[Plugin Library] LibFredo6 - v14.4c - 18 May 24
Thank you for sharing such awesome tools! You are truly a ruby script-master!
Hello.
This is Korean language files of LibFredo6 & FreeScale.
I really love this awsome plugin.
Thanks, Fredo6!
Hello.
Thanks, Fredo6!
The 2 files seems to work, though I can't really help to check with my laptop. At least it shows up in the translation dialog box.
Does 크기 변형 means "Scaling"If other users want to try, just extract the file and
- drop LibFredo6_KO.lang into the LIBFREDO6_Dir_31 folder
- drop FreeScale_KO.lang into FREESCALE_Dir_20 folder
Thanks very much
Fred
a very useful tool, thank you very much.!
NEW VERSION 3.1d
Needed for for FreeScale 2.0d (the previous version 2.0c had a major bug).
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 -
NEW VERSION 3.1e
Needed for for FreeScale 2.0e
Fredo,
First of all many thanks for all your wonderfull plugins. You have brought SU to a new, unprecedented, level.
Of course I follow the topics on your plugins and try to be as updated as possible, because your plugins already make part of my daily/standard SU tools.
You have just released a new version of Freescale (v2.0e) and following your advise I also downloaded the new
LibFredo6 (v3.1e). For the first time, this release contains a new folder called DEFPARAM_Dir, containing 1 (text)item. But...this file is already in my plugins folder as part of the Cadspan plugin (to prepare SU models for 3D printing).
As usual it is impossible to have 2 files with identical names in one folder........
So here's my question: can I replace the cadspan-DEFPARAM_Dir with yours, without getting into troubles with Cadspan or not? Can both plugins use that same folder without problems??
I have put 'on hold' the update of your plugins upon further info from you, so please fill me in. -
Ton,
The small text file have no specific use for the script. It is there in the archive to force the creation of DEFPARAM_Dir via Unzipif not already existing.
I incorporated the DEFPARAM_Dir folder (empty with just one small file) in order to be sure this folder is created at installation.
LibFredo6 would normally create it on the fly whenever you deal with Default Parameters, but it seems that in some environments (Mac in particular) and depending on security rules, the creation of the folder from a Ruby script may not be authorized.
When you unzip, and already have a folder DEFPARAM_Dir, it is neutral. Whether you answer Yes or No to the 'Replacement' question from Unzip (or Copy), your existing folder will continue existing, as well as its content.
PS: In general, I recommend that you always do a Yes All replacement when unzipping, so that you don't have to worry about what has changed. Also, keep in mind that file names in a ZIP archive go along the folder hierarchy (so it is not unusual to have several files with the same name in a Zip file, but associated with different folders)
Also, I introduce this change in release 3.1c or 3.1d, not 3.1e
Fredo,
Ton,
My previous post was general about the installation.
In your specific case of Cadspan, are you sure the DEFPARAM_Dir folder belongs to this script. Could you tell me what it contains?
NEW VERSION 3.1f
Includes fixes for Mac compatibility (web dialog boxes) and Italian translation by COSEDIMARCO.
Goes along with FreeScale 2.0f
When I close SketchUp, my debugger console get the following messages.
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Core_31.rb:270: warning: parenthesize argument(s) for future version
C:/Program Files/Google/Google SketchUp 7/Plugins/PutOnLayer.rb:78: warning: don't put space before argument parentheses
(eval):1: warning: already initialized constant SU_MAJOR_VERSION
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:325: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:331: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:335: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:339: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Protractor.rb:154: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Startup_31.rb:58: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:325: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:437: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:653: warning: don't put space before argument parentheses
C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Traductor_31.rb:47: warning: don't put space before argument parentheses
(eval):3081: warning: parenthesize argument(s) for future version
(eval):3104: warning: parenthesize argument(s) for future version
key = Units
value = 0.0
key = StampOffset
value = 12.0
key = GridSpacingX
value = 120.0
key = SmooveRadius
value = 360.0
key = GridSpacingY
value = 120.0
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command -
Thanks for signaling this.
These are just harmless warnings about the ruby syntax.
I fiexed them anyway, and it will go in a further version.Fredo
Fredo..
I don´t know if this is the correct place for this request.
Can be added something like this menu to LibFredo6?:
(It is from: http://www.3skeng.com)This menu can be part of your plugins...
I don´t know if your HoverSelect will be extended to select faces, groups, dimensions... but the idea is to have only one button on the toolbar and with a key you can see and select all the other options with the onscreen menu:
Example for JPP tool:
Daniel S
Daniel,
This is an interesting metaphor.
There are however a few issues with the JPP suggestion, because it is not possble to drwa images (i.e. jpg) in a tool.For HoverSelect, I am not clear on what it would give on other entity types than edges. But this would be easy to derive (Edges are the most complex actually).
I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
This might be because you did not install FreeScale or HoverSelect.
Actually, I arranged that, unless a script using LibFredo6 is used, the library itself is not loaded, in order not to pollute Sketchup, not even with the menu (except a very small bootstrap code). Remember that, alone, LibFredo6 does not provide any functionality.Fredo
I only wish it were that simple. I tried both with and without putting FreeScale in the Plugins folder. When FreeScale is in the folder, I get:
"Error Loading File FreeScale_Common.rb
(eval):1: uninitialized constant FreeScale::T6"Where do I go from here?
It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
Yes.
The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins"
The size is "3.03 KB (3,108 bytes)"
The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
