    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.3m Views 342 Watching
    • fredo6F Offline
      You have the option to do or not the clean up by calling the Slicing parameter dialog box (pressing TAB or contextual menu), but the choice must be made before, I am afraid.
      The only thing I'll do is also to add the slicing parameters in the Default settings, so that your default choice are persistent across sessions.
      PS: by the way, your case of texturing is, as I remember, why I did not do it in the first place (and then forgot to offer it as an option).
        tomislavm
        THANK YOU Fredo!!!!!!
        How can You make something that good for free?
          @Thomislavm: Maybe you don't know the pleasure of coding and after glory has no price 😉
          • E Offline
            Ecuadorian
            You can also read the interview with Fredo in CatchUp magazine:
            http://www.sketchucation.com/old/forums/scf/catchup/2008/may/p45-46/index.htm
            -Miguel Lescano
            • FrederikF Offline
              Frederik
              Thank you so much, Frederic...!!
              http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
              Cheers
              Kim Frederik
              • W Offline
                watkins
                Dear Fredo,
                You are one generous and talented man. Thank you!
                Regards,
                Bob
                  davidheim1
                  I have a Mac running OS X 10.4. I can download FreeScale but can't install it. I seem to be missing a plug in folder. What am I doing wrong? What do I need to do to get FreeScale to run on a Mac?
                  Thanks.
                  David Heim
                    David, have you installed other plugins?
                    If you want, call me. I'll walk you through it.
                    Dave
                      I thought I was so smart I just installed Freescale and LibFredo on my Mac. I got the following message on starting up SketchUp.
                      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LIBFREDO6_Dir_31/Lib6Core_31.rb:298:in mkdir': Permission denied - /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/DEFPARAM_DirError Loading File ZLoader__FreeScale.rb /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LIBFREDO6_Dir_31/Lib6Core_31.rb:298:in mkdir': Permission denied - /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/DEFPARAM_Dir
                      I assume this is a problem related to permissions on my Mac but I don't see where to change that. Any help would be appreciated. Thank you.
                      Edit: Problem solved. I had to give myself administrator privileges.
                      • EarthMoverE Offline
                        EarthMover
                        Finally had a second from the chaos of spring in the landscape world to pop on here and imagine my surprise to find this precious jewel, hatched by the amazing mind of Fredo6!!! Thanks so much for your generosity in giving away your most valuable time.
                        The bend tool is mind blowing....easier than bonzai's. Makes me think that potentially a path deformation plugin is now possible.
                        Content Creator at Skapeup
                        • I Offline
                          idraft
                          😮 my god, this will be fantastic! thank you very much indeed. Cant wait to give it a bash.
                          cheers Jeff
                          • takesh hT Offline
                            takesh h
                            Hi Fredo, here is Japanese language pack for your FreeScale plugin.
                            Funny thing is that I couldn't find where many of my translations are used.
                            I also noticed none of tooltips or most of context menu (shown in the attached pic) are not translated, at least on Mac OSX.
                            These are the first place where people get ideas of what the ruby is about, so I think they should be translated too, no?
                            Thanks for all your hard work to help SU catch the current of the world.
                            Without people like you, SU would have been obsolete software long time ago.
                            LibFredo6_JA.lang.zip
                              cyan.archnet
                              Hats off to you!, truly one "must have" plugin, THANKS A LOT!
                              • alexschreyerA Offline
                                alexschreyer Extension Creator
                                Congrats and thanks from me, too. I am having fun with the new tools...
                                Author of "Architectural Design with SketchUp":
                                http://sketchupfordesign.com/
                                  leixing
                                  Dear Fredo:
                                  I found a bug: When I installed the plug-ins, my Right-click menu is not working well---"some botton are gray", especially the plug-in "proper_animation.rb". I do not know why is it so, whether your code on this, please help me . someone happened this?
                                  thank you very much!
                                  the pic at last:
                                  RB:proper_animation.rb
                                  • F Offline
                                    Fletch
                                    Fredo, is there a way I can change your shortcuts F4 and F5 to something else? I have used these for years for other things in SU (toggling parallel/perspective cam= F4 and toggling xray mode is F5)
                                    so the twist tool only turns my group around... not actually twisting anything.
                                    Fletch
                                    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                      You can configure these yourself. Tools->Fredo Collection->FreeScale->Default Parameters.
                                        gata
                                        To expand upon Chris Fullmer's insight, one of the things Google did was release a 'free' version of SU. That free stuff brought in a lot of talented plugin coders from all over the world who applied their coding magic to add extra functionality to this program.
                                        SU developers can and should concentrate their energy on making this the best rendering engine which people can customize to best fit their needs.
                                        Fredo, your coding efforts shouldn't be free. Google can give out a free version as it helps draw in people to make SKP a popular and dominating extension, and for more people to use their other products and services. Like @last and many other software developers, many plugin developers deserve to earn money for their effort too.
                                          Tusen takk, ThomThom
                                            Jörg
                                            Fredo, I´m speechless.
                                            Your my hero.
                                            You are not from this world.
                                            Thank you very, very much.
                                            This plugin ist absolutely terrifik.
                                            THANK YOU!!!!
                                            Jörg
                                            • 11
                                            • 56
                                            • 57
                                            • 9 / 57
