    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
      cool to know that! ovoid some circular headaches โ˜€
      • free agentF Offline
        free agent
        @paulside said:
        Come on, Own up, how many of us have tried to orbit a jpg ! ๐Ÿคฃ
        jeez ive tried to orbit word documents ๐Ÿค“
        • david_hD Offline
          david_h
          @gaieus said:
          How about creating only "dummy" or "proxy" components?
          So what is the best method for Proxy-ing? To create a 2 layers of different components and toggle each one in a scene or is it to reload and displace the proxy via "RELOAD" when it comes time to render?
          Just Curious since I am dealing with that issue as we speak.
          David_H
            ...So what is the best method for Proxy-ing? To create a 2 layers of different components and toggle each one in a scene or is it to reload and displace the proxy via "RELOAD" when it comes time to render?
            Well, I don't think there's a general and always "true" answer to that. It would definitely depend on the particular model, the purpose, the workflow, even additional software (like renderers that can use SU proxies and instancing) etc.
            • david_hD Offline
              david_h
              That's what I was a-feared of.
              You know . .. of all the answers to life's questions. . .
              "well, that depends"
              has to be the least satisfying of them all. Thanx for the response anyway.
              ๐Ÿ’š
              so what is the most satisfying?
                Okay, I'll make a couple of short examples (but then I'll also split these posts off here and combine them with that). Is that okay? ๐Ÿ˜‰
                The best would be of course, if others could also add some examples from their field of profession and workflow.
                  Tekkybot
                  ah, heres some of my best duh moments. learning how to use groups/componenets, understanding the outliner, learning to use xray when after using follow me to clean up a curved model, and my fav duh so far, (this one stumpped me for months!) drawing on top of shapes with the pencil tool when things are made into groups/components to make model building easier and more precise.
                    Because you have internal faces which uses those edges?
                      This arrives when you make PushPull + CTRL ๐Ÿ˜‰
                      But you must clean after so...Duhduh above! ๐Ÿ˜„
                        Another one: after a Catmull Clark Subdivision ๐Ÿ’šimpossible.jpg
                        An headache for orient faces all in the same color ๐Ÿ˜ฎ
                        Solution one click!: Same than above! ๐Ÿ˜‰
                        Plugin Remove Inner faces then Right Click / Plugin "Orient Face" on a White face ๐Ÿ˜Ž
                          Not a recent but a famous! ๐Ÿ’š
                          The "after effect" ๐Ÿ˜’
                          Quasi all function in SU can be modify just after used it! ๐Ÿ˜ฎ
                          Draw any line (circle... etc) in the good direction then type on the numeric keyboard measure wanted...
                          ...and... miracle! ๐Ÿ’š
                          This is valuable for quasi all functions Move, Scale etc... ๐Ÿค“
                          • ToboboT Offline
                            Tobobo
                            I've been using SU since V1 and the biggest du'h was when Coen said โ€˜if you want to delete loads around a set of geometry that you want to keep the use the +/- option on the select tool and this deselects the geometry you want and selects the stuff you want to delete.โ€™ Which was on the @last forums so V5 ๐Ÿ˜ณ
                            Toby
                            Philippians 4:13
                              Indeed different (and endless numbers of) selection tricks is a kind of "art" which can sped up one's modelling workflow big time.
                                http://forums.sketchucation.com/viewtopic.php?f=15&t=22487
                                  arklandesign
                                  hehe .....This is a funny and informative thread at the same time...
                                  I have one... discovered by mistake yesterday.
                                  If one is in a complicated model and want to focus attention to a particular part of the model, one can double click on the scroll wheel at the point one is interested in and that will centre that point in the middle of the screen....making orbiting even easier.
                                    Doh... ๐Ÿ˜•
                                    I didn't know that.
                                    But at least now I understand why my models "jump" from time to time - I obviously (accidentally) double click with my mouse. ๐Ÿ˜ณ
                                      Tricky! โ˜€
                                      Maybe there is another thing wiht the triple click on the Wheel! ๐Ÿ˜ฎ
                                      • plot-parisP Offline
                                        plot-paris
                                        now it makes sense at last... its me, not a buggy SketchUp ๐Ÿ˜ณ
                                        another one: I am currently working on a fairly complex model. lots of nested groups...
                                        I was somewhere deep down on the hierarchy, modeling on some walls, when suddenly all newly created geometry turned transparent. when I painted another colour to the faces, they ceased being transparent.
                                        I checked the default material in the styles editor... you can't even set a transparency value there.
                                        I closed SketchUp and reopened it. still the same.
                                        I copied the whole model into a new SketchUp file. yet again: all newly created geometry turned transparent...
                                        ... and then it hit me... at some point while modelling and texturing, I must have accidentally painted over the parent-group with a glass material. most of the geometry within this group was supposed to be a stone wall, therefore a texture applied directly to the geometry. when I now created some new faces, these were coloured with the default material of course... but the transparent glass material on the group overwrote it...
                                        how can someone be soooo slow, it took me almost 15 minutes to find out. I had to hit the Homer button twice!!! ๐Ÿ˜ณ
                                        • broomstickB Offline
                                          broomstick
                                          my duh moment:
                                          when you rotate something, and you touch the rotation tool that appears on screen, the rotation will snap on the simbols of the rotation tool.
                                          If you change the rotation snaps, the rotation tool changes consequently.
                                          very, very duh
                                            Gruff
                                            More of an Ahh! than a Duh!
                                            1. Discovered that ALT-Push/Pull will move a loose planar face in the face normal
                                            I find I need to create duplicate parallel faces offset from the body a lot.
                                            1. To do this I use CTRL-Push/Pull to make a copy extrude.
                                              Rotate the model view 90 degrees to the face normal
                                              then use a right to left select window to select the extruded side faces,
                                              then press the Delete key.
                                            I'm left with a face normal to and inline with the original at a distance.
                                            Resistance is .... Character Forming. Grin
                                            • 34
                                            • 35
                                            • 4 / 35
