    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 24.0k Views 20 Watching
    • X Offline
      xrok1
      i noticed that when running a simulation if i zoom in and out with my mousewheel that sketchup changes to a bounding box display and suddenly the sim choppiness is gone and it runs smooth and fast. this also is the case when playing back a recorded sim.
      so...
      two things come to mind 1) it could be good to have an option in SP to run sim and/or recording in bounding box display.
      2) can someone tell me if i can force SK manualy into BB display?
      btw i noticed that magnets don't effect frozen magnetics unless they come in contact. i think it would be nice if magnets "thawed" if you will, frozen magnets.
        CPhillips
        To get max speed you can turn off shadows and disable all the edge style settings in the View menu. I dont know how to force it to go to just bounding boxes.
        I am not sure I understand the problem with the frozen magnets. Can you post an example?
          Click Draw
          So will you post another link to installer the new version? Sounds awesome!
          Jeff
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            l.frisken
            so would it be possible to make something like that monkey lander mini clip game? That would be really cool with the thrusters rotating and stuff!
              CPhillips
              Here is an update on the next version. I was writing up the docs for the new Controller commands and I realized I am not happy with them. Too complicated. I am going to revise it this weekend. I think I can do it without breaking compatibility with models made with 3a.
              New Feature:
              I was playing around with magnets trying to make a thruster when I realized I could just add thrusters. So I did. In next version any body can be a "thruster" like the new Magnets. It will attempt to go "up" with a user defined amount of thrust. Its pretty cool!
              First thing I made was a 2 stage rocket, including thrusters to spin it up to make it more ballistic. I have yet to get it to fly straight but it is really fun!
                CPhillips
                I dont know what that is?
                • W Offline
                  Wacov
                  Lots of pretty annoying stuff is happening... the simulation starts, but nothing moves or can be moved, and then I can't cancel it and I have to close SU. I'm also getting pretty frequent bug splats and errors when I try to close the program. All I've done is get half-way through making a differential and started playing with magnets a bit.
                    CPhillips
                    Can you give me steps to reproduce any of these problems?
                    • W Offline
                      Wacov
                      Sorry, I haven't been using it long enough to notice any specific triggers. I found out that the simulation not working was a result of gear joints not being on the top level group, but the crashes seem pretty random.
                        l.frisken
                        just search monkey lander on google and you'll find it...
                        • X Offline
                          xrok1
                          RE: frozen
                          when i drop the big sphere (magnet) through the small spheres (frozen/magnetic),which are not on the surface btw, i would expect them to react to the force being applied. i can't attach the .skp cause its 94 meg. but i can post a better example if its not clear.
                          P.S "magnetic" should be labeled ferrous it help keep things a little clearer.
                            CPhillips
                            @xrok1 said:
                            RE: frozen
                            Your saying you want them to unfreeze as soon as the magnet starts pulling them? Why not just leave them unfrozen it would amount to the same thing.
                            Frozen means an object won't move until its touched. Magnets are not "touching" an object. If it didnt behave as it did all frozen objects would instantly unfreeze as soon as any magnet in the model started pulling them.
                            If your model is 98megs it is probably because you have a bunch of animation stored in it. Try clearing it out with the Plugins->SketchyReplay->Erase option.
                            It was labeled ferrous for a while. But everybody kept asking me what it meant. Magnetic is at least obvious if not totally correct.
                            • X Offline
                              xrok1
                              i was thinking for something like a car(magnet) rolling down a hill, where there are leaves(magnetic) so the leaves don't move(frozen) till the car comes into range. this could be sort of a fake wind simulation etc...
                              • V Offline
                                Verrou
                                Very cool update! Worth the wait. Maybe as an update to SketchyReplay, you could look at adding a speed setting, like 1/2 speed etc 😄
                                And also, it seems that sometimes (although it is happening more frequently) when using SketchyReplay, the objects don't go back to where they started :S Like so:
                                http://img15.imageshack.us/img15/4726/errorkn2.jpg
                                  klaufi
                                  hello
                                  i've awaited sp3 and now its there (kinda). yippie^^
                                  i hope the bugs are quickly removed, for example the magnets arent working in my sp and it causes errors...
                                  @cphillips
                                  but i have another idea to aprove something about the keyboard controllers. i dont know how difficult it is to realize this, but it would be very cool:
                                  you could put a tag near to the joint controls (or something you can additionally write into the controller line), so that the joints wont just move when you press and move back when you unpress. its better to have such an option if you want to build a robot or something like that, so that the servo or piston for example wont just move to his maximum when you press the button, but move and stops when the button isnt pressed. and in the case of motors it would set the speed up or down (i think im repeating myself...sorry)
                                  motors with the zero point in the middle would also be cool. so if you move the slider left it moves forward and backward when you move it right. but i think you wrote something that this is planned for spIV, right?
                                  ok, i hope that my wishes come true^^
                                    CPhillips
                                    If you figure out a way to reproduce this let me know and I'll fix it. In the meantime you should be able to undo a few times and get back to normal.
                                      CPhillips
                                      If you make the leaves out of boxes friction will hold them on the ground until the car is near.
                                        CPhillips
                                        hello
                                        I cant fix the bugs unless you report them. How do magnets fail? How can I reproduce the problem? Can you post a model?
                                          klaufi
                                          that shouldnt be necessary...
                                          when i make an object to a magnet and write some number into the strength field and then push on run nothing happens... it runs like normal, just the block is static and no force slider is there as it should be...and i cant get out of the run mode by reset, just by clicking on select or some other tool, but then the run button doesnt work anymore at all...and when i close su the pc shows me a message, that su doesnt work properly
                                          after reopening su everything is normal again
                                          oh, yeah, im using su 6
                                          btw. i have found a solution for my robot joints:
                                          i have made two motors in opposite direction, one set with slider and one with the key code (rightx for example), both with the same settings, so the one motor pushes exactly against the other until the one your controlling is stronger or weaker
                                          heres an example (model downloaded from warehouse)
                                          edit:
                                          there are functions on both the arrow keys and wasd
                                          and ive found another error: while running sp and puching some of the wasd buttons he sometimes leeves the run mode and selects the tools (A)rc or (S)cale
                                          some experiment on a robot
                                            CPhillips
                                            Ok, I know what causes that. Its when you enter a bad formula. Ill fix it in next release.
                                            You can do motors like you describe by setting the controller to:
                                            0.5-slider('motor')
                                            Make sure the Control Panel window has focus when using the keyboard.
                                            • 2 / 5
