    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 25.5k Views 20 Watching
    • X
      xrok1
      awsome plug, thankyou.
      one suggestion, if i may, would be that the SP inspector window not open automatically every time i start SK or start a new file.
      thanks again for a fun plugin
      • C
        CPhillips
        If you close the UI using the button (rather than just closing it) it will stay closed.
        • X
          xrok1
          thanks for the (wierd) tip, worked like a charm. 😄
          • C
            CPhillips
            Its the same in 2.0. Originally the UI button was the "Physics Mode" toggle.
            But it shouldn't pop up on SU reload anyway. Ill fix in next version.
            • olisheaO
              olishea
              xbox 360 joystick support.......lol
              oli
              • X
                xrok1
                i noticed that when running a simulation if i zoom in and out with my mousewheel that sketchup changes to a bounding box display and suddenly the sim choppiness is gone and it runs smooth and fast. this also is the case when playing back a recorded sim.
                so...
                two things come to mind 1) it could be good to have an option in SP to run sim and/or recording in bounding box display.
                2) can someone tell me if i can force SK manualy into BB display?
                btw i noticed that magnets don't effect frozen magnetics unless they come in contact. i think it would be nice if magnets "thawed" if you will, frozen magnets.
                • C
                  CPhillips
                  To get max speed you can turn off shadows and disable all the edge style settings in the View menu. I dont know how to force it to go to just bounding boxes.
                  I am not sure I understand the problem with the frozen magnets. Can you post an example?
                  • C
                    Click Draw
                    So will you post another link to installer the new version? Sounds awesome!
                    Jeff
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                    • L
                      l.frisken
                      so would it be possible to make something like that monkey lander mini clip game? That would be really cool with the thrusters rotating and stuff!
                      • C
                        CPhillips
                        Here is an update on the next version. I was writing up the docs for the new Controller commands and I realized I am not happy with them. Too complicated. I am going to revise it this weekend. I think I can do it without breaking compatibility with models made with 3a.
                        New Feature:
                        I was playing around with magnets trying to make a thruster when I realized I could just add thrusters. So I did. In next version any body can be a "thruster" like the new Magnets. It will attempt to go "up" with a user defined amount of thrust. Its pretty cool!
                        First thing I made was a 2 stage rocket, including thrusters to spin it up to make it more ballistic. I have yet to get it to fly straight but it is really fun!
                        • C
                          CPhillips
                          I dont know what that is?
                          • W
                            Wacov
                            Lots of pretty annoying stuff is happening... the simulation starts, but nothing moves or can be moved, and then I can't cancel it and I have to close SU. I'm also getting pretty frequent bug splats and errors when I try to close the program. All I've done is get half-way through making a differential and started playing with magnets a bit.
                            • C
                              CPhillips
                              Can you give me steps to reproduce any of these problems?
                              • W
                                Wacov
                                Sorry, I haven't been using it long enough to notice any specific triggers. I found out that the simulation not working was a result of gear joints not being on the top level group, but the crashes seem pretty random.
                                • L
                                  l.frisken
                                  just search monkey lander on google and you'll find it...
                                  • X
                                    xrok1
                                    RE: frozen
                                    when i drop the big sphere (magnet) through the small spheres (frozen/magnetic),which are not on the surface btw, i would expect them to react to the force being applied. i can't attach the .skp cause its 94 meg. but i can post a better example if its not clear.
                                    P.S "magnetic" should be labeled ferrous it help keep things a little clearer.
                                    • C
                                      CPhillips
                                      @xrok1 said:
                                      RE: frozen
                                      Your saying you want them to unfreeze as soon as the magnet starts pulling them? Why not just leave them unfrozen it would amount to the same thing.
                                      Frozen means an object won't move until its touched. Magnets are not "touching" an object. If it didnt behave as it did all frozen objects would instantly unfreeze as soon as any magnet in the model started pulling them.
                                      If your model is 98megs it is probably because you have a bunch of animation stored in it. Try clearing it out with the Plugins->SketchyReplay->Erase option.
                                      It was labeled ferrous for a while. But everybody kept asking me what it meant. Magnetic is at least obvious if not totally correct.
                                      • X
                                        xrok1
                                        i was thinking for something like a car(magnet) rolling down a hill, where there are leaves(magnetic) so the leaves don't move(frozen) till the car comes into range. this could be sort of a fake wind simulation etc...
                                        • V
                                          Verrou
                                          Very cool update! Worth the wait. Maybe as an update to SketchyReplay, you could look at adding a speed setting, like 1/2 speed etc 😄
                                          And also, it seems that sometimes (although it is happening more frequently) when using SketchyReplay, the objects don't go back to where they started :S Like so:
                                          http://img15.imageshack.us/img15/4726/errorkn2.jpg
                                          • K
                                            klaufi
                                            hello
                                            i've awaited sp3 and now its there (kinda). yippie^^
                                            i hope the bugs are quickly removed, for example the magnets arent working in my sp and it causes errors...
                                            @cphillips
                                            but i have another idea to aprove something about the keyboard controllers. i dont know how difficult it is to realize this, but it would be very cool:
                                            you could put a tag near to the joint controls (or something you can additionally write into the controller line), so that the joints wont just move when you press and move back when you unpress. its better to have such an option if you want to build a robot or something like that, so that the servo or piston for example wont just move to his maximum when you press the button, but move and stops when the button isnt pressed. and in the case of motors it would set the speed up or down (i think im repeating myself...sorry)
                                            motors with the zero point in the middle would also be cool. so if you move the slider left it moves forward and backward when you move it right. but i think you wrote something that this is planned for spIV, right?
                                            ok, i hope that my wishes come true^^
                                            • 2 / 5
