    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.2m Views 345 Watching
    • T
      Teezer
      Wow! I'll be playing with this for the rest of the weekend. 🎉 Thanks!
      Real life is just another website, albeit a rather boring one.
      R 1 Reply Last reply
        Matt666
        ... I am speechless.. Incredible... 😲 😮 😍
        Thank you soooo much for these awesome new tools Fredo!!
        Frenglish at its best !
        My scripts
          Daniel S
          Thank you Fredo!!!
          This plugin is amazing.
          I love the Stretch tool!!
          Thank you again,
          Daniel S
            Rodentpete
            😮 👍 We need to have a "we're not worthy" smily on here!
            Google - learn from the master!
            • simon le bonS
              simon le bon
              http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/AhRrrr.gif
              Fredo,
              Are you coming from Mars? !
              Does your head measures 2 meters diameter?
              Your tools are simply fantastic!
              Your generosity doesn't belong to this world..
              simon
                Matt666
                +1000!!!
                My scripts
                • N
                  numerobis
                  THANK YOU Fredo!!!!!! 😍
                  what a fantastic development!
                  +1
                  • jeff hammondJ
                    hey fredo, i thought you said this wouldn't work with the new plugin 😄
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17151&start=30
                    [flash=425,344:2apxp89z]http://www.youtube.com/v/OSu_qPPnvRA&hl=en&fs=1[/flash:2apxp89z]
                    one thing, f4 on a mac is used for the dashboard however, i'm able to invoke the slicer by opening the tab key dialog.
                    Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                    • chippwaltersC
                      chippwalters
                      Truly a most remarkable plugin. And so sensible as well. Congratulations on not only brillant scripting, but wonderful imagination as well! 😄
                      Currently working with Cross-Reality technologies
                      • Chris FullmerC
                        Excellent Fredo!, I'm going to rush home and check this one out,
                        • G
                          gaganraj
                          the ruby masters make me realize how amazing a program sketchup can/should be. THis addition is awsome!
                          • L
                            leixing
                            i just say : thank you very very very very very much!
                            rise !
                            • boofredlayB
                              boofredlay
                              Very cool, thank you!
                              I have a couple of questions.
                              1. I use F4 for reverse faces as a keyboard shortcut therefore it is not working with Freescale at the moment. How can I change your script to accept another keystroke, like F12 for example?
                                (I did notice on "Bend" however if I press Tab to adjust the parameters then it will activate the slicer).
                              2. I notice in the Youtube video you have 13 icons on the toolbar. Mine only shows 10 and one that I have you don't. I also don't see an option to add or delete any in the Default Parameters Dialog.
                              Thanks.
                              • MALAISEM
                                MALAISE
                                Fredo,
                                (Rien de très nouveau ! encore un plugin inutile qui va encombrer la barre d'outils !)
                                ( 👍 )*10^n avec n variant de 1 à k, k : nombre de téléchargements du plugin!
                                MALAISE 😄
                                • G
                                  gamore
                                  Thank you Fredo6
                                  FreeScale 2.0a is quite great!
                                    remus
                                    A very slight aside,
                                    these are the only toolbars i think necessary to have open:
                                    As you notice they are pretty much all yours, i think it says a lot about the quality of your plugins 👍
                                    • fredo6F
                                      Thanks.
                                      You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
                                      To activate the slicer and divider, you also have the contextual menus.
                                      • Jean-FrancoJ
                                        Jean-Franco
                                        What a plugin !!!
                                        Thank you Fredo, your great developments have really a special flavor.
                                        Again, special thanks to all great Ruby scripters here.
                                        Jean-Franco
                                          Et çà marche? 💚
                                          PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" 😉
                                          • StinkieS
                                            Stinkie
                                            Thank you. This is most impressive.
                                            • 58
                                            • 59
                                            • 1 / 59
