    Image export size test
    27 Posts 10 Posters 4.0k Views 10 Watching
    • DanielD
      Daniel
      WORK:
      Intel Core 2 Duo 2.66 GHz
      3GB RAM
      NVIDIA GeForce 8800 GT
      XP Pro
      SU Pro 7.0.10247
      Image size: 5225 x 2878
      HOME:
      Intel Core 2 Quad Q6600 2.40 GHz
      4GB RAM
      NVIDIA GeForce 8600 GT
      XP Pro
      SU Pro 7.0.10247
      Image size: 5550 x 3083
      LAPTOP:
      Intel Core 2 Duo T7500 2.20 GHz
      4GB RAM
      NVIDIA GeForce 8600M GT
      XP Pro
      SU Pro 7.0.10247
      Image size: 5000 x 2656
      My avatar is an anachronism.
      • jeff hammondJ
        weird thing though: lots of different aspect ratios coming out..
        what's dictating that?
        [edit] nevermind.. it's just using the same aspect ratio as the sketchup window on whoever's computer. if you really wanted to get into it, everyone should be exporting at a certain ratio instead of locking to their window..
        • jeff hammondJ
          macpro quad:
          Processor: 2X- 2.66 dual-core intel xeon
          RAM: 7GB
          Graphic card and memory: geforce7300 GT 256MB
          OS: leopard 10.5.6
          SketchUp version: 7pro latest
          Width and height of your maximum exported image in pixels:
          10,000 x 6590
          crashed when i tried 12,000
          [edit] 14,250 x 9390 with AA off
          (28MB)
          • PixeroP
            Pixero
            So as a little first round up it seems that on Windows no one can export higher than 5650 width.
            On OSX its almost twice that with 10000 pixels wide.
            Has anyone tried increasing virtual memory in Windows to see what effect that has?
              remus
              From a theoretical point of view, i dont think changing virtual memory would help, as the limit is in sketchup itself i.e. SU is maxing out before it can use all the RAM available to it.
                Don't think it's the RAM. It's the maximum single chuck of memory it can address. If you don't have enough RAM it will page it out to the pagefile, but the limit is how much memory (note: not RAM) windows 32bit applications can handle.
                • DanielD
                  Daniel
                  I know from experience that virtual memory does make a slight difference. In fact, for this excercise, my office computer had VM set at 6,000 mb and the widest image I could get ws 5,000 - I increassed the VM to 200,000 and was able to get a 5,225 wide image.
                  I'll admit that most of this computer jargon goes over my head, but looking at my own results I have to conclude that it is a combination of the processors and the video card.
                    I think that the results for PC are ca max 5000-5500px wide with AA on. And I think this is where SU hits the max amount of memory it can allocate on 32bit systems. Variation due to environment differences; aspect ratio, background apps etc.
                    Had it been hardware we should have seen much larger differences. Not just a few hundred pixels.
                    What's interesting is that OSX SU exports much larger with AA. Is SU 32bit on OSX as well?
                    • jeff hammondJ
                      it must be.. the second export i posted is from a laptop i bought in 2003.. pre G5, pre 64bit
                        That's interesting how the architecture between PC ans OSX allows for different max export sizes. Another argument for SU going 64bit. ...at least compiled with Large Address Awareness marker.
                        • jeff hammondJ
                          well, if you have the following:
                          -absolutely nothing to do this weekend
                          -a test machine
                          -a knack for experimenting
                          -understand languages such as "memory_info.BaseAddress = g_last->top_reserved;"
                          then you could mess around with this:
                          http://www.genesys-e.de/jwalter/mix4win.htm
                            I check 3 out of four. Low level C programming goes swoosh! over my head.
                            • brodieB
                              brodie
                              Intel Core2 Quad Q9550 2.83GHz Processor
                              8.0 G RAM
                              nVidia Quadro FX 3700 512Mb
                              Windows Vista 64-bit
                              SU 7.0.8657
                              5800x3093 (AA on/Shadows on)
                              -Brodie
                                DavidMac
                                I know this is a very old thread by now, but I have found a way getting round these limits and exporting at any size you want.
                                It is here in the Tutorial forum:
                                "Exporting 2D graphics with NO size limit" http://forums.sketchucation.com/viewtopic.php?f=18&t=26527
                                I have also posted a second tutorial on exporting Alpha masks for your 2D exports.
                                "Creating an Alpha mask of your model for 2D graphic export" http://forums.sketchucation.com/viewtopic.php?f=18&t=26530#p228664
                                Bon appetit!
                                David Mac
                                • 2 / 2
