    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.6k Views 135 Watching
    • B
      BTM
      Some of my first "d'uh" moments when learning about the middle button thing: when using the middle button, hold SHIFT to pan, or hold OPTION to allow the camera to tilt.
      also a "d'uh" moment from long ago: holding OPTION when moving an object, push/pulling an object, or rotating an object, to duplicate it.
      note: these are for mac. Buttons might be different on windows.
      • B
        BTM
        I just leaned this yesterday and I am kicking myself.
        When selecting object I normally went with a box from upper right to lower left drawing a box around things.
        Worked fine for months or years.
        Try a sweep left to right going over the objects. It has a totally different feel and works like a charm, feels to me at least like it saves a lot of movement. I use a tablet, not sure if has quite the feel with a mouse but it works, try it if you haven't.
        This thread is great, and so are all you good people on the forum. I learn something everyday I look here.
        Thank you for all,
        Right to left selects anything in or touching the selection box, left to right only selects things in the selection box. Is that what you meant? Because it works the opposite way you described for me. Right to left is useful for cleaning up lines after an intersection I find.
        • T
          Teezer
          I found out today that the rotate tool does the same thing that the move tool does when you hit the Ctrl key. It puts a plus sign next to the cursor and copies the rotated object, leaving the original in place.
          Not that I have an immediate use for this -- I just hit it by accident, and there it was... ๐Ÿ˜†
          Real life is just another website, albeit a rather boring one.
          • B
            BTM
            I've had plenty of uses for it, my current WIP is 4-way symmetrical, and that makes it easier to place everything in the same place in all directions.
            • david_hD
              david_h
              Try it for Polar Arrays . . .it's loads of fun! But. . .Im sure you knew that! ๐Ÿ’š
              • B
                BTM
                A new "D'uh" for me: holding shift while using the smoove tool: smooves from normals.
                  What??? Duh!!!
                    Rodentpete
                    Damn!! This has to be the most useful 'Duh!' in the thread - is this documented anywhere?!
                      remus
                      You can sculpt in a direction other than vertical by holding down
                      the Shift key while moving the mouse. However, this operation can result in a
                      non-functional terrain or terrain that can no longer be manipulated in a known
                      way. This operation can only be performed while in active selection (not after
                      preselection).
                        False Duhduh! ๐Ÿ˜’ Oh! ๐Ÿ˜ฎ A manual is existing? ๐Ÿ’š
                        PS You don't need especially a manual : Just Look at the line help Page Bottom! ๐Ÿ˜†
                        It's Write...
                        Line help is an another false Duhduh! ๐Ÿ˜„
                        • B
                          BTM
                          Mine didn't say that.
                            sepo
                            [/quote]Being able to put in "s5" in the VCB to control the number of sides before I create a circle or arc... Big Duh![/quote]
                            It does not work for me. As soon I type s it triggers scale tool. Btw If you call arc or circle vcb gives you option to type in number of segments.
                            • soloS
                              try 5s.
                                sepo
                                But what is the point as vcb gives you option for number of sides as soon as you select arc or circle.
                                • soloS
                                  I dunno, I use the model info options to alter my segments anyway.
                                    @BTM: As shown on the green image above ๐Ÿ˜„
                                      An another one ๐Ÿ˜„
                                      • GaieusG
                                        Duh... I've never noticed you can collapse that Entity info box (mine is always expanded). Well, still better than the other way around. ๐Ÿ˜„
                                          My Duhduh of the day! โ˜€
                                          No exactly for SU but ๐Ÿ˜‰
                                          As make a "snapshot" of a video is impossible ๐Ÿ˜ฎ
                                          You can Save "as an image" when you make pause inside the viewer! ๐Ÿ˜ณ
                                          So I have need this today for this crazy teaser of Fredo6 and his new Bend Function! ๐Ÿ˜ฒ ๐Ÿ˜Žbend.jpg
                                          (click image if scrallbars)
                                          • E
                                            Ecuadorian
                                            Pause inside the viewer? What viewer?
                                            -Miguel Lescano
                                            • 34
                                            • 35
                                            • 5 / 35
