    [Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
    2.3k Posts 593 Posters 13.9m Views 595 Watching
    • fredo6F
      Fredo,
      For the first time, this release contains a new folder called DEFPARAM_Dir, containing 1 (text)item. But...this file is already in my plugins folder as part of the Cadspan plugin (to prepare SU models for 3D printing).
      Ton,
      My previous post was general about the installation.
      In your specific case of Cadspan, are you sure the DEFPARAM_Dir folder belongs to this script. Could you tell me what it contains?
      • fredo6F
        NEW VERSION 3.1f
        Includes fixes for Mac compatibility (web dialog boxes) and Italian translation by COSEDIMARCO.
        Goes along with FreeScale 2.0f
        see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
        • P
          pecan
          When I close SketchUp, my debugger console get the following messages.
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Core_31.rb:270: warning: parenthesize argument(s) for future version
          C:/Program Files/Google/Google SketchUp 7/Plugins/PutOnLayer.rb:78: warning: don't put space before argument parentheses
          (eval):1: warning: already initialized constant SU_MAJOR_VERSION
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:325: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:331: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:335: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Mark_31.rb:339: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Protractor.rb:154: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Startup_31.rb:58: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:325: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:437: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Tool_31.rb:653: warning: don't put space before argument parentheses
          C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6_Dir_31/Lib6Traductor_31.rb:47: warning: don't put space before argument parentheses
          (eval):3081: warning: parenthesize argument(s) for future version
          (eval):3104: warning: parenthesize argument(s) for future version
          key = Units
          value = 0.0
          key = StampOffset
          value = 12.0
          key = GridSpacingX
          value = 120.0
          key = SmooveRadius
          value = 360.0
          key = GridSpacingY
          value = 120.0
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          free_Command
          • fredo6F
            Thanks for signaling this.
            These are just harmless warnings about the ruby syntax.
            I fiexed them anyway, and it will go in a further version.
              Daniel S
              Fredo..
              I don´t know if this is the correct place for this request.
              Can be added something like this menu to LibFredo6?:
              (It is from: http://www.3skeng.com)
              This menu can be part of your plugins...
              I don´t know if your HoverSelect will be extended to select faces, groups, dimensions... but the idea is to have only one button on the toolbar and with a key you can see and select all the other options with the onscreen menu:
              Example for JPP tool:
              Daniel S
              • fredo6F
                Daniel,
                This is an interesting metaphor.
                There are however a few issues with the JPP suggestion, because it is not possble to drwa images (i.e. jpg) in a tool.
                For HoverSelect, I am not clear on what it would give on other entity types than edges. But this would be easy to derive (Edges are the most complex actually).
                  mfseeker
                  I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
                  • fredo6F
                    This might be because you did not install FreeScale or HoverSelect.
                    Actually, I arranged that, unless a script using LibFredo6 is used, the library itself is not loaded, in order not to pollute Sketchup, not even with the menu (except a very small bootstrap code). Remember that, alone, LibFredo6 does not provide any functionality.
                      mfseeker
                      I only wish it were that simple. I tried both with and without putting FreeScale in the Plugins folder. When FreeScale is in the folder, I get:
                      "Error Loading File FreeScale_Common.rb
                      (eval):1: uninitialized constant FreeScale::T6"
                      Where do I go from here?
                      • fredo6F
                        It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
                          mfseeker
                          Yes.
                          The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins"
                          The size is "3.03 KB (3,108 bytes)"
                          The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
                          • fredo6F
                            Then, I would suggest you resinstall with the Zip files, because your current settup is missing something, or files may not be in the right place.
                            For FreeScale, the footprint at the Sketchup Plugin Directory level should be
                            Although you don't really have to care, here is the inside. But the rule is not to modify or rename any of the files.
                            I hope this helps.
                              mfseeker
                              You were right, of course. I was missing files. Once, I found the latest I was able to install and run FreeScale. Thanks so much for your help.
                              The reason I found your wonderful plugin in the first place was that I was looking for a way to model bending 1 1/2" x 1 1/2" x 78" vertical wooden elements so that their tops would be offset in both the x and y directions by perhaps 4", creating a gentle bow.
                              When I try the Radial bending tool, what I get is not a curved bend (similar to the one shown in the tool's icon) but a skewing. The documentation didn't help me. What am I missing?
                                mfseeker
                                Ah, I found the video. Bend works with embedded slice F4. Thanks.
                                  mpowell1234567890
                                  Wow! This plugin is amazing. Love it a lot - very easy to use too. When is the next update?
                                  [Edit - 04 May 09 - 23:00 CET-> LibFredo6 3.1f]
                                  bug fixing for Mac compatibility and updated Italian translation. Required by FreeScale 2.0f. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                                  [Edit - 28 Apr 09 - 22:20 CET-> LibFredo6 3.1e]
                                  bug fixing required by FreeScale 2.0e. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                                  [Edit - 17 Apr 09 - 06:05 CET-> LibFredo6 3.1d]
                                  bug fixing required by FreeScale 2.0d. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                                  [Edit - 11 Apr 09 - 16:25 CET-> LibFredo6 3.1c]
                                  various bugs fixed and some small evolutions required by FreeScale 2.0c.
                                  NOTE: again, download the zip file, Open it, then Select All, then Extract in the Sketchup Plugins folder, answering YES to any request for replacing files. This way you are sure to recreate the proper folder hierarchy.
                                  [Edit - 01 Apr 09 - 08:30 CET-> LibFredo6 3.1b] various bugs fixed and some small evolutions required by FreeScale 2.0b. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                                  LibFredo6 is a Shared Library which is used by some of my scripts. The first one to use it is FreeScale. It used to be called LibTraductor in previous times.
                                  Version 3.1 or higher is necessary to run FreeScale 2.0
                                  As a user, you should not bother too much, except to install it and respect the versions required by the Plugins. The current version of LibFredo6 is 3.1 (so 31 in integer form). I maintain backward compatibility so plugins using an older version of LibFredo6 should work with a new version.
                                  LibFredo6 takes care, among others, of enriching the plugin with a few capabilities:
                                  • Default parameters
                                  • Language translation via external files (please, read the doc if you wish to contribute)
                                  • Extra information and external links available in the “About…” box and menus
                                  LibFredo6 installs a submenu “LibFredo6 Settings…” in the Sketchup Windows menu. It contains a command to set the language preferences, to set a few default parameters (inference colors) and to access the documentation (as a PDF).
                                  • fredo6F
                                    NEW VERSION 3.2a
                                    Needed for for RoundCorner 2.0 (and compatible for FredoScale and HoverSelect).
                                    see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                                      matteo
                                      Thank you very much for this essential tool.
                                      hire me: http://www.nonsolo3d.it/ !
                                      • Bob JamesB
                                        Bob James
                                        I can find no place to download 3.2a
                                        • B
                                          BTM
                                          … Bottom of first post of this thread.
                                          • Bob JamesB
                                            Bob James
                                            Clicking on that just takes me back the same page ❓
                                            • 115
                                            • 116
                                            • 2 / 116
