    My Rubik's Cube model
    46 Posts 7 Posters 4.2k Views 7 Watching
      Kus
      Can someone give me some advice. I am kind-of board and want to do something in SU 😉
      Maybe witch plugin do I need do I need to make the animation suggested by Ecuadorian
      • E Offline
        Ecuadorian
        Hi, it's a plug-in called Sketchy Physics. There's a whole sub-forum about it here in SketchUcation:
        http://www.sketchucation.com/forums/scf/viewforum.php?f=61
        -Miguel Lescano
          Kus
          TY... I googled for a Mac version, but could not find it... is there such a thing??
          • jeff hammondJ Offline
            @kus said:
            well... keep in mind that I am on a Mac... and I think, that IrfanView is PC only
            try seashore:
            302 Found
            (seashore.sourceforge.net)
            it's based on gimp but doesn't require X11... it's simpler than gimp too but it will do the overlays that these guys are talking about.
            [EDIT] and here's the link to download the latest version of sketchyphysics for mac..
            Error 404 (Not Found)!!1
            (sketchyphysics2.googlecode.com)
              Kus
              hey... when I try and play the SletchyPhysics the cube automatically deforms. Can anyone tell me why??
              • E Offline
                Ecuadorian
                Do you have intersecting objects? I think you'd have better luck making Sketchy Physics ignore the little plastic pieces that keep the cubelets together. This way the cube should stay together until it hits the ground or another static object.
                -Miguel Lescano
                  Kus
                  ye... that is it... 1 more thing... I made the center piece 1 component. But when it hits the floor it goes half trough. What about that?
                  • E Offline
                    Ecuadorian
                    Mmmm... try making each of the 5 parts of the center piece a separate group, not a component, and then grouping them all together.
                    -Miguel Lescano
                    • E Offline
                      Ecuadorian
                      The simulation should work like this:
                      [flash=425,344:10eiopeu]http://www.youtube.com/v/JxCEmqnvD2Y[/flash:10eiopeu]
                      -Miguel Lescano
                        Kus
                        Nice video!!! well... i have done all that, but when I press play it is still deformed 😞
                        can you maybe send me the model that you have made??
                        • E Offline
                          Ecuadorian
                          Sure, I did it in Sketchy Physics 1, not sure if it will work if you have another version installed.
                          I used WinRAR to compress it because the ZIP file was almost twice the size.
                          If you don't have WinRAR installed,
                          http://download.cnet.com/WinRAR/3000-2250_4-10007677.html
                          rubik_crash010.rar
                          -Miguel Lescano
                          • E Offline
                            Ecuadorian
                            By the way, this is a really nice introduction to SketchyPhysics:
                            http://sketchyphysicstutorial.googlepages.com/
                            And don't forget to visit the SP sub-forum. Lots of SP geniuses over there. I'm almost as new as you to Sketchy Physics.
                            -Miguel Lescano
                              unrarX is great with .rar files on macs..
                              http://www.unrarx.com/
                              (winrar doesn't work)
                                BTM
                                ...That, or export to jpg, and find a program that can put them all into a video. (I still can't find one...)
                                  Kus
                                  I downloaded a MacRar... or something... well I am getting the hang of this, but I don't know why I cant export it into a video. The options I get are: Skp, Png and Jpg...
                                  How did you get it into a video?? Maybe with a screen cam??
                                  PS: I spotted another problem... because the small pieces on the Cubies are set to Ignore, when they hit the ground, they go strait trough... What can I do about that??
                                    Kus
                                    I didn't find any program like that. The animation it self is quite nice. That plugin ROCKS 😎
                                    • E Offline
                                      Ecuadorian
                                      I used Camstudio to record the onscreen action.
                                      Yes, there's that problem with the cubelets. As I said, I'm as new as you to SketchyPhysics. Actually, I followed the tutorial a couple days ago just to be able to break this cube. I was using SP1 but I think in SP3 there's something called "breakable joints" that could prove useful in this case.
                                      You can make a video from a JPG sequence with VideoMach.
                                      -Miguel Lescano
                                        these are mac users... neither of those programs have os x versions
                                        • E Offline
                                          Ecuadorian
                                          There's always Bootcamp. 😉
                                          -Miguel Lescano
                                            never 😡 .. i wouldn't want any of that junk on my system 😄
                                            Snapz, Screenium, iShowU, are a few of the better screen capture apps.. Jing has a free version.
                                            with quicktime, you can make a video out of sequenced jpegs...
                                            • 2 / 3
