    My Rubik's Cube model
    46 Posts 7 Posters 5.2k Views 7 Watching
      sepo
      Sun is way too strong, make it around 32(dark slider) or less, make the floor colour darker.
      You can have GI only render if you switch of sun. You get nice soft render.
      To add lines you need to save your Black and white SU image 2 times bigger at least. In your case maybe even more as you are using eval version of Podium. Reduce line drawing to same size in Photoshop and use blending (say 20% opacity of line drawing layer) in Photoshop or similar.
      • K
        Kus
        OK... here I got rid of the sun and darkened the floor. But I don't have PS, so I left it at that 😞
          sepo
          There are a lot of free image editors...Irfan view is one of them.
          • K
            Kus
            well... keep in mind that I am on a Mac... and I think, that IrfanView is PC only
            • mitcorbM
              mitcorb
              Can GIMP be used in lieu of Photoshop for the treatments you suggest? Gimp is open source.
              • K
                Kus
                Well I do have GIMP, but I can't do anything worth mentioning... so if any1 knows how... plz tell
                EDITED: What else should I do to make the model look better and start with the animation??
                • K
                  Kus
                  Can someone give me some advice. I am kind-of board and want to do something in SU 😉
                  Maybe witch plugin do I need do I need to make the animation suggested by Ecuadorian
                  • E
                    Ecuadorian
                    Hi, it's a plug-in called Sketchy Physics. There's a whole sub-forum about it here in SketchUcation:
                    http://www.sketchucation.com/forums/scf/viewforum.php?f=61
                    -Miguel Lescano
                    • K
                      Kus
                      TY... I googled for a Mac version, but could not find it... is there such a thing??
                      • jeff hammondJ
                        try seashore:
                        http://seashore.sourceforge.net/index.php
                        it's based on gimp but doesn't require X11... it's simpler than gimp too but it will do the overlays that these guys are talking about.
                        [EDIT] and here's the link to download the latest version of sketchyphysics for mac..
                        Error 404 (Not Found)!!1
                        (sketchyphysics2.googlecode.com)
                        • K
                          Kus
                          hey... when I try and play the SletchyPhysics the cube automatically deforms. Can anyone tell me why??
                          • E
                            Ecuadorian
                            Do you have intersecting objects? I think you'd have better luck making Sketchy Physics ignore the little plastic pieces that keep the cubelets together. This way the cube should stay together until it hits the ground or another static object.
                            -Miguel Lescano
                            • K
                              Kus
                              ye... that is it... 1 more thing... I made the center piece 1 component. But when it hits the floor it goes half trough. What about that?
                              • E
                                Ecuadorian
                                Mmmm... try making each of the 5 parts of the center piece a separate group, not a component, and then grouping them all together.
                                -Miguel Lescano
                                • E
                                  Ecuadorian
                                  The simulation should work like this:
                                  [flash=425,344:10eiopeu]http://www.youtube.com/v/JxCEmqnvD2Y[/flash:10eiopeu]
                                  -Miguel Lescano
                                  • K
                                    Kus
                                    Nice video!!! well... i have done all that, but when I press play it is still deformed 😞
                                    can you maybe send me the model that you have made??
                                    • E
                                      Ecuadorian
                                      Sure, I did it in Sketchy Physics 1, not sure if it will work if you have another version installed.
                                      I used WinRAR to compress it because the ZIP file was almost twice the size.
                                      If you don't have WinRAR installed,
                                      http://download.cnet.com/WinRAR/3000-2250_4-10007677.html
                                      rubik_crash010.rar
                                      -Miguel Lescano
                                      • E
                                        Ecuadorian
                                        By the way, this is a really nice introduction to SketchyPhysics:
                                        http://sketchyphysicstutorial.googlepages.com/
                                        And don't forget to visit the SP sub-forum. Lots of SP geniuses over there. I'm almost as new as you to Sketchy Physics.
                                        -Miguel Lescano
                                        • jeff hammondJ
                                          unrarX is great with .rar files on macs..
                                          http://www.unrarx.com/
                                          (winrar doesn't work)
                                          • B
                                            BTM
                                            ...That, or export to jpg, and find a program that can put them all into a video. (I still can't find one...)
                                            • 2 / 3
