    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 25.5k Views 20 Watching
    • T
      t.larcombe
      i have come across some interesting bugs and have no idea why they are happening. Using this in sketchup 7, i can't seem to use some of the prebuilt components. when using hinges etc the component does not travel in the same orientation as the hinge slider etc.
      Any ideas on where i might be going wrong?
      • B
        Bryden
        Very nice Chris
        I really like the new features πŸ˜‰
        I made a slider controled truster out of 2 boxes held together with ball joints
        and a slider controled magnet πŸ˜„
        Magnet Truster
        http://img7.imageshack.us/img7/8487/googlesketchupuserbarzh3.jpg
        • C
          CPhillips
          Post a model that shows the problem and I'll take a look.
          • P
            Platypus5
            I have found a bug: In this model, the thing is supposed to "explode" like a bomb. It works in sketchyphysics 2, but in the SP3 Alpha, not only does it fail to detonate, but a blank control bar appears. If you touch the control bar, you get an error message.
            Link to model: http://sketchup.google.com/3dwarehouse/details?mid=920ecad0ac545b53266076a1a3bfa166
            Also, could you give us instructions on how to use the rubyscript duplicate objects?
            • C
              CPhillips
              As I said in the Magnets thread, the Sp2 style magnets dont work in this version. The dup option is broken at the moment.
              • P
                Platypus5
                It does not use magnets. It uses spazzed out hinges.
                • P
                  Platypus5
                  Sometimes, if you don't fill in the inspector values exactly right, an error message will pop up every time you try to access the joint in question. This effect can occur both before, during, and after a simulation.
                  • C
                    CPhillips
                    @platypus5 said:
                    It does not use magnets. It uses spazzed out hinges.[/quote]
                    Ah, I see the problem. It will fixed in next version.
                    • C
                      CPhillips
                      Yeah, there is a lot that can go wrong there. I'll see if I can fix it.
                      • C
                        CPhillips
                        @bryden said:
                        Very nice Chris
                        [attachment=0:1pt9feos]<!-- ia0 -->truster_test.skp<!-- ia0 -->[/attachment:1pt9feos]
                        Thats cool! I discovered the same thing last night by connecting two spheres with a slider. πŸ˜„ I am working on a hover car powered by magnet thrusters.
                        • X
                          xrok1
                          awsome plug, thankyou.
                          one suggestion, if i may, would be that the SP inspector window not open automatically every time i start SK or start a new file.
                          thanks again for a fun plugin
                          • C
                            CPhillips
                            If you close the UI using the button (rather than just closing it) it will stay closed.
                            • X
                              xrok1
                              thanks for the (wierd) tip, worked like a charm. πŸ˜„
                              • C
                                CPhillips
                                Its the same in 2.0. Originally the UI button was the "Physics Mode" toggle.
                                But it shouldn't pop up on SU reload anyway. Ill fix in next version.
                                • olisheaO
                                  olishea
                                  xbox 360 joystick support.......lol
                                  oli
                                  • X
                                    xrok1
                                    i noticed that when running a simulation if i zoom in and out with my mousewheel that sketchup changes to a bounding box display and suddenly the sim choppiness is gone and it runs smooth and fast. this also is the case when playing back a recorded sim.
                                    so...
                                    two things come to mind 1) it could be good to have an option in SP to run sim and/or recording in bounding box display.
                                    2) can someone tell me if i can force SK manualy into BB display?
                                    btw i noticed that magnets don't effect frozen magnetics unless they come in contact. i think it would be nice if magnets "thawed" if you will, frozen magnets.
                                    • C
                                      CPhillips
                                      To get max speed you can turn off shadows and disable all the edge style settings in the View menu. I dont know how to force it to go to just bounding boxes.
                                      I am not sure I understand the problem with the frozen magnets. Can you post an example?
                                      • C
                                        Click Draw
                                        So will you post another link to installer the new version? Sounds awesome!
                                        Jeff
                                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                        • L
                                          l.frisken
                                          so would it be possible to make something like that monkey lander mini clip game? That would be really cool with the thrusters rotating and stuff!
                                          • C
                                            CPhillips
                                            Here is an update on the next version. I was writing up the docs for the new Controller commands and I realized I am not happy with them. Too complicated. I am going to revise it this weekend. I think I can do it without breaking compatibility with models made with 3a.
                                            New Feature:
                                            I was playing around with magnets trying to make a thruster when I realized I could just add thrusters. So I did. In next version any body can be a "thruster" like the new Magnets. It will attempt to go "up" with a user defined amount of thrust. Its pretty cool!
                                            First thing I made was a 2 stage rocket, including thrusters to spin it up to make it more ballistic. I have yet to get it to fly straight but it is really fun!
                                            • 2 / 5
