    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 160.2k Views 83 Watching
    • fredo6F Offline
      @borgman said:
      Gonna bump this one up again. Fredo, have you made any progress on the script? Or is it likely that it will stay like this for some time. I'm going to install it in 7 right now, so I'm keeping my fingers crossed! ^_^
      With the holdiays, I am just resuming some work on my scripts. Indeed, I will try to fix issues with Round Edge (and maybe develop the spheric / elliptic option).
      PS: For the bug splats, it may come from the geometry itself. I never got any myself, but I don't work on complex model either. As a general rule, be careful if you work on the geometry of a component instance whose definition is also used in other instances with transformation such as rotation.
      • I Offline
        Iglesias
        Thank you Fredo, I wish you a happy New Year.
        • olisheaO Offline
          olishea
          oh my god how much time will this save!! thank you sooooo much.
          oli
          • E Offline
            Efrado
            THANNNNKSSS A LOOOOT for another magnificent Gift from your Kidness
            • 3 Offline
              3DModellers
              hey.. could anybody help. I tried this plugin today on skp 7. I made a cube and tried the round edge option. All it did was it placed two lines on either side of the ONE lone edge of the cube. There wasnt anything else.
              am I using outdated version?
              Does it work with skp 7 ?
              I downloaded it from the first page of this thread. Any idea where can I find the latest version?
              regards
              Pritam
              • fredo6F Offline
                RoundEdge normally works with SU7. I did not get any probleme before before yours.
                Could you open the Ruby Console and advise on what you see.
                Also, could you post the skp model if there is anything specific that could help to understand more.
                • 3 Offline
                  3DModellers
                  Hi Fredo,
                  I got it.. I got it to work.
                  Few days ago I had problems running podium renderer in sketchup. Somebody suggested that that removing 'matchbox' plugin might solve the problem. And it had worked.
                  i did the same this time. I removed matchbox again and then 'round edge' worked perfectly.
                  It means that the problem is with 'matchbox' plugin. Or it could be that I am using some earlier version of matchbox which was not compatible with other plugins.
                  anyways , thanks.
                  iam also thankful for all the wonderful work that you and Whatt are doing. I realised that I saved 2 hours of work yesterday simply thru round edge plugin.
                  Do you have any blog where all your plugins listed?
                  Pritam
                    Daniel S
                    Fredo, When you say to develop the spheric / elliptic option do you mean something like the attachment image?
                    That would be a huge improvement πŸ˜„
                    Thank you again for this amazing must-have tool...
                    Daniel S
                    • free agentF Offline
                      free agent
                      +100 this would be amazing
                        +101!
                        It's a cool plugin already now (although has some limitations like the Follow me can also have with concave curves) but a rounded corner (preferably an "option" vs the pointy one) would indeed be a great improvement!
                          [attachment=0:1hhs0yf5]<!-- ia0 -->roundedges.jpg<!-- ia0 -->[/attachment:1hhs0yf5]
                          Daniel S
                          How did you do that?
                            free agent
                            Bonzai3d...?
                              jmmad
                              SU needs and can catch up with bonzai3d
                              Fredo this ruby + other transformation like twist and bend would be really great.
                              Get Upa !
                                free agent
                                Funny(and sad) that Sketchup on version 7 needs to catchup with a beta release... interestingly bonzai 3d shares a render engine with modo (assuming that it has the same render engine as FormZ)
                                • O Offline
                                  Oaht
                                  Thanks for your superb plugin. This will save a lot of time!!!
                                    BorgMan
                                    It would be great if the Round Edges tool would work like that Bonzai3D image. I've had so much models which use complex shapes that totally effed up when I unleashed the RE tool on them, after which I had to manually retrace the outlines to make them work properly...
                                    More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                    You've gotta love Slivers.
                                      gio
                                      Can you tell me more about this, please?
                                      Do you have a link?
                                      It would really be a great news!
                                      Ciao, Gio
                                      • N Offline
                                        numerobis
                                        (www.bonzai3d.com)
                                        (btw. google is your friend πŸ˜‰ )
                                        • X Offline
                                          xrok1
                                          hi fredo, great script once more. 😲
                                          did you ever figure out how to overcome this type of thing?
                                            TeamSDA
                                            Hey Fredo
                                            This is a great script we are having difficulties with its performance due to a high number of edges. We are currently working on how to extrude letters from .dwg files and we want to bevel the edges of the letters but they are made up of many edges and the script gets bogged down with the task. πŸŽ‰
                                            Team SDA
                                            Here is the file we are currently working on.
                                            Logo Tests.skp
                                            • 8 / 9
