    My Rubik's Cube model
    46 Posts 7 Posters 5.2k Views 7 Watching
    • mitcorbM
      mitcorb
      Can GIMP be used in lieu of Photoshop for the treatments you suggest? Gimp is open source.
      • K
        Kus
        Well I do have GIMP, but I can't do anything worth mentioning... so if any1 knows how... plz tell
        EDITED: What else should I do to make the model look better and start with the animation??
        • K
          Kus
          Can someone give me some advice. I am kind-of board and want to do something in SU šŸ˜‰
          Maybe witch plugin do I need do I need to make the animation suggested by Ecuadorian
          • E
            Ecuadorian
            Hi, it's a plug-in called Sketchy Physics. There's a whole sub-forum about it here in SketchUcation:
            http://www.sketchucation.com/forums/scf/viewforum.php?f=61
            -Miguel Lescano
            • K
              Kus
              TY... I googled for a Mac version, but could not find it... is there such a thing??
              • jeff hammondJ
                @kus said:
                well... keep in mind that I am on a Mac... and I think, that IrfanView is PC only
                try seashore:
                http://seashore.sourceforge.net/index.php
                it's based on gimp but doesn't require X11... it's simpler than gimp too but it will do the overlays that these guys are talking about.
                [EDIT] and here's the link to download the latest version of sketchyphysics for mac..
                Error 404 (Not Found)!!1
                (sketchyphysics2.googlecode.com)
                • K
                  Kus
                  hey... when I try and play the SletchyPhysics the cube automatically deforms. Can anyone tell me why??
                  • E
                    Ecuadorian
                    Do you have intersecting objects? I think you'd have better luck making Sketchy Physics ignore the little plastic pieces that keep the cubelets together. This way the cube should stay together until it hits the ground or another static object.
                    -Miguel Lescano
                    • K
                      Kus
                      ye... that is it... 1 more thing... I made the center piece 1 component. But when it hits the floor it goes half trough. What about that?
                      • E
                        Ecuadorian
                        Mmmm... try making each of the 5 parts of the center piece a separate group, not a component, and then grouping them all together.
                        -Miguel Lescano
                        • E
                          Ecuadorian
                          The simulation should work like this:
                          [flash=425,344:10eiopeu]http://www.youtube.com/v/JxCEmqnvD2Y[/flash:10eiopeu]
                          -Miguel Lescano
                          • K
                            Kus
                            Nice video!!! well... i have done all that, but when I press play it is still deformed šŸ˜ž
                            can you maybe send me the model that you have made??
                            • E
                              Ecuadorian
                              Sure, I did it in Sketchy Physics 1, not sure if it will work if you have another version installed.
                              I used WinRAR to compress it because the ZIP file was almost twice the size.
                              If you don't have WinRAR installed,
                              http://download.cnet.com/WinRAR/3000-2250_4-10007677.html
                              rubik_crash010.rar
                              -Miguel Lescano
                              • E
                                Ecuadorian
                                By the way, this is a really nice introduction to SketchyPhysics:
                                http://sketchyphysicstutorial.googlepages.com/
                                And don't forget to visit the SP sub-forum. Lots of SP geniuses over there. I'm almost as new as you to Sketchy Physics.
                                -Miguel Lescano
                                • jeff hammondJ
                                  unrarX is great with .rar files on macs..
                                  http://www.unrarx.com/
                                  (winrar doesn't work)
                                  • B
                                    BTM
                                    ...That, or export to jpg, and find a program that can put them all into a video. (I still can't find one...)
                                    • K
                                      Kus
                                      I downloaded a MacRar... or something... well I am getting the hang of this, but I don't know why I cant export it into a video. The options I get are: Skp, Png and Jpg...
                                      How did you get it into a video?? Maybe with a screen cam??
                                      PS: I spotted another problem... because the small pieces on the Cubies are set to Ignore, when they hit the ground, they go strait trough... What can I do about that??
                                      • K
                                        Kus
                                        I didn't find any program like that. The animation it self is quite nice. That plugin ROCKS šŸ˜Ž
                                        • E
                                          Ecuadorian
                                          I used Camstudio to record the onscreen action.
                                          Yes, there's that problem with the cubelets. As I said, I'm as new as you to SketchyPhysics. Actually, I followed the tutorial a couple days ago just to be able to break this cube. I was using SP1 but I think in SP3 there's something called "breakable joints" that could prove useful in this case.
                                          You can make a video from a JPG sequence with VideoMach.
                                          -Miguel Lescano
                                          • jeff hammondJ
                                            these are mac users... neither of those programs have os x versions
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 3
