    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      NEW VERSION 3.1bavailable.
      It is necessary for running the upgrade to FreeScale 2.0b.
      see main message of this thread
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=145336#p144178
      • L
        LuckyNinja99
        I followed the installation instructions on your pdf to the letter, and I'm rewarded with an amazing nothing. You installation instructions are unclear and inadequate
          remus
          You wont get anything visible after you install libfred06. Have you installed freescale?
          • L
            LuckyNinja99
            I take back my above post. I've got it to work now, I'm just a bit tired. On that note, well done sir
              remus
              Glad to hear its working πŸ‘
              • fredo6F
                NEW VERSION 3.1c
                Needed for for FreeScale 2.0c
                see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                • fredo6F
                  NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
                  Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
                  • McGyverM
                    McGyver
                    Thank you for sharing such awesome tools! You are truly a ruby script-master!
                    Visit My ShareCG Freebie Gallery
                    • C
                      CouqueDasse
                      Hello.
                      This is Korean language files of LibFredo6 & FreeScale.
                      I really love this awsome plugin.
                      Thanks, Fredo6!
                      Korean Translation
                      • fredo6F
                        Hello.
                        Thanks, Fredo6!
                        The 2 files seems to work, though I can't really help to check with my laptop. At least it shows up in the translation dialog box.
                        Does 크기 λ³€ν˜• means "Scaling"
                        If other users want to try, just extract the file and
                        • drop LibFredo6_KO.lang into the LIBFREDO6_Dir_31 folder
                        • drop FreeScale_KO.lang into FREESCALE_Dir_20 folder
                        Thanks very much
                        Fred
                        • I
                          ideas_arte
                          a very useful tool, thank you very much.! πŸ˜„
                          • fredo6F
                            NEW VERSION 3.1d
                            Needed for for FreeScale 2.0d (the previous version 2.0c had a major bug).
                            • fredo6F
                              NEW VERSION 3.1e
                              Needed for for FreeScale 2.0e
                              • COSEDIMARCOC
                                COSEDIMARCO
                                @Fredo6
                                New Italian translation is ready. πŸ˜„
                                Italian Translation for the new version
                                [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                • ton baetenT
                                  ton baeten
                                  Fredo,
                                  First of all many thanks for all your wonderfull plugins. You have brought SU to a new, unprecedented, level.
                                  Of course I follow the topics on your plugins and try to be as updated as possible, because your plugins already make part of my daily/standard SU tools.
                                  You have just released a new version of Freescale (v2.0e) and following your advise I also downloaded the new
                                  LibFredo6 (v3.1e). For the first time, this release contains a new folder called DEFPARAM_Dir, containing 1 (text)item. But...this file is already in my plugins folder as part of the Cadspan plugin (to prepare SU models for 3D printing).
                                  As usual it is impossible to have 2 files with identical names in one folder........
                                  So here's my question: can I replace the cadspan-DEFPARAM_Dir with yours, without getting into troubles with Cadspan or not? Can both plugins use that same folder without problems??
                                  I have put 'on hold' the update of your plugins upon further info from you, so please fill me in.
                                  greetings,
                                  Ton
                                  • fredo6F
                                    Ton,
                                    The small text file have no specific use for the script. It is there in the archive to force the creation of DEFPARAM_Dir via Unzipif not already existing.
                                    I incorporated the DEFPARAM_Dir folder (empty with just one small file) in order to be sure this folder is created at installation.
                                    LibFredo6 would normally create it on the fly whenever you deal with Default Parameters, but it seems that in some environments (Mac in particular) and depending on security rules, the creation of the folder from a Ruby script may not be authorized.
                                    When you unzip, and already have a folder DEFPARAM_Dir, it is neutral. Whether you answer Yes or No to the 'Replacement' question from Unzip (or Copy), your existing folder will continue existing, as well as its content.
                                    PS: In general, I recommend that you always do a Yes All replacement when unzipping, so that you don't have to worry about what has changed. Also, keep in mind that file names in a ZIP archive go along the folder hierarchy (so it is not unusual to have several files with the same name in a Zip file, but associated with different folders)
                                    Also, I introduce this change in release 3.1c or 3.1d, not 3.1e
                                    • fredo6F
                                      Fredo,
                                      Ton,
                                      My previous post was general about the installation.
                                      In your specific case of Cadspan, are you sure the DEFPARAM_Dir folder belongs to this script. Could you tell me what it contains?
                                      • fredo6F
                                        NEW VERSION 3.1f
                                        Includes fixes for Mac compatibility (web dialog boxes) and Italian translation by COSEDIMARCO.
                                        Goes along with FreeScale 2.0f
                                        • P
                                          pecan
                                          When I close SketchUp, my debugger console get the following messages.
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Core_31.rb:270: warning: parenthesize argument(s) for future version
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/PutOnLayer.rb:78: warning: don't put space before argument parentheses
                                          (eval):1: warning: already initialized constant SU_MAJOR_VERSION
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:325: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:331: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:335: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:339: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Protractor.rb:154: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Startup_31.rb:58: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:325: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:437: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:653: warning: don't put space before argument parentheses
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Traductor_31.rb:47: warning: don't put space before argument parentheses
                                          (eval):3081: warning: parenthesize argument(s) for future version
                                          (eval):3104: warning: parenthesize argument(s) for future version
                                          key = Units
                                          value = 0.0
                                          key = StampOffset
                                          value = 12.0
                                          key = GridSpacingX
                                          value = 120.0
                                          key = SmooveRadius
                                          value = 360.0
                                          key = GridSpacingY
                                          value = 120.0
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          free_Command
                                          • fredo6F
                                            Thanks for signaling this.
                                            These are just harmless warnings about the ruby syntax.
                                            I fiexed them anyway, and it will go in a further version.
                                            • 115
                                            • 116
                                            • 1 / 116
