
                    http://wiki.renderplus.com/images/thumb/3/38/Radial-swirls.jpg/400px-Radial-swirls.jpg
                    This example was not very tileable in the first place, but makes it easier to see how this works. It works well with patterns, like grass or carpets, which are almost tileable. But it will make any pattern tileable.
                    See: Tileable Patterns for a better explanation on how this works.
                    Al Hart
                    • tinanneT Offline
                      tinanne
                      Do you have any idea when the Beta release will be available?
                      • Al HartA Offline
                        Al Hart
                        I have promised myself that I will get it out this week. 😕
                        Al Hart
                          • Al HartA Offline
                            Al Hart
                            NprTools is ready for testing.
                            http://wiki.renderplus.com/images/4/4f/House1-white-SS-bp.png
                            To download the trial version, go to Downloads
                            For more information, see: NprTools
                            Place any questions, comments, etc. here, or on this SketchUcation Support Forum Thread.
                            Look for these features:
                            http://wiki.renderplus.com/images/3/3b/NprTools-toolbar.jpg
                            1. Soft Shadows
                            2. Sketchy Shadows
                            3. Sketchy Textures
                            4. Soft Edges
                            5. Crayon Colors and Styles
                            6. Save Images from SketchUp
                            7. Make images Tileable
                            (We will have better icons in a day or two when the crowdSPRING design project is completed.)
                            Al Hart
                              richcat
                              Al
                              I've just download and installed OK but when attempting to use it says my trial period has expired.
                              (EDIT) It seems to be conflicting with Rptools, I'll try and see if it makes any difference by removing Rptools.
                              • Al HartA Offline
                                Al Hart
                                I just launched the Beta Test version.
                                See: This Thread
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  @richcat said:
                                  Al
                                  Hopefully you will be the only one with this problem. (I seem to remember that you tested it about a year ago)
                                  Try this reset trial code:
                                  Today's reset trial code is: 89307
                                  This code is only valid for today: Tuesday, May 12, 2009.
                                  If you need to process it tomorrow instead, tomorrow's code is: 90344
                                  1. Load the License dialog in SketchUp/Plugins/NprTools/License
                                  2. Enter the password into the 'Authcode or Security Code' field of the license dialog, and
                                    click 'Check License and Validate'.
                                  You should be 'rewarded' with the message 'Trial Mode Reset',
                                  which will reset your trial period for 30 more days.
                                  Al Hart
                                    richcat
                                    Tried both codes and says it reset days to 0, each time I restart sketchup it says it end of trial period and I have to insert codes again.
                                    • tinanneT Offline
                                      tinanne
                                      Thanks Al, I'm trying it out now.
                                      • Al HartA Offline
                                        Al Hart
                                        Arrgh! 😠
                                        Is it working for anyone else?
                                        If not, we may have to put out a new version tomorrow.
                                        Richcat,
                                        Start your RUby Console and type in: Time.now and send it to me.
                                        Al Hart
                                        • Al HartA Offline
                                          Al Hart
                                          You work fast! I went to the DL page and there is no check box for NPR Tools-- might confuse folks?
                                          I put out the Alpha Test version of NprTools over a year ago - so it has been in production for a long, long time.
                                          But I am glad to finally get it out (I hope)
                                          Al Hart
                                          • Al HartA Offline
                                            Al Hart
                                            @richcat said:
                                            Al
                                            Yes, We really need to put out a new version of RpTools as well to match it.
                                            [Edit] You can't really remove RpTools. It shares the same code space, and installation folder as NprTools.
                                            (They are the same internally, except for the toolbar)
                                            If you have a valid license for RpTools, or the Combo Pack, use that license and request an authcode for NprTools. People who own either of these products to not have to purchase NprTools. It will be included.
                                            Al Hart
                                            • 1 / 5
