    New API doc - typos and questions
    370 Posts 35 Posters 256.4k Views 35 Watching
      I see that behaviour as well: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=17150&hilit=+explode
      • Chris FullmerC Offline
        http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#add_polygon
        add polygon detail just repeats the add_point example.
        • scottliningerS Offline
          scottlininger
          @thomthom said:
          Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
          But onOpen works.
          Thomas,
          I'm about to push an update with all of the recent changes above. This one puzzled me, though. The ToolsObserver examples work fine for me on the onOpen and onClose. Can you clarify what "dead as well" means? πŸ˜„
          Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
          Tig, these action codes only work on the PC, but I still think I'll add them to the docs. There are some cool things in there that PC-only shops might need.
          Thanks, guys! New update should be live in the next day or so.
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
            scottlininger
            @thomthom said:
            We could ask Coen to have a strike-through BBC tag. [deleted] or something...
            Or, put a big fat FIXED in bold green. Might be easier.
            Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
            • Scott Lininger
              Dead as in: I never see it trigger.
                ToolObservers? How are they related to onClose and onOpen?
                  remus
                  I'll ask gai if he can make you a mod for the ruby forum πŸ‘
                    scottlininger
                    I meant to say, InstanceObservers. πŸ˜›
                    In any case, they fire fine for me.
                    • Scott Lininger
                      Jim
                      Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
                      If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
                        Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
                        πŸ˜†
                          Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
                            scottlininger
                            Give this a go... Could be that we're seeing a sneaky bug...
                            class MyInstanceObserver < Sketchup;;InstanceObserver
                               def onOpen(instance)
                                 UI.messagebox("onOpen; " + instance.to_s)
                               def onClose(instance)
                                 UI.messagebox("onClose; " + instance.to_s)
                            model = Sketchup.active_model
                            model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
                            • Scott Lininger
                              Nopes. Doesn't work.
                                Jim
                                Works for me...
                                  Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                                  Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                                    Jim
                                    Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                                      Well I'll be! After disabling DCs the onClose even works!
                                      btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                                        scottlininger
                                        Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                                        πŸ˜„
                                        -Scott Lininger
                                        • Scott Lininger
                                          scottlininger
                                          From Didier's post:
                                          301 Moved Permanently
                                          (www.sketchucation.com)
                                          Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                                          • Scott Lininger
                                            avariant
                                            BoundingBox.valid?
                                            text says
                                            status
                                                true if the bounding box is valid (not empty), false if it is not valid (empty)
                                            but the code example has it exactly the opposite:
                                             bbox = Sketchup.active_model.bounds
                                             status = bbox.valid?
                                             if (status)
                                               # If true, bounding box is empty.
                                             else
                                               # If false, bounding box contains entities.
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
