My Rubik's Cube model
Here... my first and second render in podium... Just set reflection to 10 and pressed render
I would like that you tell me what can be done better and how to do it... It would be such a big help step...
line overlays... can you explain a little bit more??
Sun is way too strong, make it around 32(dark slider) or less, make the floor colour darker.
You can have GI only render if you switch of sun. You get nice soft render.
To add lines you need to save your Black and white SU image 2 times bigger at least. In your case maybe even more as you are using eval version of Podium. Reduce line drawing to same size in Photoshop and use blending (say 20% opacity of line drawing layer) in Photoshop or similar. -
OK... here I got rid of the sun and darkened the floor. But I don't have PS, so I left it at that
There are a lot of free image editors...Irfan view is one of them.
well... keep in mind that I am on a Mac... and I think, that IrfanView is PC only
Can GIMP be used in lieu of Photoshop for the treatments you suggest? Gimp is open source.
Well I do have GIMP, but I can't do anything worth mentioning... so if any1 knows how... plz tell
EDITED: What else should I do to make the model look better and start with the animation??
Can someone give me some advice. I am kind-of board and want to do something in SU
Maybe witch plugin do I need do I need to make the animation suggested by Ecuadorian
Hi, it's a plug-in called Sketchy Physics. There's a whole sub-forum about it here in SketchUcation:
http://www.sketchucation.com/forums/scf/viewforum.php?f=61 -
TY... I googled for a Mac version, but could not find it... is there such a thing??
try seashore:
http://seashore.sourceforge.net/index.php
it's based on gimp but doesn't require X11... it's simpler than gimp too but it will do the overlays that these guys are talking about.
[EDIT] and here's the link to download the latest version of sketchyphysics for mac..
hey... when I try and play the SletchyPhysics the cube automatically deforms. Can anyone tell me why??
Do you have intersecting objects? I think you'd have better luck making Sketchy Physics ignore the little plastic pieces that keep the cubelets together. This way the cube should stay together until it hits the ground or another static object.
ye... that is it... 1 more thing... I made the center piece 1 component. But when it hits the floor it goes half trough. What about that?
Mmmm... try making each of the 5 parts of the center piece a separate group, not a component, and then grouping them all together.
The simulation should work like this:
[flash=425,344:10eiopeu]http://www.youtube.com/v/JxCEmqnvD2Y[/flash:10eiopeu]
Nice video!!! well... i have done all that, but when I press play it is still deformed
can you maybe send me the model that you have made??
Sure, I did it in Sketchy Physics 1, not sure if it will work if you have another version installed.
I used WinRAR to compress it because the ZIP file was almost twice the size.
If you don't have WinRAR installed,
http://download.cnet.com/WinRAR/3000-2250_4-10007677.html
By the way, this is a really nice introduction to SketchyPhysics:
http://sketchyphysicstutorial.googlepages.com/And don't forget to visit the SP sub-forum. Lots of SP geniuses over there. I'm almost as new as you to Sketchy Physics.
