    Manhattan sketchup model
    60 Posts 21 Posters 27.4k Views 21 Watching
    • B
      bubbalove
      I'm downloading it right now with no problems...
      But when I try to open it, it causes Sketchup to bog down... it's only 27.7mb... I have files larger than this that open in a couple of seconds...
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • boofredlayB
        boofredlay
        I can't get it to open either.
        • F
          FenS
          download went fine (first had to wait 2 minutes),
          but after opening it doesn't react anymore (or i'm not patient enough)
          Qué sais je? there is still so much to be learned...
          • B
            bubbalove
            I let it try to open overnight at work on my 3.0ghz processor w/ 2gigs of ram. It was open when I got here but my computer was frozen...
              Simon B
              I'm planning to buy a new laptop at the weekend; let's see how 4Gb of RAM tackles this ...
              • boofredlayB
                boofredlay
                I doubt it will help. The file must be corrupted. I have a number of files much larger than this and they open fine.
                • C
                  chango70
                  Actually I've opened up the file fine. It did take about 2mins to load. I have Core i720 and Quadro FX3700 on my desktop, which helped.
                  • O
                    oalexis
                    I have also opened it, but it makes sketchup freeze up for about 5 min on my computer (Q6600)
                    • boofredlayB
                      boofredlay
                      Were either of you able to purge then get it to behave?
                      • B
                        bubbalove
                        If you are able to get it to work... would you mind posting the purged file?
                        • C
                          chango70
                          It is behaving strangely! None of the buildings caste shadow except for the bridges and some of them have the trianglated geometry that reminds of 3ds import... I'll try and see if I can clean it up.
                          • GaieusG
                            I couldn't even open the file (3.8 GHz processor, 2 Gigs of RAM) 😲
                            • C
                              chango70
                              Oh wow. This can't be a native sketchup model!? It has 2 surfaces for everything!! and missing surfaces for large part of the gound...
                              • N
                                nightzombie
                                i think the person who made the model
                                converted it from some other application.
                                i had no idea it was double faced 😆
                                it usually takes my laptop about 5 minutes of freezing sketchup to load
                                  Simon B
                                  Could an Okino converter or something similar strip out the double faces?
                                  • K
                                    kwistenbiebel
                                    Looks like it is done in Rhino (or another solid modeler) as often geometry is imported double (disconnected edges).
                                    Probably the author forget to convert his model to a mesh and weld the edges....
                                    • brodieB
                                      brodie
                                      Quite disappointing. I was sort of excited when I saw the original image. Anyone have a similar city model they'd like to share? I looked a bit on the warehouse but didn't run across anything very appealing.
                                      -Brodie
                                        Simon B
                                        I wonder if somone in the sketchup team has access to one? I am working on a game project and wanted to use a model like Manhattan to compare relative sizes of very large objects. Hope it's not too much of a big ask if anyone is listening.
                                        If not, I will have a bash at tidying this model - but don't hold your breath...
                                        • B
                                          bubbalove
                                          I would be willing to clean the model but I can't get the damn thing to open... if someone can just clean it to where I can open it without sketchup crashing... i'll finish the rest!
                                            Simon B
                                            I found this resource in the meantime:
                                            Not Found
                                            (www.3dcadbrowser.com)
                                            And this utility may help to remove double-faces (haven't tested):
                                            http://www.deep-shadows.com/hax/3DRipperDX.htm (3d Studio Max and Maya only)
                                            • 1 / 3
