    Manhattan sketchup model
    60 Posts 21 Posters 26.1k Views 21 Watching
      me3mar
      i'm downloading it right now, thank you sooooooooooooo much
      looks great.
      • EdsonE
        Edson
        zombie,
        would you please post the complete link to the model? the link above just leads to the google skp site.
        http://www.mahfuz.arq.br
        • N
          nightzombie
          The link to the skp file is right underneath the image
          • soloS
            I tried to download it but for some reason it timed out and it refuses me to try again by citing that my IP has already downloaded file and cannot retry unless i become a premium member, any other link?
            • B
              bubbalove
              I'm downloading it right now with no problems...
              But when I try to open it, it causes Sketchup to bog down... it's only 27.7mb... I have files larger than this that open in a couple of seconds...
              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
              • boofredlayB
                boofredlay
                I can't get it to open either.
                • F
                  FenS
                  download went fine (first had to wait 2 minutes),
                  but after opening it doesn't react anymore (or i'm not patient enough)
                  Qué sais je? there is still so much to be learned...
                  • B
                    bubbalove
                    I let it try to open overnight at work on my 3.0ghz processor w/ 2gigs of ram. It was open when I got here but my computer was frozen...
                      Simon B
                      I'm planning to buy a new laptop at the weekend; let's see how 4Gb of RAM tackles this ...
                      • boofredlayB
                        boofredlay
                        I doubt it will help. The file must be corrupted. I have a number of files much larger than this and they open fine.
                        • C
                          chango70
                          Actually I've opened up the file fine. It did take about 2mins to load. I have Core i720 and Quadro FX3700 on my desktop, which helped.
                          • O
                            oalexis
                            I have also opened it, but it makes sketchup freeze up for about 5 min on my computer (Q6600)
                            • boofredlayB
                              boofredlay
                              Were either of you able to purge then get it to behave?
                              • B
                                bubbalove
                                If you are able to get it to work... would you mind posting the purged file?
                                • C
                                  chango70
                                  It is behaving strangely! None of the buildings caste shadow except for the bridges and some of them have the trianglated geometry that reminds of 3ds import... I'll try and see if I can clean it up.
                                  • GaieusG
                                    I couldn't even open the file (3.8 GHz processor, 2 Gigs of RAM) 😲
                                    • C
                                      chango70
                                      Oh wow. This can't be a native sketchup model!? It has 2 surfaces for everything!! and missing surfaces for large part of the gound...
                                      • N
                                        nightzombie
                                        i think the person who made the model
                                        converted it from some other application.
                                        i had no idea it was double faced 😆
                                        it usually takes my laptop about 5 minutes of freezing sketchup to load
                                          Simon B
                                          Could an Okino converter or something similar strip out the double faces?
                                          • K
                                            kwistenbiebel
                                            Looks like it is done in Rhino (or another solid modeler) as often geometry is imported double (disconnected edges).
                                            Probably the author forget to convert his model to a mesh and weld the edges....
                                            • 1 / 3
