    Image export size test
    27 Posts 10 Posters 4.2k Views 10 Watching
      Processor: Intel Core2 Quad 9450 3.3ghz (OC)
      RAM: 8GB
      Graphics card: Nvidia Geforce 8800GT 512MB
      OS: Windows7 64bit
      SU Version: SketchUp 7 pro
      Maximum exported image:
      With AA: 5650x3081 pixels.
      Without AA: 9500x5180 pixels
      I found that when SU failed to export I often had to restart SU in order to successfully export again afterwards.
        Maximum exported image: 4951x2750 pixels in .png format if that matters...
        That might matter. Compressing the image require exptra calcualtiuons. And different compressions methods might give different results.
        That would also be interesting to see. If saving to a raw uncompressed bitmap allows you to export larger...
        • GaieusG
          Made the topic sticky. Will chime in (and test) when back home.
          • PixeroP
            Pixero
            Thomthom, interesting to see that you with double the amount of RAM and 64bit OS you can export approx the same max size as I can (with AA). One would think it would be much higher.
            • GaieusG
              Note that since SU is (only) a 32 bit application, it cannot utilize anything that's beyond it.
                Since SU is a 32bit application I'm still under the 32bit limitations even though I have a 64bit system... 😞
                • jeff hammondJ
                  the old workhorse...
                  mac 17"powerbook
                  Processor: 1.33 PowerPC G4
                  RAM: 1gb
                  Graphic card and memory: ATI mobility Radeon 9600 64MB
                  OS: tiger 10.4.11
                  SketchUp version: 6.4.120 p
                  Width and height of your maximum exported image in pixels.
                  9500 x 7055
                  (in just over 20 minutes πŸ˜† )
                  this pretty much shows the items in the list are irrelevant to image export size... well, except one of the entries πŸ˜‰
                  • DanielD
                    Daniel
                    WORK:
                    Intel Core 2 Duo 2.66 GHz
                    3GB RAM
                    NVIDIA GeForce 8800 GT
                    XP Pro
                    SU Pro 7.0.10247
                    Image size: 5225 x 2878
                    HOME:
                    Intel Core 2 Quad Q6600 2.40 GHz
                    4GB RAM
                    NVIDIA GeForce 8600 GT
                    XP Pro
                    SU Pro 7.0.10247
                    Image size: 5550 x 3083
                    LAPTOP:
                    Intel Core 2 Duo T7500 2.20 GHz
                    4GB RAM
                    NVIDIA GeForce 8600M GT
                    XP Pro
                    SU Pro 7.0.10247
                    Image size: 5000 x 2656
                    My avatar is an anachronism.
                    • jeff hammondJ
                      weird thing though: lots of different aspect ratios coming out..
                      what's dictating that?
                      [edit] nevermind.. it's just using the same aspect ratio as the sketchup window on whoever's computer. if you really wanted to get into it, everyone should be exporting at a certain ratio instead of locking to their window..
                      • jeff hammondJ
                        macpro quad:
                        Processor: 2X- 2.66 dual-core intel xeon
                        RAM: 7GB
                        Graphic card and memory: geforce7300 GT 256MB
                        OS: leopard 10.5.6
                        SketchUp version: 7pro latest
                        Width and height of your maximum exported image in pixels:
                        10,000 x 6590
                        crashed when i tried 12,000
                        [edit] 14,250 x 9390 with AA off
                        (28MB)
                        • PixeroP
                          Pixero
                          So as a little first round up it seems that on Windows no one can export higher than 5650 width.
                          On OSX its almost twice that with 10000 pixels wide.
                          Has anyone tried increasing virtual memory in Windows to see what effect that has?
                            remus
                            From a theoretical point of view, i dont think changing virtual memory would help, as the limit is in sketchup itself i.e. SU is maxing out before it can use all the RAM available to it.
                              Don't think it's the RAM. It's the maximum single chuck of memory it can address. If you don't have enough RAM it will page it out to the pagefile, but the limit is how much memory (note: not RAM) windows 32bit applications can handle.
                              • DanielD
                                Daniel
                                I know from experience that virtual memory does make a slight difference. In fact, for this excercise, my office computer had VM set at 6,000 mb and the widest image I could get ws 5,000 - I increassed the VM to 200,000 and was able to get a 5,225 wide image.
                                I'll admit that most of this computer jargon goes over my head, but looking at my own results I have to conclude that it is a combination of the processors and the video card.
                                  I think that the results for PC are ca max 5000-5500px wide with AA on. And I think this is where SU hits the max amount of memory it can allocate on 32bit systems. Variation due to environment differences; aspect ratio, background apps etc.
                                  Had it been hardware we should have seen much larger differences. Not just a few hundred pixels.
                                  What's interesting is that OSX SU exports much larger with AA. Is SU 32bit on OSX as well?
                                  • jeff hammondJ
                                    it must be.. the second export i posted is from a laptop i bought in 2003.. pre G5, pre 64bit
                                      That's interesting how the architecture between PC ans OSX allows for different max export sizes. Another argument for SU going 64bit. ...at least compiled with Large Address Awareness marker.
                                      • jeff hammondJ
                                        well, if you have the following:
                                        -absolutely nothing to do this weekend
                                        -a test machine
                                        -a knack for experimenting
                                        -understand languages such as "memory_info.BaseAddress = g_last->top_reserved;"
                                        then you could mess around with this:
                                        http://www.genesys-e.de/jwalter/mix4win.htm
                                          I check 3 out of four. Low level C programming goes swoosh! over my head.
                                          • brodieB
                                            brodie
                                            Intel Core2 Quad Q9550 2.83GHz Processor
                                            8.0 G RAM
                                            nVidia Quadro FX 3700 512Mb
                                            Windows Vista 64-bit
                                            SU 7.0.8657
                                            5800x3093 (AA on/Shadows on)
                                            -Brodie
