    How does this window work? ;)
    42 Posts 14 Posters 5.6k Views 14 Watching
    • K
      kwistenbiebel
      Interesting.
      Being able to cut double faced structures would be a very useful feature and saves a headache when modeling buildings with a lot of repetitive window openings.
      I haven't got a clue how it is done though. Maybe Thomtom is right in his guess?
      • GaieusG
        Yes, Thom was right.
        The back faces of the inner walls are transparent while the front faces are white. πŸ‘
        There are two problems however:
        1. "from inside" (the room), this effect cannot be seen (unless you flip the components)
        2. I'm not sure how these things would behave with different PR rendering apps (I mean if they "like" back faces painted transparent or not at all)
        @thomthom said:
        One of my colleague had another work around one time to cut double holes. He made one cutout for each side. Though, the drawback was to remember to move/rotate/scale both at the same time, since you can't group them.
        But you can have two components - one cutting the outside face and one cutting the inside face - nested in a third component which also needs to have the gluing/cutting plane set properly. Now this parent component will only cut one hole but when you explode it, the remaining two child components regain their cutting features and will cut both holes.
        So just remember to explode the parent component t the end of modelling. Until then however, you won't be able to see through both faces of a thick wall unless you combine the two methods.
        OK,to demonstrate it, here is an "example" file with three components in it. There is an Outside Window to cut the outer face, an Inside Window to cut the inner face and a (simple) Window to contain both. On top of all, I used the "transparent backface trick" here again. So what you need to do is:
        1. Insert a window into the wall. You will be able to see through it from outside only but immediately - this is due to the transparent back face BUT if you orbit around, you will notice that from inside (the room) you cannot see through the window.
          However you can (still) easily move/position it in your model so it is handy as a "working component" during modelling.
        2. Explode this component - now the two,nested "child" components (Outside Window and Inside Window) will regain their cutting feature and now you can see through both from outside and inside. Note however that in this case, it is already harder to move them together as you will need to select both for that (although there is a trick I learned from Wodan for that - turn on hidden geometry to see the two "handles" by which you can drag the outside and inside components)
        Exmple.skp
        Note that the Window component in the model is "collapsed" - you need to explode it or expand it to see the "Outside Window" and Inside Window" components in the browser.
        Also, saved it "back" to SU 6 format.
          David Copperfield the big illusion! πŸ˜„
            I believe V-Ray had an option to set a material to only be rendered on one side. I'll do a quick test when I get home.
            Got any more puzzles Gaieus? I enjoyed this one.
            • GaieusG
              I'll also test it out in Kerky and IDX Renditioner and such - it'd be good to safely know when and how it can be used.
              As for more "puzzles" - well, there might be others as well (and I also like taking part in others' puzzles) so everybody feel encouraged! After all, this is not ONLY a help forum! πŸ˜„
              • E
                Ecuadorian
                sigh....
                For a minute I thought SketchUp had finally evolved into Super-ArchiCAD.
                (And I left a dumb comment in the Youtube video 😳 )
                -Miguel Lescano
                • GaieusG
                  Never mind - I'd sell them if I could, believe me! πŸ˜„
                    This is how it renders in V-Ray straight from the box. Same as you get in SU.
                    I wonder if I can make a plugin which can iterate over the windows and find there they intersect on the other wall face and insert an cut-through opening in the correct place. And also link the extra opening to the proper window component so if you mode or scale it, it will sync automatically. That would be a solution which would minimize the amount of work.
                    • X
                      xrok1
                      so, it was a riddle after all. 😎
                      • broomstickB
                        broomstick
                        @ecuadorian said:
                        sigh....
                        Me too, me too..
                        • GaieusG
                          Okay, if you meant "riddle" like that, it was. πŸ˜„
                          Yet it's straight SU modelling as "workarounds" in SU are considered "normal strategy"
                            I'm getting pretty close to generating a cutout component on parallel faces to cutout components. Got to find a good way to manage and keep track of them.
                            Though, this Solid Front Face - Transparent Backface method can prove it self quite useful for presentations where you want some kind of X-Ray effect at times.
                            • GaieusG
                              True, just imagine a case when you quickly need to change different openings to present ideas to a client. If you are careful enough, they will never realise that these windows don't actually cut that inside face.
                                Not only that, but you can fake section cuts in custom shapes... πŸ˜‰
                                  sepo
                                  Nice one Gaieus. It renders OK in Podium as well.
                                  • GaieusG
                                    Thanks Sid.
                                    I don't think it's very original (i.e. I am sure that only reinvented the wheel). It's obvious that there is no "real" solution for double cutting components so for different purposes we can use different workarounds (or their combinations).
                                    • N
                                      NewOne
                                      Is there a possibility to identify where edges of a component intersect with faces of other component? Because if it is, then on that face can be added vertexes inside the component on intersection coordinates, then add lines. Finally delete the inner created face. In this way, the component cuts trough how many faces it intersects.
                                        sepo
                                        Still very good workarround if you are still designing. Saves a lot of time. πŸ‘
                                        Thomthom
                                        "I'm getting pretty close to generating a cutout component on parallel faces to cutout components. Got to find a good way to manage and keep track of them."
                                        That sounds like very good news.
                                          @sepo said:
                                          Thomthom
                                          Generating the opposite cutouts where easy. Trying to keep track of them all and ensure that all new components placed also cuts double is more work.
                                            sceyefeye
                                            you guys are giving me a headache just thinking about this
                                            could have sworn that Renderplus or one of those tools had a multi-line wall, just trying to think where I imagined I saw it
                                            what amazes me is that google haven't co-opted a lot of these scripts as "standard" functionality. I sometimes wonder if there is a reluctance to make google too powerful (I know the idea of sketchup is to be simple) but everywhere I turn people are not using it for "simple"
                                            • 2 / 3
